Loko222
Forum Posts: 17
436
2015/02/11 - 23:27
@Oma7144
Dunno if you got time to check some problems I still have with the rom. It's a yuandao n80.
Camera never worked, apps just close or I get the message that it couldn't connect to the camera (don't really care about this if it's not an easy fix since I don't use the camera).
If I remove any (tried removing random apps one per time) of the apps that came with the rom using titaniumbackup the tablet will not boot if I restart it / shut it down (would like to remove quite some of them).
And last but not sure if you can do anything about it, everytime I view something with mx pro player the quality is really degraded, I have to switch decoder for it to go back to normal (doesn't matter which it uses it will be crap and once I switch to another or to another and back to the one it used it will be fine).
Cheers
igor_vb
437
2015/02/14 - 21:07
Hi Oma!
I can't found android 4.4 custom rom for pipo u1 pro. This is devvice with RK3188 SoC. Can You help me?
dmesg.txt and logcat.txt in attachments.
Thanks.
438
2015/02/14 - 22:15
Pipo U1 pro is a rk30board. Build is here: http://crewrktablets.arctablet.com/?p=1913
igor_vb
439
2015/02/14 - 22:20
Loko222 said
@Oma7144
Do not touch the system, you will corrupt the build.
For the cam, did you test both modle fixes: http://crewrktablets.arctablet.com/?p=3555
440
2015/02/14 - 22:22
franzD said
I've been trying out the latest firmware on my Prestigio PMP5010C_QUAD (Multipad Quantum 10.1) with RTL8723 wifi.
WIFI works out-of-the-box, screen/orientation/cameras are OK with the 160dpi fix. I've come across two issues:
1. Bluetooth doesn't work, can't switch it on.
2. I'm getting reboots every time the screen goes to sleep automatically. If I switch the screen off manually using the power button, it's fine and it wakes up fine, but whenever it's supposed to sleep after the timeout, it goes to black and reboots, doesn't even show the animation. I had this same problem on the CM11 edition.
Any ideas? I can provide logs/backups, if needed.
Where can I find the stock firmware?
franzD
441
2015/02/15 - 11:13
The latest version of the stock firmware is available on Prestigio's website. If you need the nandroid backup, I can send that, as well.
442
2015/02/15 - 11:26
Sorry, PMP5010C or PMP5101C?
franzD
443
2015/02/15 - 11:45
My bad, sorry, I've mistyped the model number in my first post, it's indeed the PMP5101C_QUAD, without the 3G. I did send you the right link, though.
444
2015/02/15 - 14:35
Ok, the kernel from the 1.0.8 firmware is already in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1603
Here is the kernel from the 1.0.12 firmware: http://crewrktablets.arctablet.com/?wpfb_dl=2460
Maybe this one works better. Model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2459
franzD
franzD
445
2015/02/15 - 19:35
No more reboots with the model fix and the latest kernel. The phantom rotation fix is also necessary for this model.
Bluetooth now works the same as in the stock firmware, meaning awfully (WLAN and Bluetooth don't work well together on my tablet, don't know if only I have this problem or if it's a "feature", when BT is active, WiFi signal quality drops and often disconnects but this is a known issue for me and has nothing to do with the ROM).
Thank very much, you can add this model to the list of confirmed installations, works fine and I see no issues with it at the moment. A small donation is on the way.
How usable would the model fix be on your Lollipop build, is it worth trying out?
Also, any quick tips on how to remove the volume buttons from the menu bar?
446
2015/02/15 - 19:52
Great. Thank you very much!
Documented here: http://crewrktablets.arctablet.com/?p=3555
Edit build.prop: set ro.rk.systembar.voiceicon=true to false.
Loko222
Forum Posts: 17
447
2015/02/16 - 22:14
Loko222 said
@Oma7144
Any chance you could change that in the future? I mean for example I would like to remove viber, mx player (since I got pro) among others.
If you remember, one of the model fixes wasn't working properly (it lagged and changed the resolution while it was rotating). Also I am semi certain camera didn't work on that either.
448
2015/02/16 - 22:29
Use the included FileManager in Root mode to delete the 3rd party apps. But not more.
SoulSlash3r
449
2015/02/21 - 10:19
hi oma, kinda newhee since i recently have an medion lifetab 10320.
worked last night on the rom to get it working. I've managed towork on the medion. runs smooth but not fast.
when i hold the tablet at the long side, i can add widgets, but when it is in the widhtside the screen rotates on and on when trying to add an widgets.
also the bluetooth won't find any device. any options?
Medion Lifetab E13020
450
2015/02/21 - 10:56
Did you install the model fix?  http://crewrktablets.arctablet.com/?wpfb_dl=2193
For rotation issue try this: http://crewrktablets.arctablet.com/?wpfb_dl=1369
SoulSlash3r
58 Guest(s)
Devices in use: Desktop (55), Phone (3)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
