2014/11/29
Hello mates, yesterday i buyed a venstar 4050 rk3188 tablet.Â
It works very Smooth without any bug. The screen is poor but the tablet only cost about 90usd.Â
My question its about firmware or custom roms installation because i always custom my devices with non stock rom but i dont find any kind of rom from venstar tablet. Â Then i search for rk3188 roms and all are from tv rk3188 devices.Â
Its there any kind of generix roms form rk3188 tablet?Â
And where i can find stock rom, probably i need it to fix a posible brick if i try a lot of roms.Â
Thanks and RegardsÂ
Pls provide a dmesg log.
2014/11/29
<6>[ Â Â 0.000000] Initializing cgroup subsys cpu
<5>[ Â Â 0.000000] Linux version 3.0.36+ (bx@bx-Desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #456 SMP PREEMPT Wed Jul 9 09:38:13 CST 2014
<4>[ Â Â 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
<4>[ Â Â 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[ Â Â 0.000000] Machine: RK30board
<4>[ Â Â 0.000000] ddr size = 1024 M, set ion_reserve_size size to 125829120
<6>[ Â Â 0.000000] memory reserve: Memory(base:0x98800000 size:120M) reserved for <ion>
<6>[ Â Â 0.000000] memory reserve: Memory(base:0x98000000 size:8M) reserved for <fb0 buf>
<6>[ Â Â 0.000000] memory reserve: Memory(base:0x97a00000 size:6M) reserved for <camera_ipp_mem>
<6>[ Â Â 0.000000] memory reserve: Total reserved 134M
<4>[ Â Â 0.000000] Memory policy: ECC disabled, Data cache writeback
<6>[ Â Â 0.000000] bootconsole [earlycon0] enabled
<4>[ Â Â 0.000000] CPU SRAM: copied sram code from c0ee6000 to fef00100 - fef021a8
<4>[ Â Â 0.000000] CPU SRAM: copied sram data from c0ee80a8 to fef021a8 - fef02920
<4>[   0.000000] sram_log:    4q ?&   :   4q ?)   !?, # 0q   *!  ! 3q  @    3qÂ
<4>[ Â Â 0.000000] CLKDATA_MSG: pll_flag = 0x03
<3>[ Â Â 0.000000] cpll auto set rate error
<3>[ Â Â 0.000000] CLKDATA_ERR: can't get a available nume and deno
<3>[ Â Â 0.000000] CLKDATA_ERR: clk_frac_div can't get rate=48000000,uart0_frac_div
<6>[ Â Â 0.000000] L310 cache controller enabled
<6>[ Â Â 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
<4>[ Â Â 0.000000] DDR DEBUG: version 1.00 20131106Â
<4>[ Â Â 0.000000] DDR DEBUG: DDR3 Device
<4>[ Â Â 0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ Â Â 0.000000] DDR DEBUG: init success!!! freq=300MHz
<4>[ Â Â 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x3, DGSL=1 extra clock, DGPS=90
<4>[ Â Â 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=1 extra clock, DGPS=90
<4>[ Â Â 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=0 extra clock, DGPS=360
<4>[ Â Â 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ Â Â 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
<4>[ Â Â 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ Â Â 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200)
<7>[ Â Â 0.000000] On node 0 totalpages: 227840
<7>[ Â Â 0.000000] free_area_init_node: node 0, pgdat c0ee3d60, node_mem_map c2170000
<7>[ Â Â 0.000000] Â Normal zone: 976 pages used for memmap
<7>[ Â Â 0.000000] Â Normal zone: 0 pages reserved
<7>[ Â Â 0.000000] Â Normal zone: 123952 pages, LIFO batch:31
<7>[ Â Â 0.000000] Â HighMem zone: 1072 pages used for memmap
<7>[ Â Â 0.000000] Â HighMem zone: 101840 pages, LIFO batch:31
<6>[ Â Â 0.000000] PERCPU: Embedded 7 pages/cpu @c2979000 s7040 r8192 d13440 u32768
<7>[ Â Â 0.000000] pcpu-alloc: s7040 r8192 d13440 u32768 alloc=8*4096
<7>[ Â Â 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3Â
<4>[ Â Â 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Â Total pages: 225792
<5>[ Â Â 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00170000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x0000c000@0x00004000(kernel),0x00008000@0x00010000(boot),0x00010000@0x00018000(recovery),0x00020000@0x00028000(backup),0x00040000@0x00048000(cache),0x001FE000@0x00088000(userdata),0x00002000@0x00286000(metadata),0x00002000@0x00288000(kpanic),0x00180000@0x0028a000(system),-@0x0040a000(user) bootver=2013-12-27#2.10 firmware_ver=4.4.2
<6>[ Â Â 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ Â Â 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ Â Â 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ Â Â 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ Â Â 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
<6>[ Â Â 0.000000] Memory: 890MB = 890MB total
<5>[ Â Â 0.000000] Memory: 874912k/874912k available, 173664k reserved, 411648K highmem
<5>[ Â Â 0.000000] Virtual kernel memory layout:
<5>[   0.000000]   vector  : 0xffff0000 - 0xffff1000  (  4 kB)
<5>[   0.000000]   fixmap  : 0xfff00000 - 0xfffe0000  ( 896 kB)
<5>[ Â Â 0.000000] Â Â DMA Â Â : 0xff600000 - 0xffe00000 Â ( Â 8 MB)
<5>[ Â Â 0.000000] Â Â vmalloc : 0xdf000000 - 0xfe800000 Â ( 504 MB)
<5>[   0.000000]   lowmem  : 0xc0000000 - 0xde800000  ( 488 MB)
<5>[   0.000000]   pkmap  : 0xbfe00000 - 0xc0000000  (  2 MB)
<5>[ Â Â 0.000000] Â Â modules : 0xbf000000 - 0xbfe00000 Â ( Â 14 MB)
<5>[ Â Â 0.000000] Â Â Â .init : 0xc0408000 - 0xc06a3000 Â (2668 kB)
<5>[ Â Â 0.000000] Â Â Â .text : 0xc06a3000 - 0xc0e39e80 Â (7772 kB)
<5>[ Â Â 0.000000] Â Â Â .data : 0xc0e3a000 - 0xc0ee5bc8 Â ( 687 kB)
<5>[ Â Â 0.000000] Â Â Â Â .bss : 0xc0ee9024 - 0xc199a488 Â (10950 kB)
<6>[ Â Â 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ Â Â 0.000000] Preemptible hierarchical RCU implementation.
<6>[ Â Â 0.000000] NR_IRQS:352
<4>[ Â Â 0.000000] rk30_gpio_init: 128 gpio irqs in 4 banks
<6>[ Â Â 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
<4>[ Â Â 0.000000] rk_timer: version 1.3
<6>[ Â Â 0.003721] Calibrating delay loop (skipped) preset value.. 1631.46 BogoMIPS (lpj=8157341)
<6>[ Â Â 0.012812] pid_max: default: 32768 minimum: 301
<6>[ Â Â 0.018042] Security Framework initialized
<6>[ Â Â 0.022588] SELinux: Â Initializing.
<7>[ Â Â 0.026492] SELinux: Â Starting in permissive mode
<6>[ Â Â 0.026558] Mount-cache hash table entries: 512
<6>[ Â Â 0.032090] Initializing cgroup subsys debug
<6>[ Â Â 0.036826] Initializing cgroup subsys cpuacct
<6>[ Â Â 0.041773] Initializing cgroup subsys memory
<6>[ Â Â 0.046619] Initializing cgroup subsys freezer
<6>[ Â Â 0.051567] CPU: Testing write buffer coherency: ok
<4>[ Â Â 0.137717] CPU1: Booted secondary processor
<4>[ Â Â 0.177708] CPU2: Booted secondary processor
<4>[ Â Â 0.217707] CPU3: Booted secondary processor
<6>[ Â Â 0.217741] Brought up 4 CPUs
<6>[ Â Â 0.235266] SMP: Total of 4 processors activated (6525.87 BogoMIPS).
<6>[ Â Â 0.242631] devtmpfs: initialized
<6>[ Â Â 0.252174] NET: Registered protocol family 16
<6>[ Â Â 0.257212] last_log: 0xde100000 map to 0xdf004000 and copy to 0xc0eed180 (version 2.1)
<4>[ Â Â 0.281066] DVFS MSG: AVS Value(index=0): 123 123 123 122 123 123 123 123 123 123Â
<6>[ Â Â 0.300096] warning:lcdc0 not add to system!
<6>[ Â Â 0.304891] lcdc1 is used as primary display device controller!
<6>[ Â Â 0.411701] rk29sdk_wifi_bt_gpio_control_init: init finished
<6>[ Â Â 0.419334] console [ttyFIQ0] enabled, bootconsole disabled
<6>[ Â Â 0.428485] Registered FIQ tty driver de035cc0
<6>[ Â Â 0.429009] Loaded driver for PL330 DMAC-1 rk29-pl330
<6>[ Â Â 0.429052] DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
<6>[ Â Â 0.429232] Loaded driver for PL330 DMAC-2 rk29-pl330
<6>[ Â Â 0.429274] DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
<6>[ Â Â 0.461158] bio: create slab <bio-0> at 0
<5>[ Â Â 0.465566] SCSI subsystem initialized
<6>[ Â Â 0.465785] usbcore: registered new interface driver usbfs
<6>[ Â Â 0.465897] usbcore: registered new interface driver hub
<6>[ Â Â 0.480139] usbcore: registered new device driver usb
<6>[ Â Â 0.480531] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
<6>[ Â Â 0.480853] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
<6>[ Â Â 0.481049] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
<6>[ Â Â 0.481181] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
<6>[ Â Â 0.481362] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
<6>[ Â Â 0.511721] rk30-adc rk30-adc: rk30 adc: driver initialized
<4>[   0.684083] first_batt_value is  4162Â
<6>[ Â Â 0.687866] rk30_adc_battery: driver initialized
<4>[ Â Â 0.692693] timed-gpio: probe of timed-gpio failed with error -22
<6>[ Â Â 0.698906] Advanced Linux Sound Architecture Driver Version 1.0.24.
<6>[ Â Â 0.705718] Bluetooth: Core ver 2.16
<6>[ Â Â 0.709409] NET: Registered protocol family 31
<6>[ Â Â 0.713887] Bluetooth: HCI device and connection manager initialized
<6>[ Â Â 0.720283] Bluetooth: HCI socket layer initialized
<6>[ Â Â 0.725195] Bluetooth: L2CAP socket layer initialized
<6>[ Â Â 0.730298] Bluetooth: SCO socket layer initialized
<6>[ Â Â 0.735398] cfg80211: Calling CRDA to update world regulatory domain
<4>[ Â Â 0.742638] rk fb probe ok!
<4>[ Â Â 0.749398] act8931_set_init,line=21
<4>[ Â Â 0.749432] act8931_set_init:g_pmic_type=7
<4>[   0.751364] act8931_set_init  act_dcdc1 =3200000mV end
<4>[   0.753240] act8931_set_init  act_dcdc2 =1500000mV end
<4>[   0.755117] act8931_set_init  act_ldo1 =2800000mV end
<4>[   0.756891] act8931_set_init  act_ldo2 =1800000mV end
<4>[   0.758034] act8931_set_init  act_ldo3 =3000000mV end
<4>[ Â Â 0.758074] act8931_set_init,line=57 END
<3>[ Â Â 0.786631] i2c i2c-1: No ack, Maybe slave(addr: 0x5a) not exist or abnormal power-on, retry 2...
<3>[ Â Â 0.786933] i2c i2c-1: No ack, Maybe slave(addr: 0x5a) not exist or abnormal power-on, retry 1...
<3>[ Â Â 0.787229] i2c i2c-1: No ack, Maybe slave(addr: 0x5a) not exist or abnormal power-on, retry 0...
<4>[ Â Â 0.787293] The device is not act8846Â
<4>[ Â Â 0.787351] i2c-core: driver [act8846] using legacy suspend method
<4>[ Â Â 0.787397] i2c-core: driver [act8846] using legacy resume method
<3>[ Â Â 0.787785] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
<3>[ Â Â 0.788083] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
<3>[ Â Â 0.788378] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
<3>[ Â Â 0.788444] tps65910 1-002d: tps65910_set_bits:read from reg 3f failed
<3>[ Â Â 0.788738] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
<3>[ Â Â 0.789034] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
<3>[ Â Â 0.789326] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
<3>[ Â Â 0.789391] tps65910 1-002d: read from reg 46 failed
<3>[ Â Â 0.789431] tps65910 1-002d: Error in configuring external control EN1
<4>[ Â Â 0.789479] tps65910 1-002d: Failed to initialise ext control config
<3>[ Â Â 0.789833] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
<3>[ Â Â 0.790127] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
<3>[ Â Â 0.790418] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
<3>[ Â Â 0.790484] tps65910 1-002d: tps65910_set_bits:read from reg 20 failed
<3>[ Â Â 0.790533] set_machine_constraints: VIO: failed to enable
<3>[ Â Â 0.790622] tps65910 1-002d: failed to register tps65910-pmic regulator
<4>[ Â Â 0.790677] tps65910-pmic: probe of tps65910-pmic failed with error -11
<3>[ Â Â 0.791085] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
<3>[ Â Â 0.791378] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
<3>[ Â Â 0.791670] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
<3>[ Â Â 0.791735] tps65910 1-002d: Read from reg 0x22 failed
<4>[ Â Â 0.791773] The device is not tps65910
<4>[ Â Â 0.791919] tps65910: probe of 1-002d failed with error -11
<6>[ Â Â 0.851558] rk616 4-0050: rk616 core probe success!
<6>[ Â Â 0.851791] Switching to clocksource rk_timer
<6>[ Â Â 0.857176] Switched to NOHz mode on CPU #0
<6>[ Â Â 0.857743] Switched to NOHz mode on CPU #3
<6>[ Â Â 0.857756] Switched to NOHz mode on CPU #1
<6>[ Â Â 0.857769] Switched to NOHz mode on CPU #2
<4>[ Â Â 0.860374] use lcdc1 and jetta implemention dual display!
<4>[ Â Â 0.860446] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xdf0ac000
<4>[ Â Â 0.921904] fb0:win0
<4>[ Â Â 0.921909] fb1:win1
<4>[ Â Â 0.921914] fb2:win2
<4>[ Â Â 0.922005] rk3188 lcdc1 clk enable...
<4>[ Â Â 0.986913] rk3188 lcdc1 clk disable...
<4>[ Â Â 1.006773] fb0:phy:98000000>>vir:e0000000>>len:0x800000
<4>[ Â Â 1.007047] rk_fb_register>>>>>fb0
<4>[ Â Â 1.059528] rk_fb_register>>>>>fb1
<4>[ Â Â 1.059581] rk3188 lcdc1 clk enable...
<4>[ Â Â 1.059624] lcdc1: dclk:63642857>>fps:78Â
<6>[ Â Â 1.059659] rk30-lcdc rk30-lcdc.1: rk3188_load_screen for lcdc1 ok!
<6>[ Â Â 1.084762] lcdc1 wakeup from standby!
<6>[ Â Â 1.084795] lcdc1 win0 open,atv layer:1
<4>[ Â Â 1.093381] rk3188 lcdc1 probe ok!
<6>[ Â Â 1.174655] rk616-lvds rk616-lvds: rk616 lvds probe success!
<4>[ Â Â 1.174778] pwm_regulator_probe:n_voltages=25,dcdc->desc.name=PWM_DCDC1,dcdc->desc.id=0 pwm_id=0
<4>[   1.175036] pwm_regulator_probe  dcdc0 =dcdc
<6>[ Â Â 1.175074] pwm_regulator.0: driver initialized
<6>[ Â Â 1.175083] ,dcdc->suspend_hrc=10,dcdc->suspend_lrc=12
<6>[ Â Â 1.175092]Â
<4>[ Â Â 1.185207] pwm_regulator_probe:n_voltages=25,dcdc->desc.name=PWM_DCDC2,dcdc->desc.id=1 pwm_id=2
<4>[   1.185404] pwm_regulator_probe  dcdc1 =dcdc
<6>[ Â Â 1.185441] pwm_regulator.1: driver initialized
<6>[ Â Â 1.185449] ,dcdc->suspend_hrc=10,dcdc->suspend_lrc=12
<6>[ Â Â 1.185459]Â
<3>[ Â Â 1.228614] emmc emmc: internal_storage is NOT emmc
<6>[ Â Â 1.228817] NET: Registered protocol family 2
<6>[ Â Â 1.228962] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
<6>[ Â Â 1.229328] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
<6>[ Â Â 1.230351] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
<6>[ Â Â 1.231524] TCP: Hash tables configured (established 65536 bind 65536)
<6>[ Â Â 1.231574] TCP reno registered
<6>[ Â Â 1.231605] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ Â Â 1.231664] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ Â Â 1.232001] NET: Registered protocol family 1
<4>[ Â Â 1.341995] RK29 Backlight Driver Initialized.
<6>[ Â Â 1.342246] Unpacking initramfs...
<6>[ Â Â 1.417404] Freeing initrd memory: 1472K
<6>[ Â Â 1.417525] PMU: registered new PMU device of type 0
<4>[ Â Â 1.417645] efuse_version_val: efuse version = 51
<4>[ Â Â 1.417685] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 13000
<4>[ Â Â 1.417738] adjust table freq=1608000 KHz, index=1350000 mV to index=1300000 mV
<4>[ Â Â 1.417795] efuse_version_val: efuse version = 51
<4>[ Â Â 1.417831] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 13000
<4>[ Â Â 1.417953] cpufreq: delete arm freq(1608000)
<4>[ Â Â 1.442137] rk3188 cpufreq version 2.2, suspend freq 312 MHz
<3>[ Â Â 1.442836] VPU_SERVICE: failed on clk_get pd_video
<3>[ Â Â 1.442896] VPU_SERVICE: failed on clk_get aclk_ddr_vepu
<3>[ Â Â 1.442942] VPU_SERVICE: failed on clk_get hclk_cpu_vcodec
<4>[ Â Â 1.442990] vpu: power on
<6>[ Â Â 1.443058] VPU_SERVICE: checking hw id 4831
<4>[ Â Â 1.490852] vpu: power off...done
<6>[ Â Â 1.490908] VPU_SERVICE: init success
<6>[ Â Â 1.491212] audit: initializing netlink socket (disabled)
<5>[ Â Â 1.491293] type=2000 audit(1.420:1): initialized
<4>[ Â Â 1.508069] highmem bounce pool size: 64 pages
<6>[ Â Â 1.508214] ashmem: initialized
<6>[ Â Â 1.519468] fuse init (API version 7.16)
<7>[ Â Â 1.519653] SELinux: Â Registering netfilter hooks
<6>[ Â Â 1.524072] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
<6>[ Â Â 1.524123] io scheduler noop registered
<6>[ Â Â 1.524155] io scheduler deadline registered
<6>[ Â Â 1.524214] io scheduler cfq registered (default)
<6>[ Â Â 1.544497] rga: Driver loaded succesfully
<4>[ Â Â 1.544659] rk_serial.c v1.6 2013-12-23
<6>[ Â Â 1.544744] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
<6>[ Â Â 1.544870] rk_serial rk_serial.0: membase 0xdf0bc000
<6>[ Â Â 1.544930] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
<6>[ Â Â 1.545043] rk_serial rk_serial.3: membase 0xdf0c0000
<6>[ Â Â 1.545251] Rockchip ion module(version: 1.0) is successfully loaded
<6>[ Â Â 1.546876] loop: module loaded
<6>[ Â Â 1.546925] Android kernel panic handler initialized (bind=kpanic)
<6>[ Â Â 1.547415] PPP generic driver version 2.4.2
<6>[ Â Â 1.547566] PPP Deflate Compression module registered
<6>[ Â Â 1.547598] PPP BSD Compression module registered
<6>[ Â Â 1.606830] PPP MPPE Compression module registered
<6>[ Â Â 1.606868] NET: Registered protocol family 24
<6>[ Â Â 1.606905] tun: Universal TUN/TAP device driver, 1.6
<6>[ Â Â 1.606934] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<6>[ Â Â 1.607130] usbcore: registered new interface driver asix
<6>[ Â Â 1.607186] usbcore: registered new interface driver cdc_ether
<6>[ Â Â 1.607249] usbcore: registered new interface driver dm9620
<6>[ Â Â 1.607303] usbcore: registered new interface driver SR9700_android
<6>[ Â Â 1.607366] usbcore: registered new interface driver CoreChips
<6>[ Â Â 1.607420] usbcore: registered new interface driver net1080
<6>[ Â Â 1.607480] usbcore: registered new interface driver cdc_subset
<6>[ Â Â 1.607536] usbcore: registered new interface driver zaurus
<6>[ Â Â 1.607578] cdc_ncm: 04-Aug-2011
<6>[ Â Â 1.607617] usbcore: registered new interface driver cdc_ncm
<4>[ Â Â 1.607651] Rockchip WiFi SYS interface (V1.00) ...Â
<6>[ Â Â 1.607704] Initializing USB Mass Storage driver...
<6>[ Â Â 1.607760] usbcore: registered new interface driver usb-storage
<6>[ Â Â 1.607795] USB Mass Storage support registered.
<6>[ Â Â 1.607885] usbcore: registered new interface driver usbserial
<6>[ Â Â 1.607939] USB Serial support registered for generic
<6>[ Â Â 1.607992] usbcore: registered new interface driver usbserial_generic
<6>[ Â Â 1.608031] usbserial: USB Serial Driver core
<6>[ Â Â 1.608082] USB Serial support registered for GSM modem (1-port)
<6>[ Â Â 1.608141] usbcore: registered new interface driver option
<6>[ Â Â 1.608175] option: v0.7.2:USB Driver for GSM modems
<6>[ Â Â 1.608220] USB Serial support registered for pl2303
<6>[ Â Â 1.608274] usbcore: registered new interface driver pl2303
<6>[ Â Â 1.608306] pl2303: Prolific PL2303 USB to serial adaptor driver
<6>[ Â Â 1.820005] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
<6>[ Â Â 1.820047] usb20_otg usb20_otg: DWC OTG Controller
<6>[ Â Â 1.820168] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
<6>[ Â Â 1.820234] usb20_otg usb20_otg: irq 48, io mem 0x00000000
<6>[ Â Â 1.820267] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
<6>[ Â Â 1.820352] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ Â Â 1.820393] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ Â Â 1.820437] usb usb1: Product: DWC OTG Controller
<6>[ Â Â 1.820465] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
<6>[ Â Â 1.820499] usb usb1: SerialNumber: usb20_otg
<6>[ Â Â 1.820788] hub 1-0:1.0: USB hub found
<6>[ Â Â 1.820819] hub 1-0:1.0: 1 port detected
<6>[ Â Â 1.823430] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xdf180000
<6>[ Â Â 2.033906] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ Â Â 2.033961] usb20_host usb20_host: DWC OTG Controller
<6>[ Â Â 2.034018] usb20_host usb20_host: new USB bus registered, assigned bus number 2
<6>[ Â Â 2.034077] usb20_host usb20_host: irq 49, io mem 0x00000000
<6>[ Â Â 2.034145] DWC_OTG: Init: Port Power? op_state=1
<6>[ Â Â 2.034175] DWC_OTG: Init: Power Port (0)
<6>[ Â Â 2.034228] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ Â Â 2.034269] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ Â Â 2.034312] usb usb2: Product: DWC OTG Controller
<6>[ Â Â 2.034341] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
<6>[ Â Â 2.034375] usb usb2: SerialNumber: usb20_host
<6>[ Â Â 2.034644] hub 2-0:1.0: USB hub found
<6>[ Â Â 2.034675] hub 2-0:1.0: 1 port detected
<6>[ Â Â 2.101835] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ Â Â 2.101895] android_usb gadget: Number of LUNs=2
<6>[ Â Â 2.101930] Â lun0: LUN: removable file: (no medium)
<6>[ Â Â 2.101960] Â lun1: LUN: removable file: (no medium)
<6>[ Â Â 2.102165] android_usb gadget: android_usb ready
<6>[ Â Â 2.102355] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
<6>[ Â Â 2.102585] usbcore: registered new interface driver xpad
<6>[ Â Â 2.102653] usbcore: registered new interface driver usb_acecad
<6>[ Â Â 2.102689] acecad: v3.2:USB Acecad Flair tablet driver
<6>[ Â Â 2.102744] usbcore: registered new interface driver aiptek
<6>[ Â Â 2.102778] aiptek: v2.3 (May 2, 2007):Aiptek HyperPen USB Tablet Driver (Linux 2.6.x)
<6>[ Â Â 2.102822] aiptek: Bryan W. Headley/Chris Atenasio/Cedric Brun/Rene van Paassen
<6>[ Â Â 2.102888] usbcore: registered new interface driver gtco
<4>[ Â Â 2.102921] GTCO usb driver version: 2.00.0006
<6>[ Â Â 2.102976] usbcore: registered new interface driver hanwang
<6>[ Â Â 2.103033] usbcore: registered new interface driver kbtab
<6>[ Â Â 2.103065] kbtab: v0.0.2:USB KB Gear JamStudio Tablet driver
<6>[ Â Â 2.103125] usbcore: registered new interface driver wacom
<6>[ Â Â 2.103158] wacom: v1.52:USB Wacom tablet driver
<4>[ Â Â 2.103185] ==gsl_ts_init==
<4>[ Â Â 2.103233] GSLX680 Enter gsl_ts_probe
<4>[ Â Â 2.103257] ==kzalloc success=
<4>[ Â Â 2.222314] I read reg 0xf0 is 0
<4>[ Â Â 2.242224] I write reg 0xf0 0x12
<4>[ Â Â 2.262380] I read reg 0xf0 is 0x12
<4>[ Â Â 2.262426] [GSLX680] Enter gslX680_ts_init
<6>[ Â Â 2.270366] input: gslX680 as /devices/platform/rk30_i2c.2/i2c-2/2-0040/input/input1
<3>[ Â Â 2.322197] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 2...
<3>[ Â Â 2.322584] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 1...
<3>[ Â Â 2.322966] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 0...
<6>[ Â Â 2.421919] usb 2-1: new high speed USB device number 2 using usb20_host
<3>[ Â Â 2.422255] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 2...
<3>[ Â Â 2.422685] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 1...
<3>[ Â Â 2.423115] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 0...
<4>[ Â Â 2.491888] =============gsl_load_fw start==============
<6>[ Â Â 2.662951] usb 2-1: New USB device found, idVendor=0bda, idProduct=0724
<6>[ Â Â 2.663058] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ Â Â 2.663160] usb 2-1: Product: 802.11n WLAN Adapter
<6>[ Â Â 2.663224] usb 2-1: Manufacturer: Realtek
<6>[ Â Â 2.663281] usb 2-1: SerialNumber: 00e04c000001
<4>[ Â Â 3.183604] =============gsl_load_fw end==============
<3>[ Â Â 3.202295] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 2...
<3>[ Â Â 3.202776] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 1...
<3>[ Â Â 3.203247] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 0...
<4>[ Â Â 3.332827] [GSLX680] End gsl_ts_probe
<4>[ Â Â 3.332997] ret=0
<4>[ Â Â 3.333513] sensor_register_slave:mma8452,id=17
<4>[ Â Â 3.333579] sensor_register_slave:mma7660,id=18
<4>[ Â Â 3.333640] sensor_register_slave:gs_stk8312,id=19
<6>[ Â Â 3.358673] using rtc device, rtc_hym8563, for alarms
<6>[ Â Â 3.358788] rtc_hym8563 1-0051: rtc core: registered rtc_hym8563 as rtc0
<6>[ Â Â 3.358953] i2c /dev entries driver
<6>[ Â Â 3.360620] lirc_dev: IR Remote Control driver registered, major 250Â
<6>[ Â Â 3.360704] IR NEC protocol handler initialized
<6>[ Â Â 3.360761] IR RC5(x) protocol handler initialized
<6>[ Â Â 3.360821] IR RC6 protocol handler initialized
<6>[ Â Â 3.360877] IR JVC protocol handler initialized
<6>[ Â Â 3.360932] IR Sony protocol handler initialized
<6>[ Â Â 3.360989] IR RC5 (streamzap) protocol handler initialized
<6>[ Â Â 3.361055] IR LIRC bridge handler initialized
<6>[ Â Â 3.361109] Linux video capture interface: v2.00
<6>[ Â Â 3.361833] usbcore: registered new interface driver uvcvideo
<6>[ Â Â 3.361954] USB Video Class driver (v1.1.0)
<4>[ Â Â 3.362295] def_ref_volt: 1800mV, curr_ref_volt: 1800mV
<4>[ Â Â 3.362337] start_charge_logo_display
<6>[ Â Â 3.362794] device-mapper: uevent: version 1.0.3
<6>[ Â Â 3.363140] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
<6>[ Â Â 3.363434] Bluetooth: HCI UART driver ver 2.2
<6>[ Â Â 3.363473] Bluetooth: HCI H4 protocol initialized
<6>[ Â Â 3.363516] Bluetooth: HCILL protocol initialized
<6>[ Â Â 3.363553] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.16
<6>[ Â Â 3.363603] rtk_btusb: Register usb char device interface for BT driver
<6>[ Â Â 3.363819] rtk_btusb: btusb_probe: usb_interface dd252400, bInterfaceNumber 0, idVendor 0x0bda, idProduct 0x0000
<6>[ Â Â 3.363898] rtk_btusb: get_fw_table_entry: Product id = 0x0724, fw table entry size 39
<6>[ Â Â 3.363977] rtk_btusb: btusb_probe: Check bt reset flag 0
<6>[ Â Â 3.364105] usbcore: registered new interface driver rtk_btusb
<6>[ Â Â 3.364229] cpuidle: using governor ladder
<6>[ Â Â 3.364262] cpuidle: using governor menu
<6>[ Â Â 3.409831] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. Â [sd_mmc]
<6>[ Â Â 3.409852]Â
<6>[ Â Â 3.409857] drivers/mmc/core/core.c...2019.. Â ===== mmc_rescan Begin....[mmc0]
<6>[ Â Â 3.410218] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. Â [sdio]
<6>[ Â Â 3.410371] Skipping unavailable LED gpio -1 (button-backlight)
<6>[ Â Â 3.412704] usbcore: registered new interface driver usbhid
<6>[ Â Â 3.412740] usbhid: USB HID core driver
<6>[ Â Â 3.414722] rk29_sdmmc_change_clk_div..1684.. Â newDiv=62, newCLK=299Khz [sd_mmc]
<6>[ Â Â 3.430629] logger: created 256K log 'log_main'
<6>[ Â Â 3.430708] logger: created 256K log 'log_events'
<6>[ Â Â 3.430792] logger: created 256K log 'log_radio'
<6>[ Â Â 3.430874] logger: created 256K log 'log_system'
<6>[ Â Â 3.431163] zram: Created 1 device(s) ...
<4>[ Â Â 3.431544] rk616_get_parameter : Can not get ap_has_alsa from kernel command line!
<6>[ Â Â 3.451960] Enter::audio_card_init----290
<4>[ Â Â 3.452158] rk616_probe : rk616 or pdata or rcv_ctl_gpio is NULL!
<4>[ Â Â 3.452195] rk616_probe : rk616 or pdata or mic_sel_gpio is NULL!
<6>[ Â Â 3.461645]Â
<6>[ Â Â 3.461648] mmc_attach_sd..1230.. Â ===== Begin to identify card as SD-card. [mmc0]
<6>[ Â Â 3.491831] asoc: rk616-hifi <-> rk29_i2s.1 mapping ok
<6>[ Â Â 3.496524] asoc: rk616-voice <-> rk29_i2s.1 mapping ok
<6>[ Â Â 3.496958] ALSA device list:
<6>[ Â Â 3.496979] Â #0: RK_RK616_TINY
<6>[ Â Â 3.497080] GACT probability NOT on
<6>[ Â Â 3.497108] Mirror/redirect action on
<6>[ Â Â 3.497131] u32 classifier
<6>[ Â Â 3.497148] Â Â Actions configured
<6>[ Â Â 3.497172] Netfilter messages via NETLINK v0.30.
<6>[ Â Â 3.497237] nf_conntrack version 0.5.0 (13693 buckets, 54772 max)
<6>[ Â Â 3.497525] ctnetlink v0.93: registering with nfnetlink.
<6>[ Â Â 3.497583] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ Â Â 3.497623] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ Â Â 3.497922] xt_time: kernel timezone is -0000
<6>[ Â Â 3.498073] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ Â Â 3.498237] arp_tables: (C) 2002 David S. Miller
<6>[ Â Â 3.498300] TCP cubic registered
<6>[ Â Â 3.498321] Initializing XFRM netlink socket
<6>[ Â Â 3.498695] NET: Registered protocol family 10
<6>[ Â Â 3.499245] Mobile IPv6
<6>[ Â Â 3.499282] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ Â Â 3.499408] IPv6 over IPv4 tunneling driver
<6>[ Â Â 3.499944] NET: Registered protocol family 17
<6>[ Â Â 3.499993] NET: Registered protocol family 15
<6>[ Â Â 3.521946] Bluetooth: RFCOMM TTY layer initialized
<6>[ Â Â 3.522025] Bluetooth: RFCOMM socket layer initialized
<6>[ Â Â 3.522056] Bluetooth: RFCOMM ver 1.11
<6>[ Â Â 3.522080] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ Â Â 3.522113] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ Â Â 3.522278] NET: Registered protocol family 35
<6>[ Â Â 3.522460] [BT_RFKILL]: Enter rfkill_rk_init
<6>[ Â Â 3.522567] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ Â Â 3.522611] [BT_RFKILL]: ** disable irq
<6>[ Â Â 3.551893] [BT_RFKILL]: bt shut off power
<6>[ Â Â 3.581869] [BT_RFKILL]: bt_default device registered.
<6>[ Â Â 3.582218] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
<3>[ Â Â 3.582291] rk_cam_cif(3361):rk3066b-camera version: v0.3.25 Â Zoom by ipp
<5>[ Â Â 3.582396] Registering SWP/SWPB emulation handler
<6>[ Â Â 3.582863] ddrfreq: verion 3.2 20131126
<6>[ Â Â 3.582891] ddrfreq: fix cpu pause bug
<6>[ Â Â 3.582917] ddrfreq: normal 456MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 300MHz
<4>[ Â Â 3.597318] ret: 0
<6>[ Â Â 3.606807] ddrfreq: change freq to 445 MHz when normal
<4>[ Â Â 3.624972] ret: 0
<4>[ Â Â 3.662138] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
<3>[ Â Â 3.662500] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
<3>[ Â Â 3.662857] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
<3>[ Â Â 3.663210] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
<3>[ Â Â 3.663255] gc2035_back_3(rk_cam_sensor:167): write reg(0xfe, val:0x50) failed, try to write again!
<3>[ Â Â 3.663616] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
<3>[ Â Â 3.663970] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
<3>[ Â Â 3.664322] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
<3>[ Â Â 3.664367] gc2035_back_3(rk_cam_sensor:167): write reg(0xfe, val:0x50) failed, try to write again!
<3>[ Â Â 3.664730] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
<3>[ Â Â 3.665082] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
<3>[ Â Â 3.665434] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
<3>[ Â Â 3.665478] gc2035_back_3(rk_cam_sensor:167): write reg(0xfe, val:0x50) failed, try to write again!
<3>[ Â Â 3.665533] gc2035_back_3(rk_cam_sensor:383): write array failed!
<3>[ Â Â 3.665563] gc2035_back_3(rk_cam_sensor:689): soft reset failed
<3>[ Â Â 3.665570]Â
<6>[ Â Â 3.670632] rk616-hdmi rk616-hdmi.1: rk616 hdmi probe success.
<3>[ Â Â 3.682312] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
<3>[ Â Â 3.682776] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
<3>[ Â Â 3.683240] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
<3>[ Â Â 3.683285] gc2035_back_3(rk_cam_sensor:333): read reg(0xf0 val:0x0) failed, try to read again!
<3>[ Â Â 3.683338] gc2035_back_3(rk_cam_sensor:716): read chip id failed
<4>[ Â Â 3.695648] ret: 0
<3>[ Â Â 3.721891] camera 33-0-gc2035_back_3: Probe gc2035_back_3 failed
<4>[ Â Â 3.732485] ret: 0
<4>[ Â Â 3.764934] ret: 0
<4>[ Â Â 4.010217] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
<3>[ Â Â 4.022374] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
<3>[ Â Â 4.022843] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
<3>[ Â Â 4.023312] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
<3>[ Â Â 4.023361] sp2518_back_4(rk_cam_sensor:333): read reg(0x2 val:0x0) failed, try to read again!
<3>[ Â Â 4.023419] sp2518_back_4(rk_cam_sensor:716): read chip id failed
<4>[ Â Â 4.035776] ret: 0
<3>[ Â Â 4.062080] camera 33-1-sp2518_back_4: Probe sp2518_back_4 failed
<4>[ Â Â 4.072667] ret: 0
<4>[ Â Â 4.104940] ret: 0
<6>[ Â Â 4.119563] rk29_sdmmc_change_clk_div..1684.. Â newDiv=0, newCLK=37125Khz [sd_mmc]
<6>[ Â Â 4.119639] mmc0: new high speed SDHC card at address 21a9
<6>[ Â Â 4.119870] mmcblk0: mmc0:21a9 APPSD 15.4 GiBÂ
<6>[ Â Â 4.120840]Â
<6>[ Â Â 4.120843] msdos_partition..466... ==== Begin to parse sdcard-partition. Â [mmc0]
<6>[ Â Â 4.120887] msdos_partition..535... ==== The sdcard has MBR. [mmc0]
<6>[ Â Â 4.120919] msdos_partition..548... ==== partition-1, size=16175005KB Â [mmc0]
<6>[ Â Â 4.120955] msdos_partition..576... ==== main partition-1....[mmc0]
<6>[ Â Â 4.120987] Â mmcblk0: p1
<6>[ Â Â 4.121276] sdmmc_rescan_try_freq..1913.. Â ===== Initialize SD-card successfully. [mmc0]
<6>[ Â Â 4.121323]Â
<6>[ Â Â 4.121326] drivers/mmc/core/core.c...2019.. Â ===== mmc_rescan Begin....[mmc1]
<6>[ Â Â 4.131869] rk29_sdmmc_change_clk_div..1684.. Â newDiv=42, newCLK=294Khz [sdio]
<4>[ Â Â 4.192055] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
<4>[ Â Â 4.245323] ret: 0
<4>[ Â Â 4.271909] Probe gc2035_back_5 success
<4>[ Â Â 4.282584] ret: 0
<4>[ Â Â 4.315376] ret: 0
<4>[ Â Â 4.352087] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
<4>[ Â Â 4.384672] ret: 0
<4>[ Â Â 4.411886] Probe gc0308_front_6 success
<4>[ Â Â 4.422470] ret: 0
<4>[ Â Â 4.454912] ret: 0
<3>[ Â Â 4.492005] i2c i2c-3: 1 i2c clients have been registered at 0x21min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
<3>[ Â Â 4.512298] i2c i2c-3: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 2...
<3>[ Â Â 4.512765] i2c i2c-3: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 1...
<3>[ Â Â 4.513232] i2c i2c-3: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 0...
<3>[ Â Â 4.513282] gc0308_front_7(rk_cam_sensor:333): read reg(0x0 val:0x9b) failed, try to read again!
<3>[ Â Â 4.513339] gc0308_front_7(rk_cam_sensor:716): read chip id failed
<4>[ Â Â 4.525715] ret: 0
<3>[ Â Â 4.551921] camera 33-4-gc0308_front_7: Probe gc0308_front_7 failed
<4>[ Â Â 4.562582] ret: 0
<4>[ Â Â 4.594837] ret: 0
<3>[ Â Â 4.631997] i2c i2c-3: 1 i2c clients have been registered at 0x21min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
<3>[ Â Â 4.652295] i2c i2c-3: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 2...
<3>[ Â Â 4.652758] i2c i2c-3: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 1...
<3>[ Â Â 4.653218] i2c i2c-3: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 0...
<3>[ Â Â 4.653264] gc0328_front_8(rk_cam_sensor:333): read reg(0xf0 val:0x0) failed, try to read again!
<3>[ Â Â 4.653316] gc0328_front_8(rk_cam_sensor:716): read chip id failed
<4>[ Â Â 4.665819] ret: 0
<3>[ Â Â 4.691915] camera 33-5-gc0328_front_8: Probe gc0328_front_8 failed
<6>[ Â Â 4.692105] input: rk_headsetdet as /devices/platform/rk_headsetdet.0/input/input2
<6>[ Â Â 4.742535] i2c i2c-0: sensor_probe: gs_mma8452,0xde20ca00
<4>[ Â Â 4.742571] sensor_chip_init:gs_mma8452:devid=0x0,ops=0xc0ea2850
<6>[ Â Â 4.744361] input: gsensor as /devices/platform/rk30_i2c.0/i2c-0/0-001d/input/input3
<4>[ Â Â 4.744557] sensor_irq_init:use irq=175
<4>[ Â Â 4.744662] sensor_misc_device_register:miscdevice: mma8452_daemon
<4>[ Â Â 4.744695] sensor_probe:initialized ok,sensor name:mma8452,type:2,id=17
<4>[ Â Â 4.744702]Â
<6>[ Â Â 4.744749] i2c i2c-0: sensor_probe: gs_mma7660,0xde20cc00
<4>[ Â Â 4.744780] sensor_chip_init:gs_mma7660:devid=0x0,ops=0xc0ea28ac
<3>[ Â Â 4.745040] i2c i2c-0: No ack, Maybe slave(addr: 0x4c) not exist or abnormal power-on, retry 2...
<3>[ Â Â 4.745308] i2c i2c-0: No ack, Maybe slave(addr: 0x4c) not exist or abnormal power-on, retry 1...
<3>[ Â Â 4.745574] i2c i2c-0: No ack, Maybe slave(addr: 0x4c) not exist or abnormal power-on, retry 0...
<3>[ Â Â 4.745783] i2c i2c-0: No ack, Maybe slave(addr: 0x4c) not exist or abnormal power-on, retry 2...
<3>[ Â Â 4.745991] i2c i2c-0: No ack, Maybe slave(addr: 0x4c) not exist or abnormal power-on, retry 1...
<3>[ Â Â 4.746199] i2c i2c-0: No ack, Maybe slave(addr: 0x4c) not exist or abnormal power-on, retry 0...
<4>[ Â Â 4.746244] sensor_active:fail to active sensor
<4>[ Â Â 4.746267] sensor_init:line=116,error
<4>[ Â Â 4.746286] sensor_initial:fail to init sensor
<4>[ Â Â 4.746308] sensor_chip_init:fail to init sensor
<3>[ Â Â 4.746332] i2c i2c-0: sensor_probe failed -11
<3>[ Â Â 4.746337]Â
<4>[ Â Â 4.746366] sensors: probe of 0-004c failed with error -11
<6>[ Â Â 4.746403] i2c i2c-0: sensor_probe: gs_stk831x,0xde20ce00
<4>[ Â Â 4.746431] sensor_chip_init:gs_stk831x:devid=0x0,ops=0xc0ea2908
<4>[ Â Â 4.746460] STK831x_Init
<4>[ Â Â 4.746474] STK831x_Init: driver version:1.8.1
<4>[ Â Â 4.746496] STK831x_Init: Initialize stk8312
<3>[ Â Â 4.746685] i2c i2c-0: No ack, Maybe slave(addr: 0x3d) not exist or abnormal power-on, retry 2...
<3>[ Â Â 4.746903] i2c i2c-0: No ack, Maybe slave(addr: 0x3d) not exist or abnormal power-on, retry 1...
<3>[ Â Â 4.747111] i2c i2c-0: No ack, Maybe slave(addr: 0x3d) not exist or abnormal power-on, retry 0...
<4>[ Â Â 4.747153] STK831x_Init:failed
<4>[ Â Â 4.747170] sensor_initial:fail to init sensor
<4>[ Â Â 4.747191] sensor_chip_init:fail to init sensor
<3>[ Â Â 4.747215] i2c i2c-0: sensor_probe failed -11
<3>[ Â Â 4.747220]Â
<4>[ Â Â 4.747248] sensors: probe of 0-003d failed with error -11
<6>[ Â Â 4.747305] sensor_init: Probe name sensors
<4>[ Â Â 4.747340] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<6>[ Â Â 4.747922] rtc_hym8563 1-0051: setting system clock to 2014-11-29 21:38:14 UTC (1417297094)
<6>[ Â Â 4.750562] asoc: dit-hifi <-> rk-spdif mapping ok
<6>[ Â Â 4.751129] Freeing init memory: 2668K
<7>[ Â Â 4.979653] SELinux: 512 avtab hash slots, 1334 rules.
<7>[ Â Â 4.980118] SELinux: 512 avtab hash slots, 1334 rules.
<7>[ Â Â 4.980140] SELinux: Â 1 users, 2 roles, 288 types, 1 bools, 1 sens, 1024 cats
<7>[ Â Â 4.980161] SELinux: Â 84 classes, 1334 rules
<7>[ Â Â 4.980866] SELinux: Â Completing initialization.
<7>[ Â Â 4.980880] SELinux: Â Setting up existing superblocks.
<7>[ Â Â 4.980907] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ Â Â 4.980934] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ Â Â 4.981005] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ Â Â 4.981027] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ Â Â 4.981056] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ Â Â 4.981087] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ Â Â 4.981278] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ Â Â 4.982419] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ Â Â 4.982446] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ Â Â 4.982468] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ Â Â 4.982496] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ Â Â 4.982530] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ Â Â 4.982598] SELinux: initialized (dev mtd_inodefs, type mtd_inodefs), not configured for labeling
<7>[ Â Â 4.982623] SELinux: initialized (dev usbfs, type usbfs), not configured for labeling
<7>[ Â Â 4.982650] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ Â Â 4.982688] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<5>[ Â Â 5.275693] type=1403 audit(1417297095.020:2): policy loaded auid=4294967295 ses=4294967295
<4>[ Â Â 5.284242] SELinux: Loaded policy from /sepolicy
<5>[ Â Â 5.291228] type=1404 audit(1417297095.030:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
<3>[ Â Â 6.457706] init: /init.rc: 629: invalid option 'chmod'
<3>[ Â Â 6.463964] init: could not import file '/init.usbstorage.rc' from '/init.rc'
<4>[ Â Â 6.471212] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<3>[ Â Â 6.531629] init: /dev/hw_random not found
<6>[ Â Â 6.535814] keychord: using input dev rk29-keypad for fevent
<7>[ Â Â 6.642631] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ Â Â 6.643168] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ Â Â 6.832291] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ Â Â 6.836860] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ Â Â 6.838248] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ Â Â 6.838827] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ Â Â 7.001935] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<4>[ Â Â 7.007411] gp_rknand_info = : 0xde29db00
<4>[ Â Â 7.011502] rk30_chip_set:1Â
<4>[ Â Â 7.014441] FtlInit!
<4>[ Â Â 7.016654] No.1 FLASH ID:ad de 94 eb 74 44
<4>[ Â Â 7.022549] FTL version: 5.0.12 20140214
<4>[ Â Â 7.236637] gBootMedia = 1 gSdmmcFwPartOffset =0!
<4>[ Â Â 7.241364] rknand_buffer.c version: 4.40 20130830!
<5>[ Â Â 7.246419] 11 cmdlinepart partitions found on MTD device rk29xxnand
<5>[ Â Â 7.252797] Creating 11 MTD partitions on "rk29xxnand":
<5>[ Â Â 7.258042] 0x000000400000-0x000000800000 : "misc"
<5>[ Â Â 7.264990] 0x000000800000-0x000002000000 : "kernel"
<5>[ Â Â 7.271609] 0x000002000000-0x000003000000 : "boot"
<5>[ Â Â 7.278051] 0x000003000000-0x000005000000 : "recovery"
<5>[ Â Â 7.284875] 0x000005000000-0x000009000000 : "backup"
<5>[ Â Â 7.291536] 0x000009000000-0x000011000000 : "cache"
<5>[ Â Â 7.297512] 0x000011000000-0x000050c00000 : "userdata"
<5>[ Â Â 7.303600] 0x000050c00000-0x000051000000 : "metadata"
<5>[ Â Â 7.304238] 0x000051000000-0x000051400000 : "kpanic"
<6>[ Â Â 7.306030] apanic: Bound to mtd partition 'kpanic'
<6>[ Â Â 7.306057] apanic: No panic data available
<5>[ Â Â 7.306085] 0x000051400000-0x000081400000 : "system"
<5>[ Â Â 7.307076] 0x000081400000-0x0001d4000000 : "user"
<3>[ Â Â 7.332979] fs_mgr: parse_link_device /dev/block/mtdblock10: in
<3>[ Â Â 7.338950] fs_mgr: parse_link_device : ---- part_num = 10, path = /devices/virtual/mtd/mtd10/mtdblock10, is_emmc = 0
<3>[ Â Â 7.349620] fs_mgr: parse_link_device : path = NULL
<3>[ Â Â 7.354537] fs_mgr: parse_link_device : path = NULL
<6>[ Â Â 7.359476] fs_mgr: ---------------resize_fs blk_dev /dev/block/mtd/by-name/system, type ext4
<6>[ Â Â 7.367860] fs_mgr: Running /sbin/resize2fs on /dev/block/mtd/by-name/system
<6>[ Â Â 7.376211] resize2fs: resize2fs 1.41.14 (22-Dec-2010)
<6>[ Â Â 7.381395] resize2fs: The filesystem is already 196608 blocks long. Â Nothing to do!
<6>[ Â Â 7.389208] resize2fs:Â
<6>[ Â Â 7.401068] EXT4-fs (mtdblock9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ Â Â 7.402006] SELinux: initialized (dev mtdblock9, type ext4), uses xattr
<4>[ Â Â 7.408020] EXT4-fs (mtdblock5): warning: maximal mount count reached, running e2fsck is recommended
<6>[ Â Â 7.408231] EXT4-fs (mtdblock5): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ Â Â 7.409685] SELinux: initialized (dev mtdblock5, type ext4), uses xattr
<6>[ Â Â 7.412061] EXT4-fs (mtdblock7): mounted filesystem without journal. Opts: noauto_da_alloc,discard
<7>[ Â Â 7.412121] SELinux: initialized (dev mtdblock7, type ext4), uses xattr
<4>[ Â Â 7.432062] EXT4-fs (mtdblock6): warning: checktime reached, running e2fsck is recommended
<7>[ Â Â 7.448390] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 3373
<7>[ Â Â 7.449403] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 3319
<7>[ Â Â 7.449578] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 3328
<6>[ Â Â 7.450534] EXT4-fs (mtdblock6): 3 orphan inodes deleted
<6>[ Â Â 7.450567] EXT4-fs (mtdblock6): recovery complete
<6>[ Â Â 7.465158] EXT4-fs (mtdblock6): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ Â Â 7.465228] SELinux: initialized (dev mtdblock6, type ext4), uses xattr
<4>[ Â Â 7.494647] UMP: Using OS memory backend, allocation limit: 536870912
<4>[ Â Â 7.494695] UMP: UMP device driver -0d88e3e loaded
<4>[ Â Â 7.518030] Mali: Mali400 inside of rk3188!
<4>[ Â Â 7.518070] Mali: mali freq table num : 6Â
<4>[ Â Â 7.518092] Mali: mali freq table :Mali: 132,Mali: 179,Mali: 223,Mali: 297,Mali: 297,Mali: 446,Mali:Â
<4>[ Â Â 7.518161] Mali: init mali clock successÂ
<4>[ Â Â 7.519685] Mali: Mali device driver loaded
<4>[ Â Â 7.523416] rk30_mirroring: Unknown symbol video_data_to_mirroring (err 0)
<4>[ Â Â 7.523498] rk30_mirroring: Unknown symbol audio_data_to_mirroring (err 0)
<4>[ Â Â 7.525677] rk29_ipp: module is from the staging directory, the quality is unknown, you have been warned.
<4>[ Â Â 7.526695] ipp irq 47
<4>[ Â Â 7.527353] IPP init, version rk30-ipp 1.003
<3>[ Â Â 7.584601] init: /dev/hw_random not found
<4>[ Â Â 7.615964] healthd: BatteryTemperaturePath not found
<6>[ Â Â 7.616019] binder: 113:113 transaction failed 29189, size 0-0
<3>[ Â Â 7.627652] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl'
<3>[ Â Â 7.635605] init: cannot find '/system/bin/rild3', disabling 'ril-daemon3'
<3>[ Â Â 7.732248] init: cannot find '/system/bin/chrome.sh', disabling 'chrome'
<3>[ Â Â 7.734829] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
<3>[ Â Â 7.734901] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
<3>[ Â Â 7.735160] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
<6>[ Â Â 7.735738] rtk_btusb: btchr_open: BT usb char device is opening
<6>[ Â Â 7.735773] rtk_btusb: btusb_open: Start, PM usage count 0
<6>[ Â Â 7.735802] rtk_btusb: get_firmware: start, cached 1,patch_entry->fw_len= 0
<6>[ Â Â 7.735839] rtk_btusb: load_firmware: Default lmp version = 0x1200, config file name[rtl8723a_config], fw file name[rtl8723a_fw]
<6>[ Â Â 7.898356] rtk_btusb: load_firmware: fw exists, config file exists
<6>[ Â Â 7.899875] rtk_btusb: check_fw_version: Controller lmp = 0xa5b1, patch lmp = 0xa5b1, default patch lmp = 0x1200
<6>[ Â Â 7.899926] rtk_btusb: check_fw_version: Warm BT controller startup with same lmp
<6>[ Â Â 7.900011] rtk_btusb: btusb_open: End, PM usage count 0
<6>[ Â Â 7.900147] rtk_btusb: btchr_close: BT usb char device is closing
<6>[ Â Â 7.910255] rtk_btusb: btusb_close: hci running 0
<7>[ Â Â 7.929483] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<6>[ Â Â 7.933710] warning: `daemonsu' uses 32-bit capabilities (legacy support in use)
<6>[ Â Â 7.939360] rtk_btusb: btchr_open: BT usb char device is opening
<6>[ Â Â 7.939466] rtk_btusb: btusb_open: Start, PM usage count 0
<6>[ Â Â 7.939498] rtk_btusb: get_firmware: start, cached 1,patch_entry->fw_len= 0
<6>[ Â Â 7.939539] rtk_btusb: load_firmware: Default lmp version = 0x1200, config file name[rtl8723a_config], fw file name[rtl8723a_fw]
<6>[ Â Â 7.944664] rtk_btusb: load_firmware: fw exists, config file exists
<6>[ Â Â 7.946126] rtk_btusb: check_fw_version: Controller lmp = 0xa5b1, patch lmp = 0xa5b1, default patch lmp = 0x1200
<6>[ Â Â 7.946240] rtk_btusb: check_fw_version: Warm BT controller startup with same lmp
<6>[ Â Â 7.946335] rtk_btusb: btusb_open: End, PM usage count 0
<6>[ Â Â 7.946384] rtk_btusb: btchr_close: BT usb char device is closing
<6>[ Â Â 7.956761] rtk_btusb: btusb_close: hci running 0
<4>[ Â Â 8.063228] RKNAND_GET_DRM_KEY
<4>[ Â Â 8.063263] return ret = 0
<3>[ Â Â 8.102640] init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
<3>[ Â Â 8.102715] init: powerctl: cannot expand '${sys.powerctl}'
<3>[ Â Â 8.102766] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
<3>[ Â Â 8.102829] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
<3>[ Â Â 8.105446] init: untracked pid 133 exited
<3>[ Â Â 8.106561] android_usb: already disabled
<6>[ Â Â 8.143425] adb_open
<3>[ Â Â 8.297530] fs_mgr: parse_link_device /dev/block/mtdblock10: in
<3>[ Â Â 8.305808] fs_mgr: parse_link_device : ---- part_num = 10, path = /devices/virtual/mtd/mtd10/mtdblock10, is_emmc = 0
<7>[ Â Â 8.306491] SELinux: 512 avtab hash slots, 1382 rules.
<7>[ Â Â 8.307009] SELinux: 512 avtab hash slots, 1382 rules.
<7>[ Â Â 8.307032] SELinux: Â 1 users, 2 roles, 288 types, 1 bools, 1 sens, 1024 cats
<7>[ Â Â 8.307063] SELinux: Â 84 classes, 1382 rules
<3>[ Â Â 8.316605] fs_mgr: parse_link_device : path = NULL
<3>[ Â Â 8.321609] fs_mgr: parse_link_device : path = NULL
<6>[ Â Â 8.326786] .204.. MMC0 receive the message sd-No-Media from VOLD.[sd_mmc]
<6>[ Â Â 8.333739] .235.. MMC0 receive the message No-Media from VOLD. waitTimes=0 [sd_mmc]
<6>[ Â Â 8.384034] .204.. MMC0 receive the message sd-Pending from VOLD.[sd_mmc]
<6>[ Â Â 8.391069] .204.. MMC0 receive the message sd-Idle-Unmounted from VOLD.[sd_mmc]
<5>[ Â Â 8.473912] type=1403 audit(1417297098.210:4): policy loaded auid=4294967295 ses=4294967295
<4>[ Â Â 8.545609] avc: Â received policyload notice (seqno=2)
<6>[ Â Â 8.548583] EXT4-fs (mtdblock9): re-mounted. Opts: (null)
<4>[ Â Â 8.552933] rk fb use 3 buffers
<6>[ Â Â 8.618603] healthd: battery l=100 v=4162 t=0.0 h=2 st=2 chg=a
<6>[ Â Â 8.702796] healthd: battery l=100 v=4162 t=0.0 h=2 st=2 chg=a
<6>[ Â Â 9.112489] EXT4-fs (mtdblock9): re-mounted. Opts: (null)
<6>[ Â Â 9.151410] EXT4-fs (mtdblock9): re-mounted. Opts: (null)
<3>[ Â Â 9.209271] init: untracked pid 381 exited
<6>[ Â Â 9.702931] healthd: battery l=100 v=4162 t=0.0 h=2 st=2 chg=a
<4>[ Â 10.704766] not_reboot_chargeing,new=100,old=100,bat_capacity=100
<4>[ Â 10.710908] old_capacity = 100 , new_capacity =100, bat->bat_capacity=100,bat ->bat_status=1
<4>[ Â 10.710922] Â Â
<6>[ Â 11.013298] healthd: battery l=100 v=4162 t=0.0 h=2 st=2 chg=a
<6>[ Â 11.013812] healthd: battery l=100 v=4162 t=0.0 h=2 st=2 chg=a
<6>[ Â 20.012703] healthd: battery l=100 v=4162 t=0.0 h=2 st=5 chg=a
<6>[ Â 20.013013] healthd: battery l=100 v=4162 t=0.0 h=2 st=5 chg=a
<6>[ Â 36.628882] healthd: battery l=100 v=4162 t=0.0 h=2 st=5 chg=a
<6>[ Â 36.631762] request_suspend_state: wakeup (3->0) at 36569905214 (2014-11-29 21:38:46.370124463 UTC)
<4>[ Â 37.151973] wifi_driver_write: wifi driver already rmmod
<6>[ Â 37.326980] acc_open
<6>[ Â 37.327011] acc_release
<6>[ Â 37.485301] .204.. MMC0 receive the message sd-Checking from VOLD.[sd_mmc]
<7>[ Â 38.073800] SELinux: initialized (dev mmcblk0p1, type vfat), uses genfs_contexts
<6>[ Â 38.145701] .204.. MMC0 receive the message sd-Mounted from VOLD.[sd_mmc]
<3>[ Â 38.145730] init: no such service 'fuse_external_sd'
<4>[ Â 38.168516]Â
<4>[ Â 38.170055] =======================================================
<4>[ Â 38.176462] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ Â 38.182842] =======================================================
<4>[ Â 38.189151] Realtek 8723AU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
<4>[ Â 38.196873] wifi_activate_usb
<6>[ Â 38.199908] rk29sdk_wifi_power: 1
<6>[ Â 38.474072] wifi turn on power
<4>[ Â 38.582540] rtl8723as-vau driver version=v4.1.8_9660.20131126_BTCOEX20130528_ver3.3
<5>[  38.660152] type=1400 audit(1417297128.390:5): avc:  denied  { read } for  pid=666 comm="e.swiftkey.beta" path=2F6465762F6173686D656D2F64616C76696B2D68656170202864656C6574656429 dev=tmpfs ino=3372 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:init_tmpfs:s0 tclass=file
<4>[ Â 38.723659] Wifi Efuse Mac => 08:d8:33:13:e9:d9
<4>[ Â 38.723763] rk29sdk_wifi_mac_addr.
<4>[ Â 38.723857] falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<4>[ Â 38.723933] This mac address is not valid, ignored...
<6>[ Â 38.754543] usbcore: registered new interface driver rtl8723au
<5>[  38.831854] type=1400 audit(1417297128.560:6): avc:  denied  { getattr } for  pid=666 comm="re-initialized>" path="/data/app" dev=mtdblock6 ino=24482 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:apk_data_file:s0 tclass=dir
<7>[ Â 39.567015] SELinux: initialized (dev mtdblock10, type vfat), uses genfs_contexts
<3>[ Â 39.622806] init: no such service 'fuse_internal_sd'
<6>[ Â 40.798714] ADDRCONF(NETDEV_UP): p2p0: link is not ready
<6>[ Â 40.878070] EXT4-fs (dm-0): mounted filesystem without journal. Opts: (null)
<7>[ Â 40.878164] SELinux: initialized (dev dm-0, type ext4), uses xattr
<6>[ Â 41.019300] EXT4-fs (dm-0): re-mounted. Opts: (null)
<6>[ Â 41.053898] EXT4-fs (dm-0): re-mounted. Opts: (null)
<6>[ Â 41.064731] ADDRCONF(NETDEV_UP): wlan0: link is not ready
<6>[ Â 41.164971] EXT4-fs (dm-1): mounted filesystem without journal. Opts: (null)
<7>[ Â 41.166200] SELinux: initialized (dev dm-1, type ext4), uses xattr
<5>[  41.541558] type=1400 audit(1417297131.270:7): avc:  denied  { read write } for  pid=694 comm="coilsw.launcher" name="ump" dev=tmpfs ino=3117 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file
<5>[  41.561309] type=1400 audit(1417297131.290:8): avc:  denied  { open } for  pid=694 comm="coilsw.launcher" name="ump" dev=tmpfs ino=3117 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file
<5>[  41.579804] type=1400 audit(1417297131.310:9): avc:  denied  { ioctl } for  pid=694 comm="coilsw.launcher" path="/dev/ump" dev=tmpfs ino=3117 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file
<5>[  41.580235] type=1400 audit(1417297131.310:10): avc:  denied  { getattr } for  pid=694 comm="coilsw.launcher" path="/dev/mali" dev=tmpfs ino=3119 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file
<6>[ Â 41.671556] EXT4-fs (dm-1): re-mounted. Opts: (null)
<6>[ Â 41.684194] EXT4-fs (dm-1): re-mounted. Opts: (null)
<6>[ Â 41.811140] EXT4-fs (dm-2): mounted filesystem without journal. Opts: (null)
<7>[ Â 41.811259] SELinux: initialized (dev dm-2, type ext4), uses xattr
<6>[ Â 41.935063] EXT4-fs (dm-2): re-mounted. Opts: (null)
<6>[ Â 41.949752] EXT4-fs (dm-2): re-mounted. Opts: (null)
<6>[ Â 42.079862] EXT4-fs (dm-3): mounted filesystem without journal. Opts: (null)
<7>[ Â 42.087113] SELinux: initialized (dev dm-3, type ext4), uses xattr
<4>[ Â 42.685574] RTL871X: rtw_set_802_11_connect(wlan0) Â fw_state=0x00000008
<4>[ Â 42.711477] RTL871X: start auth
<4>[ Â 42.713152] RTL871X: auth success, start assoc
<4>[ Â 42.716862] RTL871X: assoc success
<6>[ Â 42.717972] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
<4>[ Â 42.726277] RTL871X: send eapol packet
<4>[ Â 42.728869] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 42.728880] ==> rssi_level:0, rate_bitmap:0x000ff015
<4>[ Â 42.731423] RTL871X: send eapol packet
<4>[ Â 42.750491] RTL871X: set pairwise key to hw: alg:4(WEP40-1 WEP104-5 TKIP-2 AES-4) camid:4
<4>[ Â 42.752319] RTL871X: set group key to hw: alg:2(WEP40-1 WEP104-5 TKIP-2 AES-4) keyid:1
<4>[ Â 43.076799] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 43.076846] ==> rssi_level:1, rate_bitmap:0x000f0000
<3>[ Â 43.180212] init: sys_prop: permission denied uid:1003 Â name:service.bootanim.exit
<3>[ Â 43.429893] qtaguid: iface_stat: stat_update() wlan0 not found
<6>[ Â 43.853858] EXT4-fs (dm-3): re-mounted. Opts: (null)
<6>[ Â 43.867699] EXT4-fs (dm-3): re-mounted. Opts: (null)
<6>[ Â 43.978706] EXT4-fs (dm-4): mounted filesystem without journal. Opts: (null)
<7>[ Â 43.986069] SELinux: initialized (dev dm-4, type ext4), uses xattr
<5>[  44.175428] type=1400 audit(1417297133.910:11): avc:  denied  { execute } for  pid=970 comm="Thread-63" name="libestool2.so" dev=mtdblock6 ino=4553 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:app_data_file:s0 tclass=file
<4>[ Â 44.181055] audit: audit_lost=1 audit_rate_limit=0 audit_backlog_limit=64
<3>[ Â 44.189854] audit: printk limit exceeded
<3>[ Â 44.189868]Â
<6>[ Â 44.876176] EXT4-fs (dm-4): re-mounted. Opts: (null)
<6>[ Â 44.903929] EXT4-fs (dm-4): re-mounted. Opts: (null)
<4>[ Â 45.068454] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 45.068465] ==> rssi_level:2, rate_bitmap:0x000ff000
<6>[ Â 48.971827] binder: 883:893 refcount change on invalid ref 65
<6>[ Â 48.983122] binder: 883:883 refcount change on invalid ref 65
<6>[ Â 48.987913] binder: 883:883 refcount change on invalid ref 65
<3>[ Â 48.987985] binder: transaction release 13386 bad handle 65
<4>[ Â 51.068962] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 51.068983] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 53.909682] audit: audit_lost=2 audit_rate_limit=0 audit_backlog_limit=64
<3>[ Â 53.909804] audit: printk limit exceeded
<3>[ Â 53.909817]Â
<5>[  53.909911] type=1400 audit(1417297142.575:14): avc:  denied  { open } for  pid=1391 comm="Binder_2" name="socket" dev=tmpfs ino=1035 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:socket_device:s0 tclass=dir
<7>[ Â 57.071881] wlan0: no IPv6 routers present
<5>[  57.801178] type=1400 audit(1417297146.465:15): avc:  denied  { search } for  pid=1526 comm="IntentService[S" name="/" dev=selinuxfs ino=1 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:selinuxfs:s0 tclass=dir
<5>[  57.801432] type=1400 audit(1417297146.465:16): avc:  denied  { read } for  pid=1526 comm="IntentService[S" name="enforce" dev=selinuxfs ino=4 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file
<5>[  57.801721] type=1400 audit(1417297146.465:17): avc:  denied  { open } for  pid=1526 comm="IntentService[S" name="enforce" dev=selinuxfs ino=4 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file
<5>[  57.802209] type=1400 audit(1417297146.475:18): avc:  denied  { getattr } for  pid=1526 comm="IntentService[S" path="/sys/fs/selinux/enforce" dev=selinuxfs ino=4 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file
<5>[  57.911115] type=1400 audit(1417297146.575:19): avc:  denied  { read } for  pid=1531 comm="su" name="/" dev=selinuxfs ino=1 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:selinuxfs:s0 tclass=dir
<6>[ Â 61.070677] request_suspend_state: sleep (0->3) at 61008802218 (2014-11-29 21:39:09.749863626 UTC)
<6>[ Â 61.070874] rtk_btusb: btusb_early_suspend
<6>[ Â 61.070949] rtk_btusb: load_firmware: Default lmp version = 0x1200, config file name[rtl8723a_config], fw file name[rtl8723a_fw]
<6>[ Â 61.080610] rtk_btusb: load_firmware: fw exists, config file exists
<4>[ Â 61.081248] [GSLX680] Enter gsl_ts_early_suspend
<4>[ Â 61.081342] I'am in gsl_ts_suspend() start
<6>[ Â 61.112326] rk616-hdmi rk616-hdmi.1: Removed.
<4>[ Â 61.145969] rk3188 lcdc1 clk disable...
<4>[ Â 61.146038] ------------[ cut here ]------------
<4>[ Â 61.146112] WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x54/0x1b0()
<4>[ Â 61.146179] autorequest GPIO-161
<4>[ Â 61.146231] [<c06ae410>] (unwind_backtrace+0x0/0xf8) from [<c06e1e14>] (warn_slowpath_common+0x4c/0x64)
<4>[ Â 61.146303] [<c06e1e14>] (warn_slowpath_common+0x4c/0x64) from [<c06e1ec0>] (warn_slowpath_fmt+0x30/0x40)
<4>[ Â 61.146391] [<c06e1ec0>] (warn_slowpath_fmt+0x30/0x40) from [<c08ad1e0>] (gpio_ensure_requested+0x54/0x1b0)
<4>[ Â 61.146478] [<c08ad1e0>] (gpio_ensure_requested+0x54/0x1b0) from [<c08ad58c>] (gpio_direction_output+0xa0/0x244)
<4>[ Â 61.146565] [<c08ad58c>] (gpio_direction_output+0xa0/0x244) from [<c071c384>] (early_suspend+0xd8/0x158)
<4>[ Â 61.146660] [<c071c384>] (early_suspend+0xd8/0x158) from [<c06fabc8>] (process_one_work+0x130/0x498)
<4>[ Â 61.146768] [<c06fabc8>] (process_one_work+0x130/0x498) from [<c06fb0a0>] (worker_thread+0x170/0x3cc)
<4>[ Â 61.146856] [<c06fb0a0>] (worker_thread+0x170/0x3cc) from [<c06ff1b4>] (kthread+0x80/0x88)
<4>[ Â 61.146957] [<c06ff1b4>] (kthread+0x80/0x88) from [<c06a9a08>] (kernel_thread_exit+0x0/0x8)
<4>[ Â 61.147041] ---[ end trace 004cd92259235b37 ]---
<6>[ Â 61.147442] ddrfreq: change auto self refresh to 1 when suspend
<6>[ Â 61.157946] ddrfreq: change freq to 222 MHz when suspend
<6>[ Â 67.615879] healthd: battery l=100 v=4162 t=0.0 h=2 st=5 chg=a
<4>[ Â 85.071561] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 85.071594] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 87.067356] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 87.067372] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 101.068097] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 101.068113] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 105.074046] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 105.074079] ==> rssi_level:1, rate_bitmap:0x000f0000
<6>[ Â 127.615990] healthd: battery l=100 v=4162 t=0.0 h=2 st=5 chg=a
<4>[ Â 177.068224] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 177.068240] ==> rssi_level:2, rate_bitmap:0x000ff000
<6>[ Â 187.616991] healthd: battery l=100 v=4162 t=0.0 h=2 st=5 chg=a
<4>[ Â 205.074043] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 205.074077] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 211.074042] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 211.074072] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 225.074173] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 225.074205] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 235.074049] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 235.074082] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 245.074181] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 245.074214] ==> rssi_level:1, rate_bitmap:0x000f0000
<6>[ Â 247.616948] healthd: battery l=100 v=4162 t=0.0 h=2 st=5 chg=a
<4>[ Â 257.074172] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 257.074206] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 261.074165] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 261.074199] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 281.074051] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 281.074084] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 287.074177] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 287.074211] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 305.074050] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 305.074083] ==> rssi_level:2, rate_bitmap:0x000ff000
<6>[ Â 307.616998] healthd: battery l=100 v=4162 t=0.0 h=2 st=5 chg=a
<4>[ Â 309.074049] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 309.074082] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 311.074035] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 311.074068] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 319.074168] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 319.074201] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 333.074038] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 333.074071] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 337.072668] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 337.072698] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 361.074179] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 361.074212] ==> rssi_level:2, rate_bitmap:0x000ff000
<6>[ Â 367.616987] healthd: battery l=100 v=4161 t=0.0 h=2 st=5 chg=a
<4>[ Â 379.074184] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 379.074217] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 383.074181] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 383.074214] ==> rssi_level:2, rate_bitmap:0x000ff000
<6>[ Â 398.273442] request_suspend_state: wakeup (3->0) at 398211555425 (2014-11-29 21:44:46.952616834 UTC)
<6>[ Â 398.273816] ddrfreq: change auto self refresh to 0 when normal
<4>[ Â 398.274073] rk3188 lcdc1 clk enable...
<5>[  398.318896] type=1400 audit(1417297486.985:20): avc:  denied  { ioctl } for  pid=694 comm="coilsw.launcher" path="/dev/mali" dev=tmpfs ino=3119 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file
<6>[ Â 398.350531] ddrfreq: change freq to 445 MHz when normal
<4>[ Â 398.361573] [GSLX680] Enter gsl_ts_late_resume
<4>[ Â 398.361613] I'am in gsl_ts_resume() start
<6>[ Â 398.362757] rk616-hdmi rk616-hdmi.1: Removed.
<3>[ Â 398.382282] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 2...
<3>[ Â 398.382678] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 1...
<3>[ Â 398.383071] i2c i2c-2: No ack, Maybe slave(addr: 0x40) not exist or abnormal power-on, retry 0...
<6>[ Â 398.512977] rtk_btusb: btusb_late_resume
<6>[ Â 404.843720] Enter::rk_hifi_hw_params----105
<6>[ Â 404.847993] Enter:rk_hifi_hw_params, 155, rate=44100
<6>[ Â 404.849925] Enter:rk_hifi_hw_params, 178, pll_out/div/params_rate(params) = 64Â
<7>[ Â 404.854178] i2s dma info:periodsize(4096),limit(4),buffersize(16384),over(0)
<4>[ Â 404.908091] rk616_codec_power_up : power up playback Â
<5>[  407.244253] type=1400 audit(1417297495.915:21): avc:  denied  { read write } for  pid=694 comm="coilsw.launcher" path="/dev/mali" dev=tmpfs ino=3119 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file
<4>[ Â 408.859637] rk616_codec_power_down : power down playback Â
<4>[ Â 409.068079] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 409.068092] ==> rssi_level:1, rate_bitmap:0x000f0000
<5>[  409.589270] type=1400 audit(1417297498.255:22): avc:  denied  { read } for  pid=2132 comm="su" name="/" dev=selinuxfs ino=1 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:selinuxfs:s0 tclass=dir
<5>[  409.589503] type=1400 audit(1417297498.255:23): avc:  denied  { search } for  pid=2132 comm="su" name="/" dev=selinuxfs ino=1 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:selinuxfs:s0 tclass=dir
<5>[  409.589665] type=1400 audit(1417297498.255:24): avc:  denied  { read } for  pid=2132 comm="su" name="enforce" dev=selinuxfs ino=4 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file
<5>[  409.589817] type=1400 audit(1417297498.255:25): avc:  denied  { open } for  pid=2132 comm="su" name="enforce" dev=selinuxfs ino=4 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file
<5>[  409.589984] type=1400 audit(1417297498.255:26): avc:  denied  { getattr } for  pid=2132 comm="su" path="/sys/fs/selinux/enforce" dev=selinuxfs ino=4 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:selinuxfs:s0 tclass=file
<5>[  409.708151] type=1400 audit(1417297498.375:27): avc:  denied  { entrypoint } for  pid=2143 comm="daemonsu" path="/system/bin/mksh" dev=mtdblock9 ino=181 scontext=u:r:shell:s0 tcontext=u:object_r:unlabeled:s0 tclass=file
<6>[ Â 409.991141] Enter::rk_hifi_hw_params----105
<6>[ Â 409.991259] Enter:rk_hifi_hw_params, 155, rate=44100
<6>[ Â 409.991349] Enter:rk_hifi_hw_params, 178, pll_out/div/params_rate(params) = 64Â
<7>[ Â 409.991492] i2s dma info:periodsize(4096),limit(4),buffersize(16384),over(0)
<4>[ Â 410.046280] rk616_codec_power_up : power up playback Â
<5>[  410.107772] type=1400 audit(1417297498.775:28): avc:  denied  { open } for  pid=2114 comm="terycalibration" name="ump" dev=tmpfs ino=3117 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file
<3>[ Â 410.715141] init: untracked pid 2142 exited
<3>[ Â 410.948612] init: untracked pid 2144 exited
<4>[ Â 417.415202] rk616_codec_power_down : power down playback Â
<6>[ Â 427.615348] healthd: battery l=100 v=4162 t=0.0 h=2 st=5 chg=a
<5>[  433.151340] type=1400 audit(1417297521.815:29): avc:  denied  { entrypoint } for  pid=2189 comm="daemonsu" path="/system/bin/mksh" dev=mtdblock9 ino=181 scontext=u:r:shell:s0 tcontext=u:object_r:unlabeled:s0 tclass=file
<3>[ Â 433.741035] init: untracked pid 2188 exited
<3>[ Â 433.963613] init: untracked pid 2190 exited
<4>[ Â 439.071762] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 439.071789] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 445.068066] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 445.068075] ==> rssi_level:1, rate_bitmap:0x000f0000
<6>[ Â 449.002771] healthd: battery l=100 v=4162 t=0.0 h=2 st=5 chg=a
<6>[ Â 449.022778] healthd: battery l=100 v=4040 t=0.0 h=2 st=4 chg=
<6>[ Â 449.029132] healthd: battery l=100 v=4040 t=0.0 h=2 st=4 chg=
<4>[ Â 449.068082] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 449.068096] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 455.068063] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 455.068072] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 457.068065] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 457.068073] ==> rssi_level:2, rate_bitmap:0x000ff000
<3>[ Â 465.681936] wait for new frame start time out!
<3>[ Â 470.391929] wait for new frame start time out!
<3>[ Â 471.211894] wait for new frame start time out!
<4>[ Â 481.067193] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 481.067201] ==> rssi_level:1, rate_bitmap:0x000f0000
<3>[ Â 482.081928] wait for new frame start time out!
<5>[  482.382604] type=1400 audit(1417297571.055:30): avc:  denied  { getattr } for  pid=1474 comm="android.vending" path="/dev/mali" dev=tmpfs ino=3119 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file
<3>[ Â 486.281967] wait for new frame start time out!
<4>[ Â 487.068076] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 487.068095] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 497.624843] vpu: power on
<5>[  498.881481] type=1400 audit(1417297587.545:31): avc:  denied  { write } for  pid=1617 comm="ogle.android.gm" name="property_service" dev=tmpfs ino=3195 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:property_socket:s0 tclass=sock_file
<3>[ Â 498.891993] init: sys_prop: permission denied uid:10032 Â name:sys.glibgui
<6>[ Â 500.085301] binder: 1617:1626 refcount change on invalid ref 44
<3>[ Â 500.628360] init: sys_prop: permission denied uid:10032 Â name:sys.glibgui
<6>[ Â 501.006904] binder: 1617:1626 refcount change on invalid ref 36
<4>[ Â 501.631911] vpu: power off...done
<3>[ Â 512.271946] wait for new frame start time out!
<4>[ Â 515.079219] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 515.079240] ==> rssi_level:1, rate_bitmap:0x000f0000
<3>[ Â 515.651905] wait for new frame start time out!
<4>[ Â 517.082333] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 517.082347] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 525.083890] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 525.083918] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 529.084139] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 529.084166] ==> rssi_level:2, rate_bitmap:0x000ff000
<6>[ Â 532.668480] healthd: battery l=100 v=4040 t=0.0 h=2 st=4 chg=
<4>[ Â 543.082403] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 543.082431] ==> rssi_level:1, rate_bitmap:0x000f0000
<6>[ Â 558.622461] binder: 1617:1634 refcount change on invalid ref 36
<6>[ Â 558.622561] binder: 1617:1634 refcount change on invalid ref 36
<3>[ Â 558.622648] binder: transaction release 66497 bad handle 36
<4>[ Â 569.077352] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 569.077368] ==> rssi_level:2, rate_bitmap:0x000ff000
<5>[  577.543971] type=1400 audit(1417297666.215:32): avc:  denied  { entrypoint } for  pid=2501 comm="daemonsu" path="/system/bin/mksh" dev=mtdblock9 ino=181 scontext=u:r:shell:s0 tcontext=u:object_r:unlabeled:s0 tclass=file
<3>[ Â 578.657892] init: untracked pid 2502 exited
<5>[  581.954808] type=1400 audit(1417297670.625:33): avc:  denied  { entrypoint } for  pid=2562 comm="daemonsu" path="/system/bin/mksh" dev=mtdblock9 ino=181 scontext=u:r:shell:s0 tcontext=u:object_r:unlabeled:s0 tclass=file
<3>[ Â 582.111923] wait for new frame start time out!
<3>[ Â 582.775089] init: untracked pid 2561 exited
<3>[ Â 582.994012] init: untracked pid 2563 exited
<4>[ Â 587.078080] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 587.078093] ==> rssi_level:1, rate_bitmap:0x000f0000
<6>[ Â 592.722540] healthd: battery l=100 v=4031 t=0.0 h=2 st=4 chg=
<3>[ Â 594.223255] init: sys_prop: permission denied uid:10032 Â name:sys.glibgui
<6>[ Â 594.608694] binder: 1617:2268 refcount change on invalid ref 44
<6>[ Â 594.608831] binder: 1617:2268 refcount change on invalid ref 44
<3>[ Â 594.608914] binder: transaction release 65584 bad handle 44
<6>[ Â 595.105649] binder: 1617:1626 refcount change on invalid ref 50
<6>[ Â 595.107988] binder: 1617:1626 refcount change on invalid ref 52
<6>[ Â 595.292643] binder: 1617:1642 refcount change on invalid ref 52
<6>[ Â 595.292725] binder: 1617:1642 refcount change on invalid ref 52
<3>[ Â 595.292777] binder: transaction release 100789 bad handle 52
<3>[ Â 595.367341] init: sys_prop: permission denied uid:10032 Â name:sys.glibgui
<6>[ Â 595.706494] binder: 1617:1626 refcount change on invalid ref 34
<5>[  597.342617] type=1400 audit(1417297686.015:34): avc:  denied  { read } for  pid=2609 comm="dboxed_process0" path=2F6465762F6173686D656D2F64616C76696B2D68656170202864656C6574656429 dev=tmpfs ino=3372 scontext=u:r:isolated_app:s0 tcontext=u:object_r:init_tmpfs:s0 tclass=file
<5>[  597.494956] type=1400 audit(1417297686.165:35): avc:  denied  { getattr } for  pid=2609 comm="re-initialized>" path="/data/app" dev=mtdblock6 ino=24482 scontext=u:r:isolated_app:s0 tcontext=u:object_r:apk_data_file:s0 tclass=dir
<5>[  597.508100] type=1400 audit(1417297686.175:36): avc:  denied  { read } for  pid=2609 comm="re-initialized>" path=2F6465762F6173686D656D2F64616C76696B2D68656170202864656C6574656429 dev=tmpfs ino=3372 scontext=u:r:isolated_app:s0 tcontext=u:object_r:init_tmpfs:s0 tclass=file
<3>[ Â 597.691986] wait for new frame start time out!
<5>[  597.742471] type=1400 audit(1417297686.415:37): avc:  denied  { write } for  pid=2627 comm="DnsConfigServic" scontext=u:r:untrusted_app:s0 tcontext=u:r:untrusted_app:s0 tclass=netlink_route_socket
<3>[ Â 613.722012] wait for new frame start time out!
<3>[ Â 614.541925] wait for new frame start time out!
<3>[ Â 617.282021] wait for new frame start time out!
<3>[ Â 630.621998] wait for new frame start time out!
<3>[ Â 637.152044] wait for new frame start time out!
<3>[ Â 643.092007] wait for new frame start time out!
<3>[ Â 643.271954] wait for new frame start time out!
<4>[ Â 651.078072] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 651.078080] ==> rssi_level:2, rate_bitmap:0x000ff000
<6>[ Â 652.774224] healthd: battery l=100 v=4022 t=0.0 h=2 st=4 chg=
<3>[ Â 670.081986] wait for new frame start time out!
<5>[  671.922320] type=1400 audit(1417297760.595:38): avc:  denied  { getattr } for  pid=2889 comm=".office:browser" path="/data/app" dev=mtdblock6 ino=24482 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:apk_data_file:s0 tclass=dir
<3>[ Â 673.601934] wait for new frame start time out!
<3>[ Â 673.692144] wait for new frame start time out!
<3>[ Â 673.741978] wait for new frame start time out!
<3>[ Â 673.782005] wait for new frame start time out!
<3>[ Â 673.832205] wait for new frame start time out!
<3>[ Â 674.061936] wait for new frame start time out!
<3>[ Â 674.421913] wait for new frame start time out!
<3>[ Â 674.472536] wait for new frame start time out!
<3>[ Â 674.791945] wait for new frame start time out!
<3>[ Â 676.421051] init: sys_prop: permission denied uid:10008 Â name:sys.glibgui
<3>[ Â 676.476548] init: sys_prop: permission denied uid:10008 Â name:sys.glibgui
<3>[ Â 678.343636] init: sys_prop: permission denied uid:10067 Â name:sys.glibgui
<3>[ Â 678.467028] init: sys_prop: permission denied uid:10067 Â name:sys.glibgui
<3>[ Â 692.061495] init: sys_prop: permission denied uid:10008 Â name:sys.glibgui
<3>[ Â 693.031438] init: sys_prop: permission denied uid:10067 Â name:sys.glibgui
<6>[ Â 703.026285] healthd: battery l=99 v=3996 t=0.0 h=2 st=4 chg=
<6>[ Â 703.027085] healthd: battery l=99 v=3996 t=0.0 h=2 st=4 chg=
<4>[ Â 713.081260] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 713.081282] ==> rssi_level:1, rate_bitmap:0x000f0000
<3>[ Â 722.201942] wait for new frame start time out!
<3>[ Â 729.294008] init: sys_prop: permission denied uid:10032 Â name:sys.glibgui
<6>[ Â 729.803599] binder: 1617:1626 refcount change on invalid ref 44
<6>[ Â 729.917388] binder: 1617:1640 refcount change on invalid ref 44
<6>[ Â 729.917517] binder: 1617:1640 refcount change on invalid ref 44
<3>[ Â 729.917596] binder: transaction release 160252 bad handle 44
<3>[ Â 730.011567] init: sys_prop: permission denied uid:10032 Â name:sys.glibgui
<3>[ Â 730.205942] init: sys_prop: permission denied uid:10032 Â name:sys.glibgui
<6>[ Â 730.870065] binder: 1617:1626 refcount change on invalid ref 44
<4>[ Â 731.078843] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 731.078854] ==> rssi_level:2, rate_bitmap:0x000ff000
<3>[ Â 736.631933] wait for new frame start time out!
<6>[ Â 738.022657] healthd: battery l=98 v=4013 t=0.0 h=2 st=4 chg=
<6>[ Â 738.023092] healthd: battery l=98 v=4013 t=0.0 h=2 st=4 chg=
<4>[ Â 739.078601] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 739.078622] ==> rssi_level:1, rate_bitmap:0x000f0000
<4>[ Â 743.078071] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 743.078086] ==> rssi_level:2, rate_bitmap:0x000ff000
<4>[ Â 765.412303] select 1474 (android.vending), adj 15, size 16861, to kill
<4>[ Â 765.412371] send sigkill to 1474 (android.vending), adj 15, size 16861
<4>[ Â 765.813040] select 1821 (d.process.media), adj 15, size 7277, to kill
<4>[ Â 765.813107] select 2003 (hbullet.android), adj 15, size 7347, to kill
<4>[ Â 765.813162] select 2077 (ainfire.supersu), adj 15, size 7979, to kill
<4>[ Â 765.813222] send sigkill to 2077 (ainfire.supersu), adj 15, size 7979
<4>[ Â 766.096536] select 1821 (d.process.media), adj 15, size 7277, to kill
<4>[ Â 766.096671] select 2003 (hbullet.android), adj 15, size 7347, to kill
<4>[ Â 766.096777] select 2092 (ngs.android.pop), adj 15, size 7969, to kill
<4>[ Â 766.096906] send sigkill to 2092 (ngs.android.pop), adj 15, size 7969
<4>[ Â 766.713180] select 1821 (d.process.media), adj 15, size 7277, to kill
<4>[ Â 766.713299] select 2003 (hbullet.android), adj 15, size 7312, to kill
<4>[ Â 766.713384] select 2916 (s.office:search), adj 15, size 7794, to kill
<4>[ Â 766.713433] send sigkill to 2916 (s.office:search), adj 15, size 7794
<3>[ Â 769.292048] wait for new frame start time out!
<4>[ Â 785.079381] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 785.079404] ==> rssi_level:1, rate_bitmap:0x000f0000
<3>[ Â 785.602011] wait for new frame start time out!
<3>[ Â 786.241976] wait for new frame start time out!
<4>[ Â 787.078217] UpdateHalRAMask8192CUsb => mac_id:0, networkType:0x0b, mask:0x000fffff
<4>[ Â 787.078239] ==> rssi_level:2, rate_bitmap:0x000ff000
<6>[ Â 790.258261] binder: 1617:1626 refcount change on invalid ref 44
<5>[  790.664162] type=1400 audit(1417297879.335:39): avc:  denied  { entrypoint } for  pid=3416 comm="daemonsu" path="/system/bin/mksh" dev=mtdblock9 ino=181 scontext=u:r:shell:s0 tcontext=u:object_r:unlabeled:s0 tclass=file
Thx mate
KitKat, selinux kernel, RTL8723 wifi-chip.
No generic build avialable for that.
94 Guest(s)
Devices in use: Desktop (78), Phone (16)
titi1975
artnovabobo
sebnju
miami76
Cellarin
kuzin
