316
2014/11/30 - 15:49
Sorry, haven't noticed your post.
Here is a similar feedback: http://forum.xda-developers.com/showpost.php?p=56246334&postcount=2023
Two different orientations means two different kernel. Which kernel do you use?
Loko222
Forum Posts: 17
317
2014/11/30 - 16:00
The kernel for yuandao, namely: http://crewrktablets.arctablet.com/?wpfb_dl=1911
But seeing as my install was pretty messed up, had no recovery at first (was using stock), then forgot to change the kernel to the yuandao etc it might be a severely butchered up installation.
Could you tell me the correct order of flashing the rom?
Since now I have CW recovery, I connect it wipe IDB, change the default kernel with the yuandao one, press run.
Run factory reset, reboot tablet, hit no on both questions? (first is about recovery, 2nd is about su)
After it boots in, reboot to recovery and run format_NAND & model2 fix (which contains the 160dpi fix)
318
2014/11/30 - 16:07
Should be ok. The model fix you can install directly after the factory reset.
Loko222
Forum Posts: 17
319
2014/11/30 - 22:06
I followed the steps (installed only the model fix 2, not 1 too)
"rom may flash stock recovery on boot, fix?" I chose no.
Problem persists.
the format_NAND said some permissions could not be set log:
AROMA Installer version 2.70RC2
  (c) 2013 by amarullz xda-developers
ROM Name    : AROMA Installer
ROM Version : 2.70RC2
ROM Author  : <support@amarullz.com>
Device      : Not Defined
Start at    : Sun Nov 30 20:44:01 2014
    installing samsung updater extensions
Starting the install process
  Setting up required tools...
Format internal sd card
    unmount of /emmc failed; no such volume
  (emmc is already unmounted)
    about to run program [/tmp/mkdosfs] with 3 args
    mkdosfs 3.0.9 (31 Jan 2010)
    unable to get drive geometry, using default 255/63
    about to run program [/tmp/dosfsck] with 3 args
    dosfsck 3.0.9, 31 Jan 2010, FAT32, LFN
    /dev/block/mtdblock10: 0 files, 1/254046 clusters
  Complete
Wipe data and cache
    unmount of /data failed; no such volume
  (data is already unmounted)
  wipe data...
    Creating filesystem with parameters:
    Block size: 4096
    Blocks per group: 32768
    Inodes per group: 8192
    Inode size: 256
    Journal blocks: 32768
    Label:
    Blocks: 3700224
    Block groups: 113
    Reserved block group size: 903
    Created filesystem with 11/925696 inodes and 99903/3700224 blocks
    warning: wipe_block_device: Discard failed
    about to run program [/sbin/sleep] with 2 args
  wipe cache...
    Block size: 4096
    Inode size: 256
    Journal blocks: 1024
    Label:
    Blocks: 32768
    Block groups: 1
    Reserved block group size: 7
    Created filesystem with 11/8192 inodes and 1550/32768 blocks
    unmount of /system failed; no such volume
  (system is already unmounted)
  tune system...
    about to run program [/tmp/tune2fs] with 4 args
    run_program: execv failed: No such file or directory
    run_program: child exited with status 1
    about to run program [/tmp/e2fsck -p /dev/block/mtdblock8] with 1 args
  cleaning...
    about to run program [/tmp/mount] with 2 args
    mount: mounting /dev/block/mtd/by-name/cache on /cache failed: Device or resource busy
    run_program: child exited with status 255
  Complete
    set_perm: chown of /system/bin/whtest.sh to 1000 1000 failed: No such file or directory
    set_perm: chmod of /system/bin/whtest.sh to 777 failed: No such file or directory
    script aborted: set_perm: some changes failed
Installer Error (Status 7)
End at : Sun Nov 30 20:45:43 2014
320
2014/12/01 - 06:59
Leave the format NAND fix out. Just do instead a factory reset in CWM.
Loko222
Forum Posts: 17
321
2014/12/02 - 01:26
Sadly no change. I get some lines about not being able to access or load some logs when it goes into recovery.
Maybe factory reset is not enough? Need to go deeper? That rotation bug, might be mainly cosmetic but it's pretty annoying.
If you want me to provide logs, try other stuff, I 'll be happy to do my part.
322
2014/12/02 - 16:14
Oh, that means it boots now into Android? Check out both model fixes as they are rotating the screen differently.
Loko222
Forum Posts: 17
323
2014/12/02 - 16:48
It always did boot into android, except the first time I messed up the kernel.
Model fix 1 has the same problem and also is 180 degrees opposite, so no matter how I have it in my hands, the screen is set on the opposite side.
324
2014/12/02 - 17:04
Hm, can't imagine why this is the case. Can you pls check out if this build works for you?
Loko222
Forum Posts: 17
325
2014/12/02 - 18:42
Should there be a link there? :P
Would there be a point in removing pretty much everything from the tablet (without perma bricking it!) like os, kernel, recovery etc and doing everything correctly from the start? Or it's not possible a previous fuc* to still damage something (permissions, partitions) etc cause when I used the wrong kernel I tried a lot of random stuff to make it work.
edit: also I am pretty sure I never replaced the parameter file with the either the one linked in mandatory or the 8/32 version (since they are not for my model).
326
2014/12/02 - 19:14
You cannot brick an RK tab. If everything crashed on the NAND you can start it in mask-rom modus (1st stage bootloader) by shorting two NAND pins. By flashing a strange kernel you can, for sure, "damage" the hardware. In some cases the kernel will flash a firmware into i.e. the touch-controller. A strange firmware in the chip is the end of the road ...
The parameter file defines the partition layout on the NAND. EraseIDB will wipe this layout. If there is a missmatch the Flashtool will report download failed.
So, pls use the firmware packs as they are, just change the kernel (which is the interface to your specific hardware). Plus may be additional advises.
Can you pls test with build 1.4? Maybe we have some difficulties with the frameworks fakerotation.
Loko222
Forum Posts: 17
327
2014/12/02 - 23:53
Well 1.4 doesn't work at all :/ Moved the kernel to the image dir, lower format was fine, everything else was loaded / downloaded fine but even after 10 min no response from the tablet and it won't start.
Re grabbed the kernel and replaced it, did it again, nada.
328
2014/12/03 - 17:50
Lower format? Which Flashtool did you use?
Loko222
Forum Posts: 17
329
2014/12/03 - 18:53
Grabbed for 1.4 : Oma_RK32_Pipo_P4_KK_4.4.4_v1.4.7z
In "2. RKAndroidTool" used AndroidTool.exe
330
2014/12/03 - 18:56
No, Omni build v1.4 is here: http://crewrktablets.arctablet.com/?p=3555
82 Guest(s)
Devices in use: Desktop (72), Phone (10)
swan12
heftpflaster
