[ ROM ] RADXA ROCK Android 4.4.2 KitKat custom root firmware (2014/04/02)
cappybob
Forum Posts: 79
Thanks Received: 8
46
2014/07/23 - 23:50
Unbricked, loader 1.24 flashed, still not loading a proper format for nand addresses for images  Stuck in a CWM reboot mode.  Started this series flashing with an empty nand, so needs some work for the Radxa.  Tried to format nand with the iron format, but that was useless.
Cappybob
47
2014/07/24 - 07:14
Go back to the gen2 loader build (post #1) first.
cappybob
Forum Posts: 79
Thanks Received: 8
48
2014/07/24 - 20:35
gen2 kk or Omni, confussion.  loaded 422 with jb kernel now to check addresses.  Could not find a gen2 Omni.
Went back loaded the kk on post#1, tried the same basically with Omni, with cwm recovery change.  Did not work, checked with Linux and again the parameter file is not installing.
cappybob
Forum Posts: 79
Thanks Received: 8
49
2014/07/25 - 20:32
Radxa update.
Have got Omni to load with resolution @ 480 navigation bar seems to be off screen and the com.android.systemui error.  Everything seems to work as ticking ok on error and proceding one step at a time.  Had to change parameter file and image addresses to get parameters to load.  Changed to (OMA 4.2.2 Radxa JB).  To load without this change yields nothing.  Still looking for solution.
cappybob
cappybob
Forum Posts: 79
Thanks Received: 8
50
2014/07/26 - 20:12
RADXA OMNI WORKING.
The loading is fine the way described by OMA.
All my mistakes are because old and set in my ways, and radxa tempermental.
You must use the CM11 160 dpi fix in CWM  (Com.android.systmui error is cured with this)
you must erase factory and data in CWM
when reboot is selected ignore and enter (NO) to following questions
WAIT is LENGTHY clos3e to 5-7 minutes to boot initially
Thanks cappybob
cappybob
Forum Posts: 79
Thanks Received: 8
51
2014/07/27 - 04:38
RADXA CM11.0
Have had a good weekend, too hot to be out side, so allowed to play inside.  Have got the CM 11.0 running with the WiFi issue which is a problem it seems.  The procedure above is used, with the addition of the Parameter change for 8G tabs.  Must change this much like the kernel procedure before loading program.  Unzip and exchange with existing parameter, then follow above procedure.
cappybob
52
2014/07/27 - 11:39
Fine!
Pls use the Omni 160dpi fix: http://crewrktablets.arctablet.com/?p=3555
We will release a stable CM11 build in due time.
iRad
53
2014/07/27 - 13:32
OMA's custom ROM was working fine, but out of curiosity I flashed the official Radxa 4.4 image http://dl.radxa.com/rock/images/android/radxa_rock_pro_android_kitkat_hdmi_140725_update.zip and my Rock is no longer giving any signal on HDMI. What could have gone wrong, I had tried :
1). Erasing IDB.
2). Flashing the Android Parameter file from - http://dl.radxa.com/rock/images/parameter/parameter_android_nand
3). Re-flash the official image a second time.
Pls. help...
54
2014/07/27 - 16:29
Pls note this is an image for the new hardware revison
Revision 2014.06.10(Rock Pro)
This is the new hardware revision for the rock based on the feature requirement from the community. The major improvement are:
  • Add LVDS interface(FPC connector at the bottom of the board)
  • Add touch panel interface
  • Add CSI interface for camera module
  • Add speaker driver circuit on board
  • Others remains the same of the rock
Go back to the build in post #1.
cappybob
Forum Posts: 79
Thanks Received: 8
55
2014/07/27 - 22:05
RADXA CM 10.1 4.3.3 Running
Have loaded and running CREWRKTablets Iron CM 10.1 on Radxa.  Load pretty much the usual for the IRON loads.  Change to JB Kernel in IMAGE directory and in CWM install the 160 dpi fix from ext sd card, then erase factory and data, then reboot with No, No and let boot into CM10.1 in 5min.
Thanks again OMA
-cappybob
56 Guest(s)
Devices in use: Desktop (47), Phone (9)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
