Cube U20GT Android 4.1 JB rooted firmware (from official version 2.00 dated 2012/11/24)
Topic Rating: 5Topic Rating: 5Topic Rating: 5Topic Rating: 5Topic Rating: 5 Topic Rating: 5 (1 votes)
2012/11/24
15:13
Forum Posts: 3933
Thanks Received: 1269
Online
JMI Pulse 10
Cube has just released an Android 4.1 Jelly Bean update for the Cube U20GT.
[[** please register to see this link **]]    U20GT_Android4.1_V2.00_20121124.zip (2012/11/24)
Android 4.1 build: rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/20121108.105215:eng/release-keys
Linux Kernel: Linux version 3.0.8+ (root@ubuntu) (gcc version 4.4.3 (GCC) ) #505 SMP PREEMPT Thu Nov 22 23:18:14 PST 2012
This is a major upgrade to Android 4.1 Jelly Bean, Google Translation of Cube version history says this firmware changed the following:
Updated to Android 4.1 system;
aging game crashes to amend the part of the machine;
awakened not some machine screensavers.
Here is our custom rooted firmware version of the Android 4.1 JB based on official Cube version 2.00
Features:
- root with SuperSU version 0.96 (free version)
- writable /system partition
Rooted custom firmware for the CUBE U20GT: [[** please register to see this link **]]
Using [[** please register to see this link **]] version 1.5 to flash the firmware.
Please report any problem with this firmware, I can't verify if this custom firmware works properly as I don't own a Cube U20GT  to test it.
S1eepy, andorman, palos, rostis72
2012/11/24
15:27
S1eepy
Forum Posts: 17
Very fast and operative work, impressive!!!
The following users say thank you to S1eepy for this useful post:
palos
2012/11/24
23:09
benji
Cube U20GT
Hi, thanks for this very good work.
i have a little problem, i can't download the official firmware on cube site. can someone explain me how?
thanks
2012/11/25
12:23
S1eepy
Forum Posts: 17
@admin: Could you share stock 4.1 too? Thanks.
2012/11/25
12:39
Forum Posts: 3933
Online
JMI Pulse 10
I haven't kept it, I'll try to download it later.
2012/11/26
01:22
zcdroid
Cube U20GT
Thanks a lot, I have installed your custom rooted firmware and everything is fine. Thank you!
2012/11/27
15:00
felixarch
So far so good! txs a lot.
I've uninstall the 5 chinese apps that were still on the OS…  Can you tell me why you let them there ?  For chinese user i guess?
2012/11/28
00:36
raph07_08
I tried to flash my Cube U20GT with [[** please register to see this link **]] and this rooted firmware and impossible to flash (see screenshot below)
Anything I did wrong ?
00:42
Forum Posts: 3933
Online
JMI Pulse 10
Not really, it's probably a miss during the apps cleanup when building the custom firmware. This is be corrected in next firmware release.
2012/11/28
00:43
Forum Posts: 3933
Online
JMI Pulse 10
Was the square in green color when you started to flash the tablet ?
2012/11/28
00:46
raph07_08
the square of connected device ?
no it was in pink
2012/12/01
11:23
raph07_08
I finally succeeded in installing the firmware (I was not in download mode) !
The rooted rom works greats ! but the battery problem is still here (perhaps it's even worse).
When the battery is at 100%, If I activated wifi and launch an application ity takes about 4h30 to decrease from 100% to 45-40%
For me it's quite normal
But after that in less than 30 min it decreases from 45-40 to 15% !
Battery problem with cube u20gt ? calibration battery problem ? anyone else has this problem ?
Any idea what to do ?
Regards
2012/12/01
19:15
zcdroid
Cube U20GT
raph, I have the same battery problem too. with 4.0.4. and Jelly Bean
I have noticed that g-sensor fails with the update. When I´m working for a long with the Cube g-sensor stops to work. If I let the tablet take a rest g-sensor works again. Maybe is not a problem with the update but I hadn't this problem before to install the new firmware.
2012/12/01
19:25
raph07_08
zcdroid: I'm not sure to understand … .did you use the 4.1 rooted update too ?  you had not the problem before ?
I just bought the tablet but it seems I also had the problem with 4.0.4. perhaps it's worse with 4.1 rooted
I think I will try to calibrate the battery ? (but I don't know how)
2012/12/02
13:43
zcdroid
Cube U20GT
Yes, It is 4.1 rooted firmware, but I had also this problem before. My last firmware was 4.0.4 rooted from this page. I´ll try with another ROM and I´ll keep in updates.
I tought that was a cube problem but I had installed the two rooted firmwares from here. I had the same battery problem.
Let's see if I have the same problem with others ROMs.
Most Users Ever Online: 646
Currently Online: admin, globula_neagra, guadalupe_de, picketts, jmbox, Lumen2003, fr-fr, frizzycola, tommyv, Sascha Kaselofsky, Alban1, bilgili, Revelator, Brnky, valerio, erta1, pdduyst, Bsoft2007, 08-5-10, M.Moe, tichikawa, bazk123, Daichan, jays021, chidori, jhearrtot, sirdogg8u, chepito, flow2013, momoko, tivot, xadaya, ino13, worlmer, dudule, main3dtv, palata, matnl, cheva17, tann200, etech, grass121, ilusa, emsee, coldplay, michael02
265 Guest(s)
admin: 3933
globula_neagra: 2028
Guest Posters: 39
Members: 82722
Forums: 132
Topics: 2982
Newest Members: sko0on, engrpongs, togserefelo, Awasiahar, val1118, johnpopham
Moderators: HaroldG (117), globula_neagra (2028), exelletor (344)
Administrators: admin (3933)
