sandryan
361
2014/12/27 - 15:20
Ok i tried the same procedure both in XP and Seven, but i have the same problems.
I have to install CWM or something similar on my tablet before follow the "instructions"?? Because every time when i do "power + up volume" nothing happens.
Please help me, if some of you have a more detailed guide give it to me!
Thx
Jammed_Death
Forum Posts: 51
362
2014/12/27 - 15:48
Another procedure ti pur tablet in boot mode is:
Tablet off
Connect charger
Then while pressing vol- (or vol+ i m not sure) connect the USB
In this way the software should see the tablet as "loader" and you're ready ti flash it
Always in win 7. In win 8 no way for me
The following users say thank you to Jammed_Death for this useful post:
sandryan
sandryan
363
2014/12/27 - 17:37
Ok it works but,
I had this error:
ERROR: Download file failed (There is an error in the step "Checking download data, in 1/4 of the size there is an error).
So i hope i had some error in the downloaded file. So i am downloading it again.
I overwrote the kernel.img(taken from Qilive file) and parameter (i found 8gb version). For the installation with RkAndroidTool i check all (loader included) and only backup unckecked. Is it right?
Help me!!!
Jammed_Death
Forum Posts: 51
364
2014/12/27 - 18:08
there is a pdf file in the archive with photos and guide, i don't have it atm...can you check it out?
sandryan
365
2014/12/27 - 18:44
The pdf is in dutch so for me is useless...
I tried also to install 1.4.1 again(download agin all the files)but i have error in the same section. I tried also 1.4.7(posted by Oma) but i found error in another section.
Any suggestion?
sandryan
366
2014/12/28 - 13:05
Ok i was able to install it using the version linked by OMA. If i use the version present on the site i am not able to complete the firmware installation, i dont know why.
Impression about the ROM.
It works but it is not so smooth (when you are in application menu for example) it seems like there is a delay in everything i do, also i got crash principally with PDF program like (MuPDF and SmartQ Pdf), i cannot use them because when i try to edit the pdf the program crash.
Also in some case the tablet doesn't response, i have to wait about 2 second before it continue to work.
I don't know if i did something wrong during the installation or not.
Let me know if i am the only one with these problem or not.
For sure thanks for Oma because is the only one that i know that is working on this tablet.
Wolvy74
367
2014/12/29 - 11:34
I've got this ROM running on my Yarvik TAB09-410.
Can anyone tell me why Google Playstore keeps crashing? It happens at several points, when installing apps, when clicking Install of Accept buttons, when clicking an app and the description of the app loads, etc.
Besides this, it runs very smooth!
Greetz, Wolvy
sandryan
368
2014/12/29 - 12:55
I have the same problem with google play.
369
2014/12/30 - 14:51
Be patient with a new installed firmware. Everything has to set up. Apps could stop due to new versions received.
Redin
Forum Posts: 19
370
2015/01/09 - 00:28
Hello OMA.
Since I installed the Omnirom 4.4.4, version 4.4.4 (Kit Kat), I have come to realize an unbearable delay until my tablet was in ready condition.
The boot takes 2m.20s to ask for login.
From the moment I authenticate to use the tablet, it takes more 2m.55s to be able to use it.
While I am using it all goes well, but when I leave on stand-by for several hours, and when I go again need them, it will be blocked and takes a long time to be able to use it well again.
When this happens, I prefer to reboot because it takes less time to be prepared again.
Is there anything to do to correct this delay?
Many thanks.
My device: QiLive 97R - RK31 JDQ39
Rock293031
Forum Posts: 39
371
2015/01/14 - 12:11
Hallo Oma,
leider funktioniert auch das OmniROM nicht auf dem Volkstab1 von Trekstor.
Es bootet komplett, reagiert auf Touch.
Nur leider ist der Bildschirm komplett verzerrt. Anbei ein ähnliches Bild.
Gruss, Neptune
Rock293031
Forum Posts: 39
372
2015/01/15 - 19:38
Hi Oma,
hast Du evtl. einen Tip, wie ich das Verzerrte Display in den Griff bekommen kann?
Ich verwende den Stock Kernel (3.0.36 Source und defconfig wären bei Trekstor verfügbar, falls das hilft).
Würde gerne endlich das lahme Stock-ROM ersetzen.
Bin für jeden Tip dankbar.
hipnox
Forum Posts: 29
373
2015/01/23 - 12:58
Hi Oma,
I did manage to put the correct kernel, but it has some issues. The touch screen is mess up, i touch in one place and it aperear in another, I have to use a mouse. And the screen doesn't rotate also.
 The cameras also doesn't work. The camera app icon does apear. I downloaded one application camera and it says that could't establish conection with the cameras
Thank you.
374
2015/01/23 - 17:39
Following a recent server issue (you can read about it here) here is an hopefully complete list of the the missing posts from the past days. Please excuse the raw formatting, this series of replies is just copied here for your convenience to keep the topic history.
Replies are listed sequentially, oldest first in the list.
Post:
Vorurteile Oma mir im Laufe des Verfahrens in der Erholung in der unteren linken sagt mir,
E: ungültiger Befehl Argument
E: Kann nicht montieren / cache / Erholung / Registrieren
E: kann nicht geöffnet / cache / Erholung / Registrieren
dann nach der Tat wischen data / factory reset sagt mir, "Nein app2sd Partition gefunden. sprungen Format / sd-ext. Fehler Montage machen / sdcard / .android_secure! Skipping-Format ...." jetzt dem Bildschirm, nachdem ich aufgetaucht Penguins ich blieb schwarz. Ok ich löste die Rom mit den ursprünglichen Dateisystem installiert, ohne ihn zu verändern mir nur, dass die Schrift oben beschrieben, aber ich habe erschien jedoch erfolgreich ist die Installation. Nun das einzige Problem, ich habe und dass ich die Lautstärketasten auf dem Display, und ich oft vor, dass automatisch dreht sich die Anzeige beim Spielen!
stattdessen setzen die Parameterdatei 8Gb Ich fand Erinnerungen und nicht geteilt
Ok, now stable wifi & BT
Any feedback from beta-testers?
Post:
Hi to all!
I have problem with autorotation - not working
camera front and back turned clockwise 90°
tablet PIPO M6 max (not pro)
installed CrewRKTablets_Odys_Iron_Omni_.4.4_v1.4.1 and RK31_kernel_3036_hr_m6_pipo kernel
Regards,
Ivan
Post:
Pls install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2393
Post:
hnito82 said
Ich Mediacom Mp82s4
Sehr schwer zu verstehen. Was ist das Problem?
Post:
thanks for fast reply!
orientation works and camera but everything is upside down
Post:
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=2394
Post:
all the same as with the first version.....
Post:
Ok, then go back to v1.4 and the first model fix.
Post:
version 1.4 with first fix works!
orientation and both cameras!
Thank You Oma!
P.S. is there a topic on forum for:
RK31: Odys IRON – RTL8723 Edition
IRON by CrewRKTablets JB 4.2.2 v1.1
I have the same issues with this one and the market wont let me fully download....
(it is much faster for now then 4.4.4)
Post:
Fine.
Open a thread for specific tab/question.
Post:
I have one little glitch,
when holding icon on home page to move it, screen turns 180° then back to normal and the icon cannot be moved!?
Post:
Install this: http://crewrktablets.arctablet.com/?wpfb_dl=1369
Post:
WORKS!
Thanks man!
Post:
Be patient with a new installed firmware. There is a lot of activity in the background (i.e. mediaservice) for hours.
To improve UI feeling: disable all animation scales in developer options, use Nova launcher and set animation/scroll to "faster than light" and enable Entropy Fixer with value 256.
Post:
I did all of that already...
Thank You so much! My PIPO was really f***** up with other custom ROMs
Your work is great for giving a new life for this Chinese tablets!
I also tried Lollipop 5 and can confirm that is partially working on PIPO M6 (I know, work in progress......)
GREAT WORK!
Post:
hnito82 said
Ich Mediacom Mp82s4
ich habe das Problem, dass plötzlich schaltet sich automatisch ein, und die Anzeige ist die automatische Ausrichtung stoppen. statt über die Worte schien seltsam, dass während des Flash cwm erscheint!
Post:
hnito82 said
Ich Mediacom Mp82s4
Post:
Hi There, I'm trying to install this ROM on my Qilive 97R-2 (logcat and dmesg in attachment) but the Rkandroid tool doesn't detect the tablet in recovery mode. I've tried several drivers but still no goal. Could you help me up so I could try out this ROM.
Thank you.
Post:
Here is the latest Driver Assistant: http://crewrktablets.arctablet.com/?wpfb_dl=2398
Flash-Modus:
- press power button and volume up button and hold for 12 sec
- release the power button
- release volume up button 2 sec after "Found ..." is shown
Post:
hnito82 said
ich habe das Problem, dass plötzlich schaltet sich automatisch ein, und die Anzeige ist die automatische Ausrichtung stoppen. dann ist mein Speicher ist in 6 Gb internen und externen 16Gb Sd unterteilt. Statt über die Worte schien seltsam, dass während des Flash cwm erscheint!
Sorry, the translator doesn't work.
Post:
Flash-Modus:
Thank you very much OMA.
However there are some issues that i'd like to ask. According to CPU-Z my tablet is a RK3066 instead of a RK3188, does this ROM will still work or it's exclusive for the RK3188.
I've installed the drivers like you said and it works but in another way. The flash-modus doesn't work but if i hit in arctools to reboot in bootloader the rkandroid tools does recognezies it but the tablet screen is empty. Should I consider it normal and flash the ROM or should I not risk it.
Thank you in advance.
Post:
Check your CPU with this tool: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck
You can also use the Switch button in the RKAndroidTool to start the flash-modus.
Post:
Thank you.
Ok, with that app it is a rk3188. Just another question so I can try out the ROM, in the instrutions you mention the format_NAND fix but I don't find it in there, sorry for the newbie thing. Is it the specific fix for each model of tablet?
Thank you.
Post:
Ignore the 1st step in the instructions. Just do the factory reset in CWM.
Post:
Hi there OMA,
Sorry again but I followed the instrutions like you said and now the tablet doesn't boot. I apears your logo e it stays blanck.
Can you help me please.
Post:
Did you change the kernel?
Post:
Nop, I see now that, is there a way to fix it?
Post:
Kernel is here: http://crewrktablets.arctablet.com/?p=3555
Change it in folder rockdev/Images and flash again.
Also install the modell fix after first boot into CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2309
Post:
sorry Oma, I have the problem that suddenly rotates automatically, and I have to put the display to stop the automatic orientation. Then my memory is divided: 6 Gb internal and external 16Gb SD. Instead, for the indication seem strange that appear during the CWM flash!
Post:
I am terrible sorry but as in German that gives me only a puree of something.
Try each point as a separate bullet point.
hipnox
Forum Posts: 29
375
2015/01/23 - 17:56
Hi Oma,
It's a Qilive 97R-2 tablet.
Thank you.
Currently Online: yogurt888pl
65 Guest(s)
Devices in use: Desktop (61), Phone (5)
yogurt888pl
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
