2015/06/04
Hi everyone,
Is it possible to flash Kitkat 4.4.2 in this 10.1in tablet?
Vendor/Download page: http://www.primux.es/producto.aspx?id=238#ctrl2prodes1_lblCaracTit
-Hardware:
RK3188-T
RTL8188ETV
Mali400
Buttons are, vol-, vol+ and power
-Software:
Kernel 3.0.36+
Android 4.2.2
Build rk30sdk-eng 4.2.2 JDQ39 eng.ccz.20131025.0326BU.102426 test-keys
Here is the link of the dump from the vendor update file:
https://www.dropbox.com/sh/bfy7km9eoi6qr05/AAAK8-zjjEHpWhWWZCH9VX2Pa?dl=0
I'll run all the tests you need and give all the feedback.
Thanks =)
2015/06/04
Here is the dmesg log:
I've flashed a lot of 4.4 roms but i always get a white flash and then black screen. The back light turns on, nothing else happens, when i flash the vendors 4.2.2 update, it boots ok.
Try this build: http://crewrktablets.arctablet.com/?p=3555
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2560
Parameter: http://crewrktablets.arctablet.com/?wpfb_dl=2033
Just change the parameter file in folder rockdev and the kernel in folder rockdev/Image before flash.
In CWM do a factory reset and install the 160dpi fix: http://crewrktablets.arctablet.com/?wpfb_dl=2013
JaYmEzPer aspera ad astra, we rock the Tablets !
2015/06/04
First of all, thank you Oma for your reply!!
I've used the build cRom v1.4.1 from the first link on your reply, replaced the parameter file on the rockdev folder (renamed it to parameter) and the kernel file in the rocdev/image folder and then opened the RKAndroidTool, the flashing process went ok, but in the end the tablet doesn't get out of the flashing mode, even after i push the reset button it gets back to flashing mode without pressing any other button.
Normally when the flashing process ends the tablet tries to boot.
Did you execute eraseIDB?
Ok, found something strange. The kernel from your dump does not have a kernel string. So, it can't boot.
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2560
2015/06/04
Now it's working, you did it, thank you very much, when the flashing process ended it booted into the recovery menu, i followed your instructions and rebooted.
First boot took a while, i think it's normal, wifi, sound, buttons ar working well.
From what i've noticed only rotation isn't working.
Here is a picture from the "about this table" page:
Once again you did a great job! You can add this model in the roms page.
Thank you! =)
Fine. Is it just orientation or is the screen not rotating?
Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2561
So, 180 degrees wrong? Is it still the same when you set the app to auto?
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2561
54 Guest(s)
Devices in use: Desktop (47), Phone (7)
