2013/11/06
So I've been using Oma's n80 rom for quite a while now....ever since ver4.3 came out. Thing is sometimes it freezes like hell and there is no helping it. If I listen to music is continues to play but the screen doesnt react for like 15-20 seconds. Is there any way to fix this problem. And lastly is kitkat rom ever comming for  vido n80 rk3188? I saw there is already one for pipo. Hope I posted in the right place and didnt mess up 🙂Â
Uff, what rom was it? What is the wifi chip?
2013/11/06
Uff, what rom was it? What is the wifi chip?- Oma -
The rom from this post http://www.arctablet.com/blog/forum/yuandao-vido-tablets/vido-n80rk-by-oma-rocks-jb-4-2-2-edition-v3-4/
as for the wifi chip i dunno how to indentify it. CPU is RockChip RK3188 if this is any help.
Ok, build v3.4.
Sometimes one tested some "useful" app which generates such problems. Not directly and not one event alone ...
When mismatches are only on the data patition a factory reset will help.
If the system is corrupted somehow a re-flash of the complete build will help.
Open a terminal and type:
su
dmesg > /mnt/sdcard/dmesg.txt
Upload the log. I will check the wifi chip.
The log should now be on you sdcard. Upload it.
2013/11/06
I dont know how to upload text file so here is direct copy paste, pls tell me there is hope
<4>[17130.807881] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[17130.807974] =======================================================
<4>[17130.808070] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 3.30.WFD) init.
<4>[17130.808191] wifi_activate_usb
<6>[17130.808258] rk29sdk_wifi_power: 1
<6>[17131.085127] wifi turn on power
<4>[17131.195899] bFWReady == _FALSE call reset 8051...
<6>[17131.322392] usbcore: registered new interface driver rtl8188eu
<4>[17131.671474] ==> rtl8188e_iol_efuse_patch
No build for RTL8188 wifi available, yet. Sorry.
We are working on a generic CM11 build.
Re-flash the rom incl. eraseIDB. When you have set-up your usual environment, do a nandroid back-up via CWM.
2013/09/25
I have a Yuandao N80RK as well as the OMA rom also didn't work that well. WiFi did work but it just keep slowing down. rknand_buffer was sucking up 5-7% of CPU. Eventually, I burned the official ROM and then rooted it and removed some of the Chinese apps. It's working much better now. Battery life sucks but what do you expect for $124!
Latest stage of CM11 code is not stable again.
Check out the Omni build: http://crewrktablets.arctablet.com/?p=3555
146 Guest(s)
Devices in use: Desktop (141), Phone (5)
