301
2014/11/29 - 19:28
Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2274
Redin
Redin
Forum Posts: 19
302
2014/11/29 - 19:43
Thanks.
Rotation works but now in "uper side down" and "letf side right"
My device: QiLive 97R - RK31 JDQ39
303
2014/11/29 - 19:47
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2274
Redin
Redin
Forum Posts: 19
304
2014/11/29 - 19:59
Now works ok.
If are important, a simple think to correct, the android logo on booting are inverted 180 degrees.
Many thanks.
Redin
Forum Posts: 19
305
2014/11/29 - 20:33
Hi OMA, Like in other ocasions, i think you must add informations about that fix here: http://crewrktablets.arctablet.com/?p=3555
to others QiLive 97R users.
Many thanks
306
2014/11/29 - 20:41
Documented here: http://crewrktablets.arctablet.com/?p=3555
Which logo do you mean? The kernel logo?
Redin
Redin
Forum Posts: 19
307
2014/11/29 - 20:51
 I dont know the name to call, but is the green logo one. A litle toy surrounded by a circle and named OMNI, is inverted. Yf you think is important correct that, but for me, i pass.   ;-)
All the rest now im my tablet aparently is all ok. Well done. Great job.
308
2014/11/29 - 21:12
Pls check.
Redin
Redin
Forum Posts: 19
309
2014/11/29 - 21:34
Pls check.
Sory. Is in the same inverted position.
310
2014/11/29 - 21:42
Sorry, download again from post #308.
Redin
Redin
Forum Posts: 19
311
2014/11/29 - 22:14
Now are ok.
Do not think I'm kidding with you but the OMNI doll no longer blinks his eyes and does not move the little horns. The move shows the user that the boot was not frozen.
I think is import to impact of user.
312
2014/11/30 - 09:50
Redin
Redin
Forum Posts: 19
313
2014/11/30 - 11:49
 Success. Great. Good job. Now ok. You are the best. Thanks.
314
2014/11/30 - 12:17
Fine. Linked to the blog now.
Loko222
Forum Posts: 17
315
2014/11/30 - 14:59
Oma could you kindly take a look at my problem too?
When the screen rotates it lags a bit and distorts the resolution, below is a photo of going from landscape to portrait:
https://www.dropbox.com/s/tmc6xzg9tpb0phf/CameraZOOM-20141130155109841.jpg?dl=0
As you can see it first reduces the one dimension and then it proceeds to rotate.
Yuandao N80RK, used nand_fix, 160dpi fix, model fix & model fix 2 in that order.
72 Guest(s)
Devices in use: Desktop (62), Phone (10)
swan12
heftpflaster
