ti5002000
Forum Posts: 21
31
2014/07/04 - 20:27
hi Oma
The results in the odys 1.2 are:
-the screen is still rotated clockwise
-The camera dont work att all .Android says that it cant reach the camera
Thanks for all your work
ti5002000
Forum Posts: 21
32
2014/07/04 - 20:30
here is the Kernel
thanks a lot
33
2014/07/05 - 13:17
Cam may a problem of not proper formatted NAND. Flash the build again, with stock recovery first: http://crewrktablets.arctablet.com/?wpfb_dl=910
Kernel is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1898
Download the model fix again and try: http://crewrktablets.arctablet.com/?wpfb_dl=1896
ti5002000
Forum Posts: 21
34
2014/07/05 - 14:36
Ok later  at home I Will test.
By The way,  with the fix of yesterday in The omni rom The touch works well, not inverted as before, But The screen is rotated and Bluetooth stoped working .
Later I Will do a simbolic donation Just to thank you But is really simbolic
ti5002000
Forum Posts: 21
35
2014/07/05 - 23:22
Oma sorry But It didnt work.
The system cant reach The camera and The screen is upside down...
I flashed as you said with stock recovery then first boot It formated. Next I flashed cwm recovery and installed The fix.
36
2014/07/06 - 14:32
Ok, counterclockwise. Let us try the Archos cam.
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=1896
ti5002000
Forum Posts: 21
37
2014/07/06 - 16:01
Well Oma
The results are :
Fantastic .Almost everything is working .
except one small thing : the front camera is upside down :)
As i said a sent a small donation .the email that i used is ti5002000@yahoo.com.br.
I have no words to describe how i thank you for all your efforts
thanks very much
ti5002000
Forum Posts: 21
38
2014/07/08 - 20:53
Hello Oma
No solution yet? :)
39
2014/07/08 - 21:01
Not really. I do not know what your stock kernel is doing and without having the tab at hand not resolvable.
However, maybe this will give you a solution: http://forum.xda-developers.com/showthread.php?p=46671244&highlight=ucam#post46671244
ti5002000
Forum Posts: 21
40
2014/07/08 - 23:16
it worked oma thanks .The camera sometimes doesnt judge well the white balance but ok..it works...
Meanwhile when you have some tem if you can please fix the bugs for cm or omni...It would be much better ...
Omni has the screen totated 90 degrees anti clockwise ,i think.
And cm touchscreen doesnt even work...
When you have the time if its possible....i know maybe i asking too much but do what you can..
many thanks
cftmartins
41
2014/07/09 - 16:03
I have tablet qilive 97r and I install Odys IRON – OmniROM Edition V1.2 (I have to use the parameter_8GB from v1.1 to install) and untill now everithing works fine, except the screen rotation.
In previous version i had problems with video decoding and unstability, but with this version is OK.
Thanks,
CM
42
2014/07/09 - 16:30
Thank you guys for feedback!
We are developing the build continously. Pls install these fix: http://crewrktablets.arctablet.com/?wpfb_dl=1902
ti5002000
Forum Posts: 21
43
2014/07/10 - 01:10
My report for omni 1.2
Everything works fine except the camera that is rotated both back and front.
netlars
Forum Posts: 149
Thanks Received: 29
44
2014/07/11 - 06:57
Thanks for your response.
Please test the new 1.3 build. Now you can rotate your picture in the build.prop with the entries ro.sf.hwrotation=0  (90,180,270) and ro.sf.fakerotation=false   (true).
I hope this help you for your cam picture.
The following users say thank you to netlars for this useful post:
ti5002000
pmerrill
Forum Posts: 23
45
2014/07/12 - 00:07
I tried this build Odys Iron Omni 4.4 V1.3 on a Vido N80RK in the hopes it may work. The RKAndroidTool seemed to work fine but I could not get it to boot into CWM Recovery. I ended up having going back to Oma RK31 Vido N80RK JB 4.2.2 V3.4.
A couple of questions. Should it work on this tab if I apply the 160dpi fix? If not, is there any chance that you could make a ROM that will work on this tab? If it should work, then any tricks to flashing the rom that I should have followed?
75 Guest(s)
Devices in use: Desktop (61), Phone (13), Tablet (1)
Javier1994
jcn50
cleopatra duran
perelliz
johnpierrepierre
stumts
