[ ROM ] Cube U18GT2 Android 4.1 JB rooted firmware (version 1.06 dated 2013/01/06)
2013/01/07 - 12:27
Cube has released a new Android 4.1 Jelly Bean update for the Cube U18GT2, it looks like a re-release as version number is identical to previous 1.06 but now contains a new kernel.
Cube U18GT2 official firmware version 1.06    U18GT2_V1.06_20130106.zip (2013/01/06)
Android 4.1 build: rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/20121122.205441:eng/release-keys
Linux Kernel: Linux version 3.0.8+ (eyes#0001@lzhp-System-Product-Name) (gcc version 4.4.3 (GCC) ) #308 SMP PREEMPT 2013-01-05 17:42:08 6:00
Google Translation of Cube version history says this firmware changed the following:
Update QQ and repeatedly prompted automatically upgrade;
correction WIFI disconnect can not automatically connect.
Here is our custom rooted firmware version of the Android 4.1 JB based on official Cube version 1.06
Features:
- root with latest SuperSU version 0.99 (free version)
- writable /system partition
- increased space for application (/data partition) to 2 GB
- included hackerskeyboard (a 5-row keyboard using full PC key layout)  as latest Cube update had regular non Chinese keyboard removed
Rooted custom firmware for the CUBE U18GT2: kasty-cube_u18gt2-41-106_rerelease-rooted.zip
Using Rockchip Batch Tool version 1.5 to flash the firmware.
Please report any problem with this firmware, I can't verify if this custom firmware works properly as I don't own a Cube U18GT2  to test it.
pejerrey, Nevorna
ultranic
2013/01/09 - 22:51
I tried it and I found this firmware has a lower CPU clock, around 1400 MHz.
I prefer the 14/12 version.
EDIT: Sorry, I just found out the last version had also a maximum clock of ~1400 MHz. My bad.
andyhoney
Forum Posts: 23
Thanks Received: 4
2013/01/23 - 22:28
tried it, seems ok antutu score 11608.  1416mhz
U18GT2 - WHITE (DUAL CORE RK33 Running custom firmware)
U18GT-H BLACK (SINGLE CORE RK29 stock Standard)
tomoto
2013/02/07 - 20:16
Dears, seems i have some troubles with root access on JellyBean 4.1.1 (some programs works ok with root, but GameCIH program not working). Is it possible to upload formwave with rooted 4.0.1 android or any other IC version? Thanks a lot...
davidh7112
2013/02/24 - 05:57
Laugh
Hello, new here. I just registered here for more information on the cube u18gt2. I just purchased one and am getting root. Thank you to all who have posted info about these tablets it seems that relevant info is lacking elsewhere online. I have found a ton of useful stuff here and just want to thank the contributors. any news on firmware/Roms updates are also appreciated.
iisollie
2013/03/18 - 21:02
I upgraded my Cube 18GT elite with U18GT2_V1.06_20130106.zip (2013/01/06) firmware.
I get "success" message however there is a problem. After the flash the screen isn't working - if I connect to laptop I get the screen with Turn on USB but I get no response from the screen.
If I turn on when not connected to laptop I just see the logo for a second and then its gone .. nothing further happens.
Can someone help please
Ollie
iisollie
2013/03/21 - 09:24
problem solved -
The correct firmware version for the U18GTS is  V1.03-20130228
I found it here http://www.51cube.net/ch/DownShow.asp?ID=139
Ollie
Nevorna
Forum Posts: 17
2013/04/28 - 09:45
I had the same problem, that my touchscreen stopped working. But after I reinstall the right firmware, it still isn't working. What might I have done wrong?
Thanks Received: 268
2013/04/28 - 14:39
did you used the RESTORE option when you flashed the firmware ?
Nevorna
Forum Posts: 17
2013/04/29 - 08:34
Yes, I did, and I also tried the update-option once to see the difference, but it didn't help. It is strange that even in Recovery-mode, the touchscreen isn't working. Where does the Recovery-mode normally get the drivers from?
2013/04/29 - 09:29
from the kernel
Nevorna
Forum Posts: 17
2013/04/29 - 09:55
Thanks for your help.
That would mean that if I would get the right kernel, it might fix the problem. Would it help to only flash the kernel that is included in the u18gt-s firmware? I still suspect a newer firmware version has a newer kernel with other touchscreen drivers, if it is a driver-problem. Only, no newer firmware version has officially been released.. Hm..
158 Guest(s)
Devices in use: Desktop (152), Phone (6)
jacksonrid
usdown
ibob64
kawi
