2012/10/04
I have a problem with my tablet U30GT. Sometime the screen is awake due to SD card remove unexpectedly. I have a rooted firmaware 1.07 (kasty-cube_u30gt_h-41-107-rooted) Can anybody have same problem?
Thank you,
Radek
2012/09/26
I haven't got this problem... I just sometime the data access onto external sdcard makes errors and momently freeze...
It is a 32 Go "noname" card so maybe the problems go from it... but no problem with internal memory or internal sdcard...
Sorry if my feedback doesn't bring anything...
Cheers,
Rob'
Asus K54HR: Xubuntu 12.04 LTS,
Cube U30GT-H: Android 4.1.1, rom: 1.07b from here
Samsung Galaxy Pocket ( GT-S5300 ): rom custom, MAK-ROM DROID V2
try to reinsert the card, maybe in some positions, the sd card does not touch the pins, gets a little bit loose, and then you get the sd removed.
2012/09/27
trungakira said
1/ Cube U30gt-H no support SDHC card NTFS
2/ Using 32 Gb Micro SD card Class 4 will fix the problem
On both my Cubes (U30GT-H 16GB and 32GB) I use Sandisk 32GB class 10 micro SD cards, formatted with NTFS format.
Actually after the 1.07 update, I found that if I had them formatted with Fat32, I was getting corrupted files. Only NTFS saved me from them.
84 Guest(s)
Devices in use: Desktop (81), Phone (3)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
