[ ROM ] Cube U19GT rooted firmware (from official version 1.09 dated 2012/08/29)
Thanks Received: 3169
2012/10/18 - 09:27
fjndias said
Hi Guys ,
I have a Cube U19GT and i tried to upgrade the firmware via Rockchip Batch tool 1.5v , i tried the newest firmware from Cube v1.10 windows 8 metro , when upgrading says Prepare IDB Fail , then the icon goes red , now i cant boot the tablet , the computer recognizes it but cant boot it up , screen stays black . Any ideas ?
Thanks for now
The Cube tablets sometimes ship with a bad quality USB cable that causes errors when transmitting data with the computer. I suggest that you change the USB cable and use one you know is reliable and flash again, either Cube original firmware for a test or our custom firmware.
virush
bibi
2012/10/18 - 09:50
Try to use another usb port.
fjndias
2012/10/18 - 21:39
Hi Bibi , i just tried that worked perfectly now , i have successfully updated , thanks everyone for the help. :)
2012/10/18 - 22:24
Sounds good to hear. What was the problem, cable, USB port, something else ?
fjndias
2012/10/18 - 23:19
Well i had an usb extension cable from the back of my case to the front of my desk ,so i was trying trough this cable , what i did i plugged the tablet usb cable directly to a different usb port on the back o my case and it worked .
The Windows 8 Merto firmware its quite cool . :)
2012/10/18 - 23:55
I have just built a custom firmware update, based on official Cube's U19GT-W update version 1.10 dated 2012/09/18
My custom firmware update has the same features as the one in post #1, it's just an update from v1.09 to v1.10.
Please test it and let me know, I'll update post #1 if the firmware is confirmed to work.
Download: kasty-cube_u19gt_w-40-110-rooted.zip
Thanks.
virush, bibi
fjndias
2012/10/21 - 23:49
Thanks.
I would like to try , should o install in the same way as the original Cube firmware using RBTv1.5 ?
Do you guys now if the update for the 4.1 Jellybean its available for this tablet ?
bibi
2012/10/22 - 16:46
Thanks.
Why is so big this update? Oficial update has 319 mb and this custom firmware has 496 MB.
2012/10/22 - 16:47
We have modified the partition layout and the system image part is a bit bigger than stock, when compressed in a zip file it doesn't make much difference.
mack123
Forum Posts: 15
2012/10/25 - 01:04
flashed 1.10 firmware and lost all location services, returned to 1.09 and still cant get a location.This was working fine on 1.09 but since flashing your 1.10 i cant get a location on any firmware official or custom . cant download anything from play store, getting921 error.
2012/10/25 - 09:20
Are you flashing the firmware using Rockchip Batch Tool 1.5 ? Are you using the Restore button, not Upgrade ?
mack123
Forum Posts: 15
2012/10/25 - 09:50
Hi , yeah all of the above but still no location ,will try factory default 1.04 and see if this makes any difference. I'll let you know how I go later
no fix, cant access goole account  through play store to buy apps,cant download apps cant get a location. Do not flash this firmware it just causes major problems, great
thanks
mack123
Forum Posts: 15
2012/10/25 - 23:07
have now tried cubes new 1.10 android ui and still no change. gone from working perfectly , flashed admins firmware and now have no play store no location service. thanks heaps
2012/10/25 - 23:13
You're the first to report this kind of problems, sorry about that.
I'll see if I can advise anything, but restoring the stock firmware should get you the device as you got it originally, using Restore button in Rockchip Batch tool makes sure the system is erased before flashing.
mack123
Forum Posts: 15
2012/10/26 - 00:59
Any help would be much appreciated
Thank you
114 Guest(s)
Devices in use: Desktop (101), Phone (13)
uzair
aozdnazodjazod
mgmrda
mobilstore
sandertb
3187
Topics: 6030
Members: 261443
