Gents,
this is a generation 1 loader build for Trekstor Tolino Tab 8.9. Wifi chip is AP6476
240 dpi fix (install via CWM)
– stock 4.2.41 recovery, CWM 6.0.3.1 recovery
– system ext4
– kernel jack #23
– internal storage 4 GB
– Multi-User
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Instructions are included in the download pack.
A few hints:
– higher performance > disable animation scales in developer options
– don't show su notifications > disable in Superuser
– to prettify the build use Xposed Framework > JB Starter Pack
– Oma -
friendman0806, bobonsPer aspera ad astra, we rock the Tablets !
70 Guest(s)
Devices in use: Desktop (62), Phone (8)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
