Pls use this one: http://crewrktablets.arctablet.com/?wpfb_dl=2704
2015/03/31
Hello dear Oma, i trying to port your firmware with android 4.4.2 RK3188 on my tablet DNS M100qw RK3188, everything works except wifi, i have chip - mt6620 combo driver; I copied all modules from stock in port(system/lib/modules), edited init.rc from port - added lines about mt6620 from stock; lsmod showed me - all modules run, exactly as stock firmware, but wifi is not work, help please, i can send you dmesg log from port and from stock:)
Did you see the loader? http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/kitkat-rom-request-for-skyworth-x7010dns-airtab-p70qw/page-2/?lang=fr#p43667
Let me have the logs.
2014/01/22
I am having an issue with USB Hubs (both 7 ports self powered and 4 ports versions), it seems they are recognized but ignored.
dmesg:
[ 3088.403313] usb 1-1: new high speed USB device number 2 using usb20_otg
[ 3088.614499] usb 1-1: New USB device found, idVendor=14cd, idProduct=8601
[ 3088.614558] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 3088.614609] usb 1-1: Product: USB 2.0 Hub
[ 3088.614648] usb 1-1: Manufacturer: USB Device
[ 3088.616230] hub 1-1:1.0: ignoring external hub
(this USB HUB works fine with 4.4.4 Android in Sony tablet)
Otherwise, USB OTG works fine. And connected one at a time USB devices work OK (gamepad, memory stick etc..). The issue is with the Hub alone.
With Hub connected to tablet, USB Device Info App (same goes with USB Host Diagnostics) App reports:
- KERNEL section: connected USB devices are identified and shown (but do not actually work)
- API section: No Devices Detected
So, it seems to be some sort of configuration issue.
I found this info elsewhere, not sure if it applies:
"If arnova used the RK kernel was compiled blacklisting usb hubs they will be ignored. In .config we have this line:
CONFIG_USB_OTG_BLACKLIST_HUB=y"
Does anyone have a clue on how to fix this?
PS: I am running 1.4.1 with qilive97 kernel.
Our server is down, sorry. Try again tomorrow.
Server is back.
2017/12/03
any idea how to make update.img from this package?
i want to use update.img as firmware in android tool or rkbatchtool ? my tablet (yarvik tab09-410) is in MASKROM-mode. after flashing an IMG-file, i stuck in WAIT LOADER FAIL. and after this i cannt boot the tablet and it is in a mode that my laptop (windows 10) cann't recognize the connected usb device....any idea for help?
2017/12/03
i figured out what the problem with WAIT LOADER START -failure is.
i was using RK Android Tool v2.3 with custom KitKat-rom. tried with custom Lollipop-rom and RK Android Tool v2.3. now working very good.
strange that RK Android Tool 2.3 is not working with KitKat-rom. RK Android Tool v1.37 (RKDeveloptool) was not recognizing my yarvik tab09-410 (is odys iron clone) in MASKROM-mode. RK Android Tool 2.3 did recognized my tablet in MASKROM-mode
46 Guest(s)
Devices in use: Desktop (41), Phone (5)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
