| Latest product reviews |
(1 votes) 22:30
OfflineArchos 101 XS
Just released [[** please register to see this link **]] (2012/12/14) U23GT_v1.06_20121214.zip
Version 1.06 revision history from Cube (translated from Chinese by Google Translate):
1. Updated to Android 4.1 system;
2. solve Aging crash problem;
3. enter the browser sometimes save bookmarks screen flicker;
4. enter the e-mail error phenomenon.
Android build: rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/20121122.205441:eng/release-keys
Linux Kernel: Linux version 3.0.8+ (eyes#0001@eyes) (gcc version 4.4.3 (GCC) ) #325 SMP PREEMPT 2012-12-13 15:59:15 4:50
Here is a custom rooted firmware version of the Android 4.1 Jelly Bean based on official version 1.06
Features:
- root with latest SuperSU 0.99 (free version)
- writable /system partition
- updated busybox to version 1.20.2-cm9
- update busybox to version 1.20.2-cm9
- included [[** please register to see this link **]] (a 5-row keyboard using full PC key layout) as latest Cube update had regular non Chinese keyboard removed
Rooted custom firmware for the CUBE U23GT: [[** please register to see this link **]]
Using [[** please register to see this link **]] version 1.5 to flash the firmware.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Cube U23GT to test it.
foox2k, daniel.yap, RandumAccess, ol213Last edited by admin on 2012/12/17 - 21:45
I tried to flash the firmware , it boots , try to open SuperSu, an error apears it says it got to update so i turn on wifi and an error apear it says unfortunately. Android keyboard (AOSP) has stopped it keeps poping up every time i try to use the keyboard so i go and freze Android Keyboard with Titanium Backup and install Swype , no problem after that, anybody else with this problem?
10:21
A bit of warning following foox2k message. It looks like Cube has removed non Chinese virtual keyboard on some firmwares. It is the case on latest Cube U30GT-MINI and latest U23GT firmwares. I have replaced the missing APK with one from an earlier firmware, but it doesn't seem to be working well, as foox2k reported some errors related to the keyboard. I'm currently having a look at this issue, will keep you updated.
I confirm the Android keyboard problem as well. I tried the firmware this evening, and Android keyboard keeps on crashing. Cannot comment on anything else, except that I've done a full clean using RESTORE option, and worked Ok, less the keyboard problem.
I hope you'll figure it out soon guys. Thanks again for the terrific work!
Just try to install another virtual keyboard like swype and set it as your custom virtual keyboard, i also freeze the original android keyboard with titanium backup, it seems to work fine now.
The following users say thank you to foox2k for this useful post:
XtremeOneI have reflashed to 4.0.4 and installed some free keyboard. Now I make the update to 4.1, and see if it works. Thanks for the advice. BTW, why do you need to freeze the original keyboard with Titanium backup?
UPDATE: I have upgraded to 4.1 but it did not keep the keyboad app which I installed previously, so I cannot enter my password for my WiFi. Any … suggestions?
21:43
I have rebuilt a custom firmware with [[** please register to see this link **]] as default keyboard, since Cube latest firmware doesn't have one.
I have updated the file in post #1:
Nice Rom but I was wondering if there was anyway to incorporate some tweaks like maybe a CyanogenMod Build or to use some of their tablet tweaks? or maybe a MIUI Build Rom? I would try to do it myself but I really dont know what im doing lol
I like this rom and appreciate it very much though… Didnt mean to sound ungrateful just would like to try more options on this device
Thanks!
PS – I also tweaked the build.prop with Rom Toolbox Lite with the following settings:
wifi.supplicant_scan_interval – I changed from 15 to 180
And I tweaked the CPU Control with Rom Toolbox Lite with the following settings:
I slid the max down to 1200mhz
CPU settings not sticking :/
I have been getting really good battery life with the wifi change though!
I AM NOT RESPONSIBLE FOR ANYTHING THAT HAPPENS TO YOUR DEVICE AS A RESULT OF APPLYING THESE CHANGES, IF YOU CHOOSE TO DO SO… lol
19:48
Well, the general rule is not to upgrade when everything is working fine ![]()
Maybe just wait for next release or the following if there are interesting items for you in the release changelog for the new versions.
20:24
OfflineCube U23GT
hello guys, I brick my tablet, cube u23gt, during the flash appear IDB Download Fail…I'm desperate, i now for the u30gt it's easy to unbrick the tablet, is sufficient to connect two contacts, but these are different of my u23gt…I disassembled it, but I do not know what to do, what are the contacts you want to merge for the maskrom mode??? please help me..
Most Users Ever Online: 646
Currently Online: globula_neagra, westmarine, ariga, BOBDAVE, pombas, furonai, algem, JDfense, rich270982, piotrr00, msmelko, renato0134, mobango, smot, pribi, zerscher, erta1, msantos001, Makotosan, blodnje, Raska501, md990, ebeb2 U30GT2, jobrima, airman, jamesian, szczudlo, dessman, 3lackhawk, jlbahi, maurizio, yucelis, PLGHA, ricky_mk4, vincent8575, RedWolfwere, solemats, jz3, robototo, lozweezy
205 Guest(s)
Currently Browsing this Page: vincent8575
admin: 3646
globula_neagra: 1857
Guest Posters: 36
Members: 73386
Forums: 121
Topics: 2789
Moderators: HaroldG (117), globula_neagra (1857), exelletor (344)
Administrators: admin (3646)
Log In
Register
Arnova and Archos support Forum
