mostafatalaat
481
2016/07/03 - 05:07
Danke für das Feedback! Du hast ein Odys Iron?
can you help me i have pipo m6  pro when i change language to any language except english come "systemui.has stop working" and didnt disapper untail i make hard reset or flash new rom in all kitkat roms
482
2016/07/03 - 11:44
I guess you try to change to a RTL (rigth to left) language?
mostafatalaat
483
2016/07/03 - 14:14
yes is there any fix
thank you
484
2016/07/03 - 14:27
I depends on if the feature is on in the UI. Pls check if there is an option RTL-Layout in Developer Settings.
mostafatalaat
485
2016/07/03 - 15:35
yes there is force RTL layout direction option in developer settings
486
2016/07/03 - 17:11
Pls switch on and check if the UI will change.
mostafatalaat
487
2016/07/03 - 17:42
i switched it on the ui change the back  arrow become in right
488
2016/07/03 - 17:44
Ok, now change the language and reboot to see if this works.
mostafatalaat
489
2016/07/05 - 15:08
that doesnt work problem come again i lost my apps and data
sorry for late reply
490
2016/07/05 - 15:46
Ok. Which rom do you use?
mostafatalaat
491
2016/07/05 - 16:53
 it is Maakie's 1.2 pipo project
but i think this problem in all kitkat
SlavaGrig1
492
2016/07/05 - 19:24
Hi dear Oma, sorry, my quastion about rk3188, i trying to port your rom - android 4.4 kitkat (http://crewrktablets.arctablet.com/?p=2736) on tablet DNS M100qw, almost all work, but don't work - wifi, bluetooth, gps (radio moduls), coo-chip - mt6620, help please, i compile all modules mt6620 and insmod good, but wifi does not start
493
2016/07/05 - 19:37
Some debug?
494
2016/07/05 - 19:55
Works fine here. I do however not know how good the translation is 😉
Screenshot_2016-07-05-19-50-39.pngImage Enlarger
mostafatalaat
495
2016/07/06 - 08:06
which kernal should I use to flash this ROM
can I use any KitKat kernal
Thank you
62 Guest(s)
Devices in use: Desktop (58), Phone (4)
yogurt888pl
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
