Cube has just released an Android 4.1 Jelly Bean update for the Cube U18GT2.
Cube U18GT2 official firmware version 1.03  U18GT2_V1.03_4.1_20121124.zip (2012/11/24)Â
Android 4.1 build:Â rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/20121122.205441:eng/release-keys
Linux Kernel:Â Linux version 3.0.8+ (eyes#0001@eyes) (gcc version 4.4.3 (GCC) ) #290 SMP PREEMPT 2012-11-21 17:13:52 3:47
This is a major upgrade to Android 4.1 Jelly Bean, Google Translation of Cube version history says this firmware changed the following:
Updated to Android 4.1 system;
aging game crashes to amend the part of the machine;
awakened not some machine screensavers.
Here is our custom rooted firmware version of the Android 4.1 JB based on official Cube version 1.03
Features:
- root with SuperSU version 0.96 (free version)
- writable /system partition
Rooted custom firmware for the CUBE U18GT2: kasty-cube_u18gt2-41-103-rooted.zip
Using Rockchip Batch Tool version 1.5 to flash the firmware.
Please report any problem with this firmware, I can't verify if this custom firmware works properly as I don't own a Cube U18GT2 Â to test it.
That's strange, I check the build.prop and it's configured for English language and region:
ro.product.locale.language=en
ro.product.locale.region=US
I'll see if there are other settings...
2012/12/04
yup you have english, but when you go to type text you get no keyboard , so basicly cant enter wifi details or anything else
under keyboard and input methods it has default, but the default seems to be none.
on apps running, it has input devices, which is blank with nothing set.
U18GT2 - WHITE (DUAL CORE RK33 Running custom firmware)
U18GT-H BLACK (SINGLE CORE RK29 stock Standard)
2012/12/01
andyhoney said
yup you have english, but when you go to type text you get no keyboard, so basicly cant enter wifi details or anything else
Easy, download a keyboard apk, conect via USB copy the file to the tablet, run apk installer and install the new keyboard
2012/12/04
Thanks, ill do that, its not normal for the keyboard to be missing right ?
if this gets updated i would love to download it again, the chinese on the original tablet is annoying, and the bloatware as well
2012/12/04
Thanks to all for the help.
Rooted Install custom firmware version for the CUBE U18GT2.
It works fine has all languages ​​but not keyboard
Install go keyboard app and works perfect.
I will continue testing with this firmware.
A question I have a white cube u18gt2, charging can be performed only by usb or wall charger?
Sorry for my English, I speak Spanish ok.
Horacio.
cube U18gt2
2012/12/13
HI,
I just got one set of U18GT2 too. Its the dual core Rock chip 3066 version.
Antutu test done - 1600Hz CPU. scored quite high bench marking.
But I don't under stand why the charging seem to flip flop out and in. Charge and disconnected than charge again....continuously on off... Than I do a search online and found one video on you tube concerning the charger problem. I follow it. Cut of the rubber front of the charger. One small extended rubber head. And after doing some adjustment, the charger become stable and properly connect and able to start charging consistently now.
In order to use USB charging it can be done. BUT its from USB(PC or other 5V DC source) power out but still connect to the charging socket. The input will have to be connect to the unit's charger socket. I also found that the included charger have 5 Volts but very small ampere.(current). As the set's battery is around 3000AH. It would certainly take a long while to charge up the battery.
Is there a new firmware for this Cube u18gt2 (rockchip dual core set)?
Is the cube U18gt's firmware V1.4 and v1.5 compatible to be sue for u18gt2 ?
Any help would be very much appreciated. Also although can access Play market - its not full market and can't find whatsapps and a few other apps.
Any way for us to access real full play market?
http://moneycow.biz
2012/12/04
Desmond said
HI,
 Yeh its a good chipset.
yeh thankfully my charger didnt have that issue.
 my son has the black u18gt2 and he says it takes ages to charge via usb.
this is the latest firmware, its just missing a keyboard, which can be solved by downloading a keyboard.apk file, and then its fine, ive had it on mine for about 2 weeks and it runs like a dream.
unsure i know my son has the elite black u18gt-h (still a elite dual core) and its got a whole diff firmware, but it comes with no Chinese bloatware, seem to run exactly as fast as mine, just diff UI look etc.
 dont know i have the same issue, just know the rest from experience of having 2 of the same cube 1 white, 1 black.
pejerrey If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
85 Guest(s)
Devices in use: Desktop (73), Phone (12)
lbalexa001
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
