76
2014/07/14 - 15:19
livendead said
I've did a little research on the app pre-installed "Entropy Fixer"(Value= 256), and I believe that has made a large difference. I've had zero random reboots, and no lock/wake lockups, reboots, or crashes since I put the value to 256. Do you suggest a certain value, and can you confirm if this is wise for me to do?
Test v1.2 - Auto-rotation is also partially working on the ROM, the above rotation error in ROM v1.3 is identical to this version as well. Auto-rotation sensors are working, but it's "tap&hold" is not working on Landscape mode. Portrait mode is fine, just like version 1.3!
WiFi confirmed working,
Bluetooth confirmed working too!
HDMI is confirmed implemented!
Ok, then it is more kernel then build related. Go for build v1.2.1 and install the V88 rotation fix.
Yes, value=256 is the optimum.
livendead
pmerrill
Forum Posts: 23
77
2014/07/15 - 11:03
pmerrill said
Oma,
I've attached dmesg.log.
Hm, isn't there. Could you pls try again?
78
2014/07/15 - 16:45
Sorry again. I need a log from 0.00000 sec. Boot tab fresh and do again.
pmerrill
Forum Posts: 23
79
2014/07/16 - 00:50
The following users say thank you to pmerrill for this useful post:
80
2014/07/16 - 22:06
Build v1.3.1
- updated code
- hdmi settings functional
- minor changes on overlays
v1.3.1.pngImage Enlarger
Rock293031
Forum Posts: 39
81
2014/07/17 - 01:26
Hi Oma,
i tested your 1.3.1 build on my RK3066/RK903 tab.
After creating my own model fix for imuz TX12D (Kombi aus AOC und Qilive) it is running good.
Sensors, Rotation, Camera, BT, WIFI, HDMI all working.
The only thing is, i am getting a red frame in 1.3.1 when starting some applications. (roter Rahmen erscheint manchmal beim Start von Apps oder bei Update von Apps). This is new compared to 1.3. But "Aggressive Desktop" in Nova Settings has made it better.
Still i have the problem after updating Google Play Services/Dienste the tab does not boot anymore. But i have deinstalled Hangouts now.
Grüsse!!
Edit: When i hold an app on desktop or in the app overview to move the position the screen rotates 180°. Is there a setting for this?
Wenn ich eine App auf den Desktop verschieben will und diese gedrückt halte, dreht sich der Bildschirm um 180°. Kann man das irgendwo abstellen?
Edit2: Settings->Startseite  -> "Einstellungen" wurde beendet FC.
Rock293031
Forum Posts: 39
83
2014/07/17 - 20:10
Hi Oma,
thanks for this. I had to set Rotate.app to Auto then back to Force Auto and now the display rotates correctly and i can move my apps/widgets on my desktop and in the app drawer. No more strange 180° display-flip.
Grüsse
Edit: my BT is now FC when booting the tab. BT-Freigabe beendet. dmesg attached if this helps
pmerrill
Forum Posts: 23
84
2014/07/18 - 01:49
Vido n80rk still laggy.
There has got to be a problem with the hardware or the kernel on this tablet that makes it laggy. I have two tablets based on the RK3188 chip, the n80rk and an iFive X2. The iFive's battery lasts for three days with pretty heavy use. Watching video for 1-2 hours every day. With my n80rk, it will drain the battery in a day and I'm doing nothing more than browsing the web for an hour or so. The rknand_buffer process takes up 5% of the CPU when I'm doing nothing and at it's worst, I get the xxx isn't responding Do you want to close it? Wait/Report/Ok messages appearing.
I will look at flashing another kernel but I'm not sure that's going to work because it really needs to be a kernel from the manufacturer, doesn't it?
In case I do try a different kernel, can I just flash the new kernel only using the RKDevelopTool_v1.37 and unticking all the items except the kernel, or do I have to flash everything?
85
2014/07/21 - 16:14
Rock293031 said
Hi Oma,
This is a bug in the current build.
Try to also copy over power.rk30xx.so and power.default.so.
FC of BT may driven by the BT libs. I don't know what is in the model fix.
Can you pls share the model fix?
Rock293031
Forum Posts: 39
86
2014/07/21 - 19:10
Hi Oma,
my modelfix is a combination of your AOC Q70S15 (BT, Sensors) and the Qilie97r (Cam, WiFi) and a modified build.prop
Its attached.
I will extract now the stock to see what lib is used for BT there.
Many, many thanks for all your hard work!!!
Grüsse!!!
Edit: The stock libbt-vendor.so is 17.4kb, the one i used 17.5kb. I will change them to see what will happen
Edit2: No success. Stock libbt-vendor.so is causing same FC
Edit3: Flashed again 1.3.1. Works for now without errors. BT works, can connect to other device but shows very often "Client already in an operation".
What is the advantage to use stock power.rk30xx.so and power.default.so? DANKE!!!!!!!!!!!!!!!!
Rock293031
Forum Posts: 39
87
2014/07/22 - 11:34
Hi Oma,
unfortunately i had to reset the tab again. During the installation of my last purchases (3-4GB) the tab battery became very hot and apps started to FC randomly. After that the tab did not start anymore showing lots of "permission denied" in the dmesg. Factory reset brought it back to life.
Hallo Oma,
Leider musste ich das tab wieder in den Ursprugszustand zurücksetzen. Beim Download meiner letzten Käufe (3-4GB) wurde die Batterie extrem heiss. System-Apps stürzten auf einmal willkürlich ab. Habs mal abkühlen lassen und danach neu gestartet. Aber das Tab blieb bei der Boot-Animation hängen und zeigte im dmesg lauter Meldungen über fehlende Berechtigungen. Über einen Factory Reset konnte es wiederhergestellt werden auf läuft wieder. Ich mache nochmal einen Test mit so einem Massendownload um zu schauen, ob es wieder passiert.
Grüsseeee!!!
Rock293031
Forum Posts: 39
88
2014/07/22 - 23:03
Hi Oma,
today i flashed again 1.3.1 newly. 8GB Paramter File and Model Fix.
After 5th or 6th installation of apps the tab makes errors. Memory shows 4GB free.
Attached the logs from boot.
Grüsse!!
89
2014/07/23 - 06:48
Do not use the old 8 GB parameter. Build has unified internal storage. So use the pack as is.
mateusz
90
2014/07/23 - 14:40
Rom works on Cube U9GTV?
88 Guest(s)
Devices in use: Desktop (79), Phone (9)
karim78190
mario millan
estelavg
Skyzhay
HorstG
techboy
