This is a generation 2 loader KK build for RK903 wifi  Â
Pipo U8 by Oma KitKat build v1.2
– system ext4
– selinux kernel alex #603 preempt 14.04.2014
– internal storage 4 GB
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Bugfix: change the boot.img in folder rockdev/Images before flash.
Gen2 loader firmware will frequently generate trouble for the user. So, please read
the instructions carefully to understand how to change between gen1 (v1.24 loader)
and gen2 (v2.10 loader) firmware.
hints:
– do not install google+ from Play Store; use this one (can be updated later)
– to improve UI feeling disable animation scales in developer options
– to disable su notifications change notification in su app
– to prettify the build use Xposed Framework > Starterpack
 – Oma -
adminPer aspera ad astra, we rock the Tablets !
Hm, works for me.
Delete the app in /system/app and do a factory reset.
Pls change the boot.img: http://crewrktablets.arctablet.com/?wpfb_dl=1903
Use RKAndroidTool. Just tick parameter and boot, then Run.
43 Guest(s)
Devices in use: Desktop (33), Phone (10)
nikitamaan
VMILCINOV
