Thanks Received: 1381
106
2014/08/06 - 17:10
What tab? What firmware?
I guess you are on a gen2 loader build. Then you need to change the loader first to run a gen1 loader build. See hints in post #1.
iRad
107
2014/08/07 - 04:09
I am using a Radxa Rock (first batch) and flashed Tom Cubi's official 4.4 image before this.
cappybob
Forum Posts: 79
Thanks Received: 8
108
2014/08/07 - 04:27
iRad  Oma is asleep right now, so use the non-Selinux JB Kernel.  All of Tom's will be Selinux.
Try this one, works for me http://crewrktablets.arctablet.com/?wpfb_dl=1032
iRad
109
2014/08/07 - 05:11
cappybob said
Thanks, I wanted Selinux to be off - any ideas how to flash this one on the Tom's version?
cappybob
Forum Posts: 79
Thanks Received: 8
110
2014/08/07 - 06:29
 @ iRad
The kernel structure is different.  Oma's builds include a System.img along with a Kernel.img.  The Radxa builds seem to have a System and Kernel.img which is a single image.  Without a source to build your own kernel.image for the Oma release, I don't think it can be done.  As far as the Selinux kernel being on and off, this can be edited in a rooted system in the /system/build.prop to be on or off (1 or 0) yes or no (true or false)?  Not sure which syntax,  but I have ran across it in the  /system/build.prop that is running the Selinux kernel.  Also the build for this flavor is I believe a 30xx, 31xx build and is not a true KitKat build, but one which will allow the 3.0.8 and 3.0.32 kernels to build into 4.4.x.  Could be wrong, but I think this is what I have seen doing a little hacking on it.  Maybe Oma can straighten me out.
hnito82
Forum Posts: 11
111
2014/08/08 - 10:53
Build v1.3.1: http://crewrktablets.arctablet.com/?p=3555
Kernel MP84S4: http://crewrktablets.arctablet.com/?wpfb_dl=1790
Just change the kernel in folder rockdev/Images before flash.
In CWM do a factory reset and install the 160dpi fix.
Ho trovato questa guida ma va bene?
Al posto della rom Oma RK31 KK metto la Build v1.3.1, e devo inserire il modem fix mediacom?
Grazie Mille
1. Scaricare il rar della ROM e scompattarlo sul desktop. link > https://mega.co.nz/#!Tkx2wJJK!lN96kF...3Tq8sd8r8z0Eew
2. Fate un backup a tutti i dati della vostra microsd
3. Formattate la microsd in fat32 e dimesione di allocazione predefinita (al pc) o formattarla prima con il tablet
4. Copiare dentro la microsd i file ZIP "Oma RK31 KK v2.1 Format NAND" & "Oma_V88_KK_v2.3_model fix_Mediacom_MP84S4"
5. Spegnere completamente il tablet già CARICO! almeno il 50% di batteria!
6. rimettere la microsd nel tablet con solo i due file indicati al punto 4.
7. Spengere internet dal vostro computer, assicurateneve che non carica più le pagine sul browser.
8. Tenete premuto il tasto volume su' (vol+) con il tablet completamente spento e tenendo tenuto il tasto vol+ collegare il tablet al pc con il cavo in dotazione.
9. Windows riconoscerà una nuova periferica, NON fate installare il driver automaticamente, ma usate i driver presenti nella cartella "Drivers" del rar della ROM scompattato sul desktop. Usare l'opportuna versione a seconda del vostro sistema operativo (xp, 7, 8, 32/64bit)
10. Andate su "gestione dispositivi" e sopra il device non riconosciuto fate "aggiorna driver" e mettete "manualmente" successivamente mettete il percorso che vi porterà alla cartella del driver corretto per il vostro pc.
11. Se usate il driver corretto in "Gestione Dispositivi" avrete una periferica che si chiama "Rockusb Device" con un piccolo "?" vicino.
12. Recarsi nella cartella "RKDevelopTool_v1.37" del rar della ROM ed avviare con diritti di amministratore il file "RKAndroidTool.exe" (tasto destro-Esegui come amministratore)
13. Assicurarsi che in basso appaia la scritta "Found RKAndroid rock usb". Se non appare non avete installato i driver correttamente.
14. Togliete la spunta sulla riga colorata di verde (loader)
15. Cliccate su EraseIDB e aspettate che finisca il processo.
16. Cliccate su "RUN" senza toccare altro e aspettare che finisca la procedura.
17. Al termine il tablet si avvierà da solo in recovery .
18. staccate il cavetto usb.
19. Usando i tasti volume su e volume giù per muoversi e il tasto power per confermare, andate su "install zip from sdcard"
20. "choose zip from external sdcard" Scegliete il file "Oma RK31 KK v2.1 Format NAND" precedentemente copiato e confermate con yes.
21. Si avvierà Aroma, scegliete "FULL format" e aspettate che finisca e date "finish" e vi ritroverete in recovery.
22. ora "choose zip from external sdcard" Scegliete il file "Oma_V88_KK_v2.3_model fix_Mediacom_MP84S4" e date yes!
23. ora dovrete fare un'altra volta "choose zip from external sdcard" Scegliete il file "Oma_V88_KK_v2.3_model fix_Mediacom_MP84S4" e date yes!
24. non sto ripetendo.. dovete veramente averlo eseguito due (2) volte!
25. Tornate alla schermata iniziale della recovery e andate su "reboot system now".
26. ora vi comparirà da scegliere no o yes. voi premete di nuovo il pulsante di accensione (dovete dare no!)
27. ancora insisterà nel chiedervi no o yes su un'altra cosa, voi continuate a premere il pulsante di accensione (dovete dare no!)
28. Attendete il riavvio del tablet, ci metterà un po' è normale.
nelySLB
Forum Posts: 34
112
2014/08/14 - 00:04
this works on U30GT2 ?
Bachan
114
2014/08/15 - 10:12
Good Day,
Sir Oma
I have tried installing this on my tablet an FNF IFIVE Mini 3 "Non Retina Model"
Using this Kernel: RK31 Kernel 3036 Mini3 Ifive
was able to boot it
the Problem is Wifi and Bluetooth are not working
I've check some model fixes and the one only working is this w/ a reversed rotation
AOC Q70S15 = http://crewrktablets.arctablet.com/?wpfb_dl=1910
"I really dislike the dual volume buttons in the Navigation bar though"
___
Have the same problem w/ the latest CM11 too. but last build (1.0) runs w/o modifications, Wifi that is
It would be beneficial for us IFIVE mini3 Non Retina Users for a smooth custom rom
Thanks.
EDIT:
Ok its not just the AOC Model fix but a combination of both w/ the Qilive Model Fix
Standalone w/ the Qilive = Bluetooth Works | No Wifi | Landscaped Orientation (@Tablet in Vertical Position)
Standalone w/ AOC = None Works (Upsided Down Rotation)
Mixing Both = as of Build 1.3 Wifi Works (Upsided Down Rotation)
115
2014/08/15 - 14:38
Pls provide a dmesg log of a working firmware.
Bachan
116
2014/08/15 - 17:22
Ifive Mini3 Non Retina (Kasty's Rom) Android 4.4.2
DMESG
would the fixes here be interchangeable w/ the latest build of CM11?
117
2014/08/15 - 22:40
Update to build v1.4 with Omni multi-window approach.
v1.4_01.pngImage Enlarger
118
2014/08/15 - 22:51
DMESG
Ok, ifive mini3 has AP6210 wifi.
Try build v1.4 with this model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2012
Bachan
Bachan
119
2014/08/16 - 07:19
DMESG
Thank you Sir, will try to test it later and give results :D
SquareMan
120
2014/08/16 - 17:29
Ok, Pipo M9 pro has AP6476 wifi. Check out the latest Omni v1.4 build: http://crewrktablets.arctablet.com/?p=3555
Use this model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2010
Hi, Oma
Which kernel should I use?
RK31 Kernel 3036 Hr M9pro Pipo (2.6 MiB)
or
RK31 Kernel 3036 Hr M9pro Pipo 2 (2.6 MiB)
Thanks!
114 Guest(s)
2 Guest(s)
Devices in use: Desktop (101), Phone (12), Tablet (1)
quodiddle
dakarpesca
Andrews666
Jonny2020
passsaris
sepa1999
