Rooted custom firmware based latest Android 4.1 Jelly Bean update Cube U19GT official firmware version 1.11Â (20121228)
Android build:Â rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/20121113.184202:eng/release-keys
Linux kernel build:Â Linux version 3.0.8+ (root@forise04) (gcc version 4.4.3 (GCC) ) #96 SMP PREEMPT Thu Dec 13 12:35:55 CST 2012
- root with latest SuperSU 0.99 (free version)
- writable /system partition
- increased space for application (/data partition) to 2 GB.
- included hackerskeyboard (a 5-row keyboard using full PC key layout)  as latest Cube update had regular non Chinese keyboard removed
Rooted custom firmware for the CUBE U19GT-W: kasty-cube_u19gt_w-41-111-rooted.zip
Using Rockchip Batch Tool version 1.5 to flash the firmware.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Cube U19GT to test it.
Firmware version 1.11 revision history from Cube (Chenglish by Google translate )
1. Updated to Android 4.1 system;Â
2. solve Aging crash problem;Â
3. enter the browser sometimes save bookmarks screen flicker;Â
4. enter the e-mail error phenomenon.
mgkkelis, bibi, MRU19GT, madmayser If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/12/30
Hey m8
I am new around here. Just wanted to say thanks.
Everything works fine for me until now. I didn't find any issues. Already used Play
Actually JB solved my issue with unstable wifi signal.
Good work. Thanks
The following users say thank you to mgkkelis for this useful post:
bibi
2012/12/29
Hi, After I updated with this file, I'm not able to use the keyboard? It defaults to speech recognition instead of typing. Any help would be appreciated. Also for wifi, I constantly get "obtaining IP..."
Hey m8 I am new around here. Just wanted to say thanks. Everything works fine for me until now. I didn't find any issues. Already used Play Actually JB solved my issue with unstable wifi signal. Good work. Thanks
2012/12/30
As been said the default keyboard was removed by cube so he was kind enough to add one for us.
Did you uninstall "Hackers Keyboard" ? If you did you are left without keyboard and you have to go through your pc browser to add one from play while you have the tablet connected to the pc.
Otherwise go to Settings -> Lenguage & Input -> Keyboard & Input Methods -> Default -> Setup
As for your wifi issue, I had the same one before flashing this rom. I was using stock 1.10
Good luck
2012/12/29
Good luck
hi thanks you for your response back. Everything is fine, except very weak wifi signal. Now that it's rooted, is there any software I can load that will help?
2013/01/24
Hello everibody.
I have a similar problem : no wifi signal. I think the trouble is hardware because it was ok two weeks ago.
Before sending back the tablet i would like to install the official version but the page is in chinese and I do not succeed to get the firmware .
Is there somebody who know how to get it ??
2013/05/28
Hi all
I tried to flash this rooted 1.11 but I did a mistake during flashing :
I selected Upgrade instead of Restore. So the flash finished with 1 error, but the tablet doesn't boot anymore (and I can't link it to my PC usb anymore too, there is no connection - windows can't detect it).
Is there a way to reset the tablet ?
74 Guest(s)
Devices in use: Desktop (67), Phone (7)
lilila3
Anatrop
antoniors021
wemiy54158
sidor
houssmen
