[ ROM ] Cube U19GT rooted firmware (from official version 1.09 dated 2012/08/29)
Thanks Received: 3169
2012/10/01 - 20:20
Rooted custom firmware based on Cube U19GT official firmware version 1.09 (20120829)
Features:
- root with SuperSU 0.96 (free version)
- writable /system partition
- increased space for application (/data partition) to 1.5 Gb.
Rooted custom firmware for the CUBE U19GT-W: kasty-cube_u19gt_w-40-109-rooted2.zip
Using Rockchip Batch Tool version 1.5 to flash the firmware.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Cube U19GT to test it.
Update 2012/10/04: fixed boot issue.
mack123, bibi, MRU19GT, noom9999, victorgz
MRU19GT
2012/10/03 - 19:28
Just tried this method, and resulted in "restore done succes (1) fail (0)", but when the tablet (U19GT) reboots, it stops rebooting when the 2sunflowers show up. (no black screen, just the sunflowers. )
My computer does recognise the tablet (new hardware found).
Any solution?
for those who don't know how to get in recovery/flashing mode: push volume down, than insert usb cable
2012/10/03 - 19:45
Since I don't have a U19GT to test it myself and noone has yet confirmed my firmware works, it may be a problem on my custom firmware.
Can you flash Cube's stock firmware and tell me if it works fine ? then I'll double check if there is anything wrong with my firmware.
Thank you.
MRU19GT
2012/10/03 - 19:52
i did a restore of an updated version of the rom i found online (v1.10) (http://ge.tt/86Kop3O/v/0?c), and that works fine (offcourse, not rooted, no writable system partition and chinese apps.)
mack123
Forum Posts: 15
2012/10/04 - 07:16
hi, same here stuck on sunflowers, cube 1.09 stock firmware works fine
2012/10/04 - 19:05
I found a possible issue that prevent the tablet from booting (problem in the system partition size in my custom firmware).
I have fixed that and updated the rooted firmware link in the first post. kasty-cube_u19gt_w-40-109-rooted2.zip
It should hopefully boot properly now, please let me know.
bibi
MRU19GT
2012/10/04 - 19:41
 it doesn't stuck anymore on the sunflowers, it seems it's working fine. will do more tests tomorrow. Thanks a lot!
mack123
Forum Posts: 15
2012/10/05 - 07:23
hi, the new firmware seems t o work fine, extra room for a few more apps is very handy. Thank you very much just what i've been looking for.
saaro
2012/10/06 - 02:28
I can confirm this is working. Thanks!
coulwave
2012/10/11 - 19:59
Hi Everybody,
I receive cube U19GT since 2days, everything works very well, except that I have problem with camera.
 When I open camera I see image and I have message error and I can't use it. After that I have another message " to use camera you have to mount Flash card" and application stop.
I Install firmware but I have always the same problem. Does anyone could help me?
PS: Sorry for my bad english
2012/10/11 - 23:40
Well, if the problem happens also with the stock firmware, it's probably a bug. Let's hope Cube brings a fix in a future update.
Still, formatting the local storage may help to fix the problem, check in Factory data reset in Backup & Reset menu, or in Storage menu if you can Erase storage then Mount it.
bibi
2012/10/12 - 21:03
I try to install this firmware, but no work. I install oficial firmware v1.10. It's ok, but no root and many chinese app.
Thanks.
2012/10/14 - 20:09
Thanks.
Thanks for your message. I didn't know about the 1.10 update, I'll rebuild my custom firmware with it.
Still, our 1.09 rooted firmware was already confirmed to work by other forum members (see post #7, #8 and #9), can you be more specific about what's not working for you ?
bibi
2012/10/15 - 10:16
Thanks for answer.
I read the posts  (7, 8 and 9). But me not work; upgrade fail. Then I try v1.10 and it's work. Last firmware is U19GT-W_v1.10_Win8_20120918.zip. The last firmware has metro UI interface. I dont like it and I try another custom firmware. I use the same method to install firmware (RKBatchTool).
fjndias
2012/10/18 - 01:57
Hi Guys ,
I have a Cube U19GT and i tried to upgrade the firmware via Rockchip Batch tool 1.5v , i tried the newest firmware from Cube v1.10 windows 8 metro , when upgrading says Prepare IDB Fail , then the icon goes red , now i cant boot the tablet , the computer recognizes it but cant boot it up , screen stays black . Any ideas ?
Thanks for now
100 Guest(s)
2 Guest(s)
Devices in use: Desktop (92), Phone (8)
ericzx
rallador de queso
5taxerror
Bacucco
ARARAT
DjDare
Topics: 6030
Members: 261708
