SoulSlash3r
451
2015/02/21 - 11:05
Did the modelfix and the 160 fix. Will try later the other one. Also the app viper. do i need it because  i got the icon that says to stop it.
Medion Lifetab E13020
SoulSlash3r
452
2015/02/22 - 17:36
Oma: die all the fixes.
Issues found:
Bluetooth not working , cant find my phone.
Screen rotation shows an small format before rotating.
When adding an widget or deleting an widget the screen rotates.
Last thing the kernel on the ROM is for the medion tablet or use an other kernel?
Thats what i found so far.
Loko222
Forum Posts: 17
453
2015/02/23 - 00:47
Use the included FileManager in Root mode to delete the 3rd party apps. But not more.
Could you be a bit more specific? I checked and the only filemanager is the one I use (unless that's what you had anyway - es file explorer) in which case it's menu --> APPS and remove.
If that's not the app / way you recommend plz let me know the correct one.
Cheers
juronius
Forum Posts: 12
454
2015/03/24 - 14:59
Hello !
I install this rom on Qilive 8QC / Archos 80b Platinum.
My topic : http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/qilive-8qc-archos-80b-platinum/?lang=fr
But rotation, Wifi and BT not work.
Please, help me.
Thank's for helps.
SlavaGrig1
455
2015/03/31 - 22:07
Hello dear Oma, i trying to port your firmware with android 4.4.2 RK3188 on my tablet DNS M100qw RK3188, everything works except wifi, i have chip - mt6620 combo driver; I copied all modules from stock in port(system/lib/modules), edited init.rc from port - added lines about mt6620 from stock; lsmod showed me - all modules run, exactly as stock firmware, but wifi is not work, help please, i can send you dmesg log from port and from stock:)
SlavaGrig1
456
2015/04/01 - 17:55
I think, need to replace file libhardware_legacy.so, but after change it, tab is not included
hnito82
Forum Posts: 11
457
2015/04/02 - 10:55
Hi guys, I have a problem with the cam face, that is when I make a video call I do not see the other user. How so?
thantos
Forum Posts: 30
Thanks Received: 8
458
2015/04/09 - 02:14
Hi Oma, I was wondering if you had ideas on how to fix rotation for the Cube U30GT 2. I have tried editing the boot.img which made no difference, and I also tried to copy the modules from the cube firmware, but this just broke the build. I do believe that the drivers are loading as, for example, on initial boot if you try to set the auto brightness, it will activate and the screen will brighten or dim in response to the lighting levels. However, the auto brightness will disable itself and refuse to enable again.
Would be really interested in any thoughts you have as apart from the sensor issues the rom runs really well.
1nf3c710n
459
2015/04/20 - 21:31
Thanks a lot for your great job, I install this rom successfully on my Prestigio pmp5297c quad, but I have some littles problems with randoms reboots :/ and dont know why...
Also, is there a way to put lollipop on my device? thanks
hurricane165
460
2015/05/08 - 21:18
Hallo Omi
wie sieht derzeit den mit stabilen Roms aus? bzw. welche haben den status "stable"?
Anyone knows which roms are at that time stable??
Gruß aus austria
hnito82
Forum Posts: 11
461
2015/05/13 - 12:29
Help, there is news for Mediacom Mp82S4 because always goes in crash !!!
gk
462
2015/11/28 - 13:46
Hallo Oma,
habe auf meinem Wayteq 79QCI (http://www.wayteq.hu/en/xtab79qci) die schöne OmniROM 4.4.4 v1.4.1 installiert. Erster Eindruck: SUPER, HUT AB. Sehr stabil, läuft wesentlich stabiler und besser, als die Factory-Firmware... Also wirklich vielen Dank.
Ich habe eine Kleinigkeit aber gemerkt: kein Sound. Habe ich etwas falsch gemacht oder gibt es ein Update oder Fix hierzu ? Es liegt wahrscheinlich daran, dass es abh. von Seriennummer zwei Hardwarevarianten gibt (s. Unterschiedliche ROM updates for 79QCI unter http://www.wayteq.hu/en/download-tablet-pc). Mein Tablet hat eine Seriennummer 7914xxx
Das Ergebnis von "adb shell dmesg" habe ich beigelegt.
Wenn ich irgendwie weiterhelfen kann, werde ich versuchen zu helfen.
Vielen Dank und schöne Grüße aus Ungarn !
463
2015/11/28 - 17:11
Ja, kann durchaus sein. Welche Stock Firmware funktioniert denn bei dir?
gk
464
2015/11/28 - 17:24
Also was Soundwiedergabe angeht, waren sowohl die JB als auch die KK Stock ROMs identisch in Ordnung:
http://wayteq.eu/en/xtab79qci_sw_update_v2014
http://wayteq.eu/en/xtab79qci_kitkat_2014
Von allen anderen Aspekten (Stabilität, Performance, Bugs, Crashes, etc.) her sind die obigen Firmware-Ausgaben ja leider nicht mehr so zufriedenstellend :-((((
Ciao!
62 Guest(s)
Devices in use: Desktop (59), Phone (3)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
