2013/03/06
Found it -
The correct firmware version for the U18GTS is V1.03-20130228
I found it here http://www.51cube.net/ch/DownShow.asp?ID=139
Ollie
One should be done in the coming days.
2013/05/28
Pls. help. U18GT w/sn.U18GTS8GBW13157210662, what firmware should I use to restore/re-install? Only used it for a day then it became corrupted (dead android with a red exclamation mark) and then the unit no longer charged afterwards. The charger is not the problem because it can charge other unit. I can already detect the unit using the RKTool but can't continue using this firmware U18GT-S_V1.04_20130307 that I downloaded.Â
2013/03/06
If yours is a cube u18gt dual rk3066 then use V1.03-20130228
I found it here http://www.51cube.net/ch/DownShow.asp?ID=139 and it workeds for me
Ollie
Currently Online: chloeting2701
74 Guest(s)
Devices in use: Desktop (57), Phone (18)
kevbez
xxxdddd
xxxddd
Kaydc__
jessicapeterson
Riki111
