Loko222
Forum Posts: 17
331
2014/12/03 - 21:54
No, Omni build v1.4 is here: http://crewrktablets.arctablet.com/?p=3555
Yea that's where I got it from.
cRom v1.4.1 ( http://crewrktablets.arctablet.com/?wpfb_dl=2035 ) Was the one I was using and had the problems.
cRom v1.4 ( http://crewrktablets.arctablet.com/?wpfb_dl=2079 ) Is the one that is not running at all with.
332
2014/12/04 - 17:23
Try again v1.4. Use the included RKAndroidTool and flash incl. eraseIDB.
Loko222
Forum Posts: 17
333
2014/12/04 - 21:55
I might be going blind, there is only the "2. RKAndroidTool" folder and inside it AndroidTool.exe
Basically the only exes inside the 7z are:
1.4-1.pngImage Enlarger
Can you grab it yourself and check?
For example in the 1.4.1. I can find the "RKAndroidTool.exe".
334
2014/12/04 - 22:11
Ok, there is something mixed up on our server. Link corrected now: http://crewrktablets.arctablet.com/?wpfb_dl=2011
Loko222
Forum Posts: 17
335
2014/12/04 - 23:31
:D
So I just changed kernel and it entered just fine.
Used model fix2 and did the opposite of 1.4.1 !! the orientation was 180 degrees off, also I think the 160dpi fix didn't work. Otherwise there was no lag on the rotate.
So flashed model fix1 & 160dpi fix and it works fine!!
Cheers for bearing with me!
Got some unrelated questions / requests here. Could you add the battery option on the settings? I like to know how many hours it's been on, since the battery tends to lie about it's percentage.
Also there is no rotate when you are in the menu or the "desktop". Is that a feature of 4.4.x ? Can I change it somehow seeing as it is a tablet and I have it on landscape most of the time.
Loko222
Forum Posts: 17
336
2014/12/09 - 01:47
Nudge.
So I have re installed 1.4 like 10 times trying various things till it doesn't boot anymore.
My rotate problem that stopped after a while in 1.4 must be nova settings since it happens after a restore of nova settings.
Now for the goodie part. If I try to unistall (using titanium backup) any app that is part of the "system" like mx player (have mx player pro) on next reboot / boot it won't boot. It can go into recovery but if you try to start it normally after it shows the vido logo the screen stays a bit dim and tablet starts to get hot..
Tried the mx, launcher3, the filemanager one per time etc and it always dies out. Any idea if you could fix that somehow (or better then rotate lag on 1.4.1? :P).
Will try to see if the unistall problem happens on 1.4.1 too for my tablet.
As always if you want to try something, provide logs of some kind, let me know.
edit: also happens on 1.4.1 when uninstalling mx player
Cheers
lujji
Forum Posts: 67
Thanks Received: 19
337
2014/12/09 - 21:18
I couldn't seem to find a way of mounting internal storage rw via MTP under Linux.
How do I revert the unified storage? Will editing mountpoint and partition table be enough?
Redin
Forum Posts: 19
338
2014/12/09 - 22:25
Redin said
Sorry, download again from post #308.
 Success. Great. Good job. Now ok. You are the best. Thanks.
Hello OMA, sorry again, I'm back.
It's because my camera is again rotated 90 degrees reversed.
I dont know how or why he returned to the same problem.
I made a short video to explain in detail what is happening. See attachments.
Can you fix it? Thank you.
My device: QiLive 97R - RK31 JDQ39
tabnabs
339
2014/12/09 - 22:37
Hi Oma, Great Work. Any chance of an updated model fix for Pipi Max M1 for latest updated Rom?
Mr.R
Forum Posts: 25
340
2014/12/15 - 22:43
Hi Oma, long time no see :)
Has any progress been made on the MT5931 wifi issue? I have a pipo m9 max (you created the RK31_kernel_3036_m9_pipo_2 kernel for me :)) and have tried this build and your cm11 build, both work perfectly bar the wifi which is obviously something that is needed. Keep up the good work though and hope there is a fix soon if it is at all possible :)
Robur
341
2014/12/16 - 11:49
EDIT: Actually I was using parameters from Oma KK V2.1 Parameter 8GB Tabs 2 (Oma_KK_v2.1_parameter_8GB_tabs_2.7z). I have since used parameters from CrewRKTablets RK31 KK Omni V1.1 Parameter 8GB (CrewRKTablets_RK31_KK_Omni_v1.1_parameter_8GB.7z) and CrewRKTablets RK31 KK Omni Parameter 8GB Tabs (CrewRKTablets_RK31_KK_Omni_parameter_8GB_tabs.7z) both with success.
Either changing the parameters file used or having run the RefreshTool or both seem to have fixed the issue.
I am still having the camera problem mentioned in post 338, though.
Thanks a lot for your great work!
Previously I wrote:
I am experiencing a serious nag where whenever I shutdown the tablet (both using the menu which pops up when you press the Power Button or with the application included with the rom) it next hangs indefinitely at boot while showing the OMNI logo. It only comes back if I enter CWM and perform a factory reset.
I mean, whenever the tablet is shutdown I have to delete all user data and start over...
I have a QiLive 97R. I installed v 1.4.1 + your custom kernel for Qilive 97R v. 1.4.1 + the parameters fix for 8GB models v2 + I installed from CWM the zip fixing specific QiLive driver issues.
Any idea of what might be wrong? Otherwise everything seems to work fine expect the camera issue mentioned in post 338 above, which I also have.
Thanks in advance.
342
2014/12/16 - 17:23
@ Redin, Robur - pls test: http://crewrktablets.arctablet.com/?wpfb_dl=2309
Redin
343
2014/12/16 - 17:23
Sure. Pls test: http://crewrktablets.arctablet.com/?wpfb_dl=2310
344
2014/12/16 - 17:25
Unfortunately still not luck with MT5931 wifi.
Redin
Forum Posts: 19
345
2014/12/16 - 17:45
Hi OMA;
Rear camera is OK but front camera is 90 degrees left.
Many thanks to come back ;-)
65 Guest(s)
Devices in use: Desktop (61), Phone (4)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
