346
2014/12/16 - 17:51
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2309
Redin
Redin
Forum Posts: 19
347
2014/12/16 - 18:16
front camera it's up side down. rear camera still ok.
My device: QiLive 97R - RK31 JDQ39
348
2014/12/16 - 18:23
Redin
Redin
Forum Posts: 19
349
2014/12/16 - 18:56
Finally: http://crewrktablets.arctablet.com/?wpfb_dl=2309
Sorry, not yet! front camera is now 90 degrees right.
Rear camera is still ok.
350
2014/12/16 - 19:02
Redin
Redin
Forum Posts: 19
351
2014/12/16 - 19:39
Arrrrghhh: http://crewrktablets.arctablet.com/?wpfb_dl=2309
Ehehehehehehehehe!
Take a easy my men. It's now all OK.
You are the best.
Robur
352
2014/12/16 - 19:40
Eureka. Seems you have struck gold.
Orientation is OK on both cameras here.
Thanks a lot! Thanks to your Rom just instilled new breath on an otherwise lackluster machine.
353
2014/12/16 - 19:59
Fine. I will have now a good Single Malt Whisky ;-)
tabnabs
354
2014/12/16 - 21:54
Hi Oma. Thanks for Pipo M1 Model Fix for 1.41 rom. However orientation is upside down and no camera at all. Wifi works but bluetootrh is not working as in 1.30.
355
2014/12/17 - 20:59
Can you pls check build 1.4? Wifi was working in v1.3 or not?
tabnabs
356
2014/12/17 - 21:56
Hi Oma sorry to be unclear. Wifi works and has in all builds. Bluetooth does not work and never has in any build. Camera is not available as an app or in gallery at all. Screen is inverted as un upside down. Hope this helps.
Shanti7777
Forum Posts: 18
357
2014/12/19 - 11:13
OMA this is final patch for "Prestigio Multipad 4 Diamond 7.85" (rotation,dpi and camera fix). In last version Wifi work without any fix. Only light sensor doesn't work.
I try also Lolipop on my tablet, the same doesn't work like in KitKat.(rotation,light sensor)
The following users say thank you to Shanti7777 for this useful post:
sandryan
358
2014/12/27 - 00:15
Hi all.
I am trying to use this ROM on my Qilive 97r, but i think i there is something wrong with the drivers because i am working on windows 8.1 x64. I installed the drivers by run DriverInstall.exe, but i have a yet a yellow triangle in "device management" with the ADB peripheral. So when i try press power + volume up nothing succeeded. What can i do?
I tried also to do the same things on windows vista SP1 but have the same problem.
Please help me!!
Jammed_Death
Forum Posts: 51
359
2014/12/27 - 11:11
same issue on 8.1, i solved with windows 7. Apparently bootmode drivers don't work on 8.1. Don't know about vista
sandryan
360
2014/12/27 - 12:22
Ok i will try on windows XP o windows 7.
Another question. Do i need to install something on my tablet before following the procedure?
Thx
61 Guest(s)
Devices in use: Desktop (57), Phone (4)
yogurt888pl
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
