2013/11/29
I have a tablet Cube U51GT-C4 TALK7X4 Quad Core. The tablet is very nice and good performances. Its characteristics:
Model | Cube U51GT-C4 TALK7X4 Quad Core |
Screen Information | 7 Inch IPS 5 Point touch Capacitive Screen |
Resolution | 1024x600 pixels |
CPU | MTK8382,Quad Core,1.3GHz (MTK8312,Dual Core,1.3GHz For TALK7X Dual Core) |
GPU | Mali-400MP |
Operation System | Android 4.2 |
RAM | 1GB |
ROM(Storage) | 8GBÂ (4GB ROM For TALK7X Dual Core) |
Extend Card | Support TF card up to 32GB extended |
Camera | Rear Camera:2.0MP |
Front Camera:0.3MP | |
Bluetooth | YES |
GPS | YES |
HDMI | N/A |
WIFi | Yes, 802.11 b/g/n |
2G GSM(Phone Call) | GSM 850/900/1800/1900MHz |
3G | WCDMA 2100MHz |
Video | AVI/MOV/MP4/RMVB/FLV/MKV… |
Music | MP3/WMA/WAV/APE/AAC/FLAC/OGG |
Ebook | UMD,TXT,PDF,HTML,RTF,FB2… |
Other Applications | File Manager,OfficeSuite,Google Search, Browser,Gallery,Clock,Calculator, Calendar,iReader,Email etc |
Language | Multi- language support |
Connectivity | 2 x SIM Slot(Standard+Micro) |
1 x Micro USB port | |
1 x TF card slot | |
1 x Earphone port | |
Battery | 3000mAh Li-Polymer Battery (2700mAh Li-Polymer Battery For TALK7X Dual Core) |
Work Time | Up to 6 hours |
Power Device | Adapter Input 100/240V Output 5V-2A Micro USB |
Product Size | 191.2x106.5x9.9mm (191x110.9x10.1mm For TALK7X Dual Core) |
I would like to change the recovery for TWPR or CWM.
Anyone know where or how to change it?
some manually?
thank you
P. D. Sorry for my English, is regular.
2013/11/29
Root with Framaroot, a one-click apk to root.
http://forum.xda-developers.com/apps/framaroot/root-framaroot-one-click-apk-to-root-t2130276
2013/11/29
The tablet must be root. First install one of the two recoverys:
CWM http://yadi.sk/d/TdwELGuLPRyrZ
TWRP http://yadi.sk/d/4OkFM7BnPRSrJ
After that if you tried to get into recovery (Vol + and power) does not enter in recovery installed. To enter the recovery installed you have to go through the droid mtk tools
http://www.mediafire.com/download/6z...ols+v2.5.3.zip
We must have the debug mode enabled. Open the program and give it to root ... this only serves to give permission to the program. Pass the box the bottom yellow to green. Eye on the tablet can ask confirmation. We give reboot and restart and recovery in our recovery.
Within the recovery install the patch that belongs to the chosen recovery.
CWM http://yadi.sk/d/9CDSgpeDPS3yM
TWRP http://yadi.sk/d/aQhhLcVoPS4da
and this should let us in with a combination of buttons on the recovery that we have installed.
Although I could not test the idea, taken from post
2014/08/10
I just got the above tablet 2 days ago.Â
After installiing some apps. and perform a root, device crashed, hanging in start-up screen forever.
Unfortunately I didn't yet install CWM and/or TWRP recovery.
I manage to enter the device recovery (3e) but from there it won't let me install any zip file, either new/factory firmware or other recovery.
Tried both using external SD card and ADB (using ADB terminal). Both cases device starts loading then aborts installation, no fault code or what so ever.
Tried to install drivers using SP tool and all the other options mentioned in former post, no success.Â
No luck with installing Media Tek USB Vcom drivers, although tried to follow the instructions found in XDA.
Device is not recognized by computer (W7).
I suppose it is all because I did not activate the USB debugging, but of course, since I can't log into system , I can't change those settings.
Any idea regarding how to restore the brick, or should I approach the customer service asking for replacement?
Thanks in advance
Shemer.
I do not recommend installing root
For safety reasons
No bad browser, new browser Vivaldi http://vivaldi.browser.ideaprog.download/
73 Guest(s)
Devices in use: Desktop (67), Phone (6)
lilila3
Anatrop
antoniors021
wemiy54158
sidor
houssmen
