2012/10/13
Hello guys!
I was asked by a friend of mine to upgrade his new bought Cube U30GT-H to a rooted firmware but I dont succeed to enter recovery mode!
I tried a bunch of different combinations with the volume and power buttons but the closest I get to recovery mode is when I hold the volume - (down) button and power button and wait for the logo to appear and suddenly there´s a loud click noise and when nothing!Â
Thx in advance!
PS: The tablet came pre-installed with the metro UI if that matters....
First make sure you're using a properly working USB cable, the one that ships with the Cube tablet has a bad reputation.
See our guide for Rockchip flasher.
On the U30GT, the proper sequence is:
- disconnect the USB cable and shutdown your tablet
- press Vol+ key then power button on the tablet
- while you hold the two buttons, plug in the USB cableÂ
- when tablet screen turns back and Windows detects the device, you can release the buttons on the tablet
Modo, pamtayls, jooker If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/10/13
First make sure you're using a properly working USB cable, the one that ships with the Cube tablet has a bad reputation.See our guide for Rockchip flasher.
The tablet doesnt respond when I hold the volume + and power button at the same time
2012/09/26
It is normal way... I had flash my cube and the first time I was in the same interrogation ^^
My way: firstly , plug to pc with usb cable, secondly turn on in recovery mode...
The only sign that the recovery mode is on: windows detect it and announce: drivers installing etc etc...
the screen stay turned off during all flash procedure and it turned on after reboot
I flashed several time my tab' and any problem at this time are discovered
Cheers
Rob'
The following users say thank you to bishop.sad.clown for this useful post:
rohshallAsus K54HR: Xubuntu 12.04 LTS,
Cube U30GT-H: Android 4.1.1, rom: 1.07b from here
Samsung Galaxy Pocket ( GT-S5300 ): rom custom, MAK-ROM DROID V2
2012/10/13
Cheers
Rob'
Thx mate, but my windows 7 says that it couldnt install the drivers due to the fact it couldnt identify the device :/
123 Guest(s)
Devices in use: Desktop (110), Phone (11), Tablet (2)
Nobrubbr
pall668
Debilai1234
senaslapinas
WINL
Olione
