91
2014/07/23 - 15:29
No, mt5931 wifi is not implemented yet.
mateusz
92
2014/07/23 - 15:48
will the new rom on Cube U9GTV ?
93
2014/07/23 - 16:00
Well, we are still working on the mt5931 wifi implementation. I do have also a tab with mt5931 wifi (Chuwi V88) ... so time will come ;-)
Jammed_Death
Forum Posts: 51
94
2014/07/25 - 09:57
hi, if i use the fix for qilive and archos for the 4.4.2 version can i install the 4.4.4 version?
95
2014/07/25 - 14:57
Yes, should work.
cappybob
Forum Posts: 79
Thanks Received: 8
96
2014/07/26 - 03:44
Oma:
RADXA is still no go.  The original parameters are not being recognized in build.  Not building at all with kernel replacement (JB Your Oma non-selinux).  Have booted and ran the Radxa 4.2.2 JB (the build from which I am using kernel from).  So I have taken this build and replaced the Image directory with the Omni build Directory and kernel change to JB.  I now get a boot and install with two major problems 1) The display is running in a 480 AV format over HDMI and 2) com.android.systemui error.  Between ticking OK and one step movement to next screen, everything seems to work except for the 2 mentioned above.  Still seeing what can be done and will try cube30gth dual next.  On radxa checked the cm11 and the same parameters are used here also, will see if I can get cm11 to work on radxa also, if not will push as above and see if I get same results.
cappybob
Forum Posts: 79
Thanks Received: 8
97
2014/07/26 - 20:21
RADXA OMNI WORKING.
The loading is fine the way described by OMA.
All my mistakes are because old and set in my ways, and radxa tempermental.
You must use the CM11 160 dpi fix in CWM  (Com.android.systmui error is cured with this)
you must erase factory and data in CWM
when reboot is selected ignore and enter (NO) to following questions
WAIT is LENGTHY clos3e to 5-7 minutes to boot initially
Thanks cappybob
The following users say thank you to cappybob for this useful post:
pmerrill
Forum Posts: 23
98
2014/07/30 - 03:38
Given that I'm still having problems with my Vido n80rk freezing for periods due to rknand_buffer chewing up CPU, I'm really thinking that it's a problem with the kernel some how. So, a solution is to replace the Vido n80rk kernel with another kernel that will hopefully support all the hardware and perhaps fix the problem.
Does anyone have any suggestions of a kernel that is known to work with this device or people may think will work on this device?
Here's a link to the exact device: http://www.yuandaocn.com/product_details.aspx?id=39
hnito82
Forum Posts: 11
99
2014/08/04 - 12:04
Update post #1 with build v1.1.
v1.1_01.pngImage Enlarger
Hello Oma, this rom can be installed on tablet Mediacom 8 S4?
I tried another rom 4.4.2 but I create a lot of problems when I turn on wifi and I get bored very much to not use it!
Could you help me I would be very grateful, Thanks
hnito82
Forum Posts: 11
101
2014/08/04 - 19:19
Mediacom MP84S4 or which tab do you mean?
We have had some discussions here: http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/mediacom-smartpad-8-0-s4-m-mp84s4-kitkat-4-4-2-problems/
Build v1.3.1 should work for you: http://crewrktablets.arctablet.com/?p=3555
I tablet Mediacom MP84S4 and have installed Rom:
OMA KIT KAT Android 4.4.2: http://www.androidiani.com/forum/altri-tablet-mediacom/405678-rom-mp84s4-smartpad-s4-8-0-oma-kit-kat-android-4-4-2-a.html
so just drain and install rom without changing anything ..... excuse my ignorance but are not practical enough for this I ask you a big help. Thank you very much
102
2014/08/04 - 20:07
Build v1.3.1: http://crewrktablets.arctablet.com/?p=3555
Kernel MP84S4: http://crewrktablets.arctablet.com/?wpfb_dl=1790
Just change the kernel in folder rockdev/Images before flash.
In CWM do a factory reset and install the 160dpi fix.
hnito82
hnito82
Forum Posts: 11
103
2014/08/05 - 10:37
Thank you very much Oma, but the fix 160dpi where is it?
help me by writing a guide for installation or if you have one already completed?
104
2014/08/05 - 17:06
See first link to the v1.3.1 build. There you will find the instructions and the fixes.
hnito82
iRad
105
2014/08/06 - 07:41
Hi Oma,
I tried flashing this on the stock 4.4 ROM by TOM but it fails with following logs - http://pastebin.com/bR3C3vcH, any pointers - I am a newbie to all this.
sshot-4.pngImage Enlarger
91 Guest(s)
Devices in use: Desktop (82), Phone (9)
karim78190
mario millan
estelavg
Skyzhay
HorstG
techboy
