[ ROM ] Cube U23GT rooted firmware (from official version 1.03 dated 2012/09/26)
S1eepy
Forum Posts: 17
2012/10/19 - 00:00
Yeah, after flashing it tablet booted to CWM, great work!!!
Thanks Received: 3170
2012/10/19 - 00:13
That's great.
Is CWM OK for all users to have or shall I make 2 firmwares versions: one with stock recovery and another with CWM ?
Are there special firmware setup instructions I need to include ?
S1eepy
Forum Posts: 17
2012/10/19 - 14:12
Not sure if someone needs stock recovery.
Imho, only instruction to get into cwm sould be added:
*power down
*hold VOL+ button and power button (approx 7 sec)
*release when logo flash
2012/10/19 - 14:45
Well, I tested CWM on my Cube MINI, it works OK, but the the internal storage comes unformated after the Android system has booted, as the regular recovery normally takes care of that on first boot.
So I had to manually format the Storage within Android system, can this be fixed in CWM ?
S1eepy
Forum Posts: 17
2012/10/19 - 15:43
It can't be fixed with cwm, and this is ok to format storage manually after first boot.
mikele79
2012/10/19 - 18:50
hi.I read in a forum u30gt that you can put the img file in the sd , start the tablet and start the update.i can do this?
S1eepy
Forum Posts: 17
2012/10/19 - 18:57
cwm recovery support fw files in .zip format only.
2012/10/19 - 18:59
It works on some Arnova tablets but I don't know about the Cube U23GT.
Moreover, this method should work if the new firmware has same layout as the firmware currently installed on the tablet, which isn't the case here as we have some different partitionning (increased space for /data partition). So I wouldn't recommend doing it as it could result in a tablet brick. This should be fixable without problem with Rockchip flasher.
neox
2012/10/23 - 23:31
Hello I just received my Cube and I would like to install this room but I don´t really know how to do it. I searched for some information but I couldn´t find any in thos forum. So I would really aprecciate any help.
Excuse my English I´m from Costa Rica and my English is a little rusty.
S1eepy
Forum Posts: 17
2012/10/26 - 18:15
@admin:
Could you recommend/provide build.prop for games compatibility and tweaks, please?
And which fingerprint should be ok for this tablet?
Thank you.
adrianus
2012/10/30 - 18:50
hi,, i have a new one u23gt bought in china by my friends causing it's cheap rather than same tab spec. in my country, for $100++.. but the bad news is china's word and it is very annoyed. I would try the new ROM .. Do you mind explain the steps?
Actually it is brand new one. so it is not rooted.
2012/10/30 - 20:41
I've just posted a new custom firmware based on latest Cube's UG23GT 1.04 update from today.
http://www.arctablet.com/blog/forum/cube-u23gt/cube-u23gt-rooted-firmware-from-official-version-1-04-dated-20121030/
Adrianus, to flash the firmware, you can find Rockchip flasher tool and some instructions here:
http://www.arctablet.com/blog/archos-tablet/flashing-your-rockchip-3066-based-tablet-rockchip-batch-tool-1-5/
Or you can go to vondroid.com, they provide a good tutorial:
http://vondroid.com/threads/sticky-tutorial-how-to-firmware-upgrade.334/
S1eepy
Forum Posts: 17
2012/10/30 - 21:00
Great news for new custom fw version, but there is a small changes in 1.04:
(google transaltion)
Fixed:
Optimization problem can not wake up dormant standby;
Optimize the the part machine flash machine failed.
ctradiomail
2012/11/07 - 05:05
hi, i'm new to this forum, just got my cube u23gt. I just want to clarify if its normal with this unit that when I press the power to put the tab to sleep & press again after about 20 secs, I wont be able to awaken it in one press of the button.  it takes 5 to 6 short & long press to turn it on & when it does, it boots like its been shut down.  but if I set  the leave wifi on to always & press the power button for the tab to sleep, I can re-awaken it even after more than 20 sec of sleep.  doesn't bother me much except that the batt. will drain coz of the wifi being constantly on.  I already tried upgrading the firmware to 1.04 w/c I got from the cube website (as advised by merimobiles) but the problem still persist.  Is this a defective unit?
spyder79
2012/11/17 - 03:18
Hi guys
1) how do i get into recovery mode ?
2) i keep pressing the Vol- n power button. no respond.
3) do i need to root it 1st ? how to ?
Currently Online: miami76
69 Guest(s)
Devices in use: Desktop (59), Phone (10), Tablet (1)
miami76
Cellarin
kuzin
Dag58
montolla
portvein
