Just released: Cube U23GT official firmware version 1.05 (2012/11/17), it seems to be mainly a kernel update:
Version 1.05 revision history from Cube (translated from Chinese by Google Translate):
1. To amend the part of the machine aging game crash problem;Â
2. solve the problem after wake not part of the machine Screensavers.
Android build:Â rk30sdk-user 4.0.4 IMM76D eng.wbx.20120615.112351 test-keys
Linux Kernel:Â Linux version 3.0.8+ (eyes#0001@eyes) (gcc version 4.4.0 (GCC) ) #489 SMP PREEMPT Mon Nov 5 09:55:53 CST 2012
Here is a custom rooted firmware version of the Android 4.04 ICS based on official version 1.05
Features:
- root with SuperSU 0.96 (free version)
- writable /system partition
- increased space for application (/data partition) to 1.5 Gb.
Rooted custom firmware for the CUBE U23GT: kasty-cube_u23gt-404-105-rooted.zip
Using Rockchip Batch Tool version 1.5 to flash the firmware.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Cube U23GT to test it.
thanks for this forum and the job to create custom firmware.
I tried from the version 1.02 to upgrade to the new version 1.04 custom firware. So the custom firmware works fine except the evolution  "1) Optimization problem can not wake up dormant standby"
I still have the problem, ater 20 or 30 seconds, I have to reset the tablet by pressing 12 sec the power button.
So I would like to know if it's problem is solve with this version ?
Thanks for your feedback.
2012/10/19
Via Pc Using Rockchip Batch Tool version 1.5 to flash the firmware.
Follow this link also check the tutorial.
The following users say thank you to foox2k for this useful post:
carlosU23Carlos U23,
In fact, I've upgrade the tablet from 1.02 to 1.04 version.
So it has worked well. So you can upgrade directly to the 1.05 version, I think.
Now I don't see a lot of improvements with the 1.04. For my part, I was looking for a solution to the wake up or sleeping mode problem.
Normaly, the firmware 1.04 has to correct this problem but it doesn't.
May be I have to find a solution to install a bootloader like malez recovery in order to Wipe all the data and the cache before and after the system upgrade.
Or May be, I have to came back to the 1.02 version and upgrade the tablet with all the versions one by one from 1.03 to 1.05.
I don't have time to do that.
Actually I found an issue to the death sleep or wake up problem for the cube U23GT . I have installed the " Wake lock " application and set it to "Partial Wake lock". In fact this application force your tablet to stay woke up. It's working well and that doesn't have a big impact on the battery.Â
Flashing successive upgrade probably won't work, it's not cumulative like a Service Pack on Windows. Still, it can help trying them all to find the one that best fits you.
Hopefully Cube will fix those sleep problems when they make an Android 4.1 Jelly Bean update. Thanks for the "Wake lock" tip in the mean timeÂ
About wiping cache and data you shouldn't have to worry about that as flashing the tablet using Rockchip Batch tool (use restore button) erases everything.
2012/11/20
Thanks for the rom.
I noticed they also got Jelly Bean for u23gt, http://www.51cube.com/en/ProductShow.asp?ID=182&pageview=pro
Do they make the rom available? Thanks.
daniel.yap,
Cube is probably working on it, but I haven't seen anything released so far.
Be sure we'll publish it as soon as we see Android 4.1 Jelly Bean on the U23GTÂ
daniel.yap If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Android 4.1 JellyBean rooted firmware for Cube U23GT available:
Currently Online: sadako11
70 Guest(s)
Devices in use: Desktop (65), Phone (6)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
