The_Maximus
France
Forum Posts: 20
286
2014/11/23 - 17:32
With the new CrewRKTablets_KK_Omni_v1.4.1_model fix_Aoson_M30Q_GT911 (4) (simply reboot in cwm and update from zip)
Desktop menu on the top of the screen, cam menu on the left of the screen like the first time (icons upsidedown).
The two cam images are Ok !
- Max -
287
2014/11/23 - 17:35
To understand this with the desktop menue ... can I have a simple screenshot?
The_Maximus
France
Forum Posts: 20
288
2014/11/23 - 18:17
- Max -
The_Maximus
France
Forum Posts: 20
290
2014/11/23 - 18:35
It's ok for the desktop menu and the rotation of the screen with the last fix CrewRKTablets_KK_Omni_v1.4.1_model fix_Aoson_M30Q_GT911 (5).
But the two cam are 180° image error now, i suppose it's logic.
- Max -
The_Maximus
France
Forum Posts: 20
292
2014/11/23 - 18:52
You finally fix all !
Thanks ! Great job.
- Max -
293
2014/11/23 - 19:31
Fine. Documented here: http://crewrktablets.arctablet.com/?p=3555
Loko222
Forum Posts: 17
294
2014/11/26 - 01:31
So I did something wrong.
Have the yundao n80 (which is in the list of tablets that it works on), and had some rom on it, 4.1.x I think.
Fixed my flash problem, wasn't using the correct kernel for my tablet.
Though I am getting hit every sec by system ui process has stopped. Will be trying to flash the nand_fix, model fix etc.
Flashed 160dpi, model fix 1 & 2 (2 seemed to fix it).
What I am getting now is that when it rotates, it lags for a tiny bit, the resolution changes width or height gets smaller and then it rotates.
Redin
Forum Posts: 19
295
2014/11/28 - 23:41
Qilive:
Download pack: http://crewrktablets.arctablet.com/?wpfb_dl=1901
Download kernel and Parameter, unzip the files and replace them in the pack:
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1898
Parameter: http://crewrktablets.arctablet.com/?wpfb_dl=2043
Download update and model fix and copy to external sdcard:
Update: http://crewrktablets.arctablet.com/?wpfb_dl=1916
Model fix: http://crewrktablets.arctablet.com/?wpfb_dl=1896
Flash according to instructions and install update and model fix directly after first boot into CWM.
- Oma
Awesome - I have only problems on my camera. It revert 90 degrees allways from true view. Any sugestion to fix? Many thanks.
My device: QiLive 97R - RK31 JDQ39
Redin
Forum Posts: 19
296
2014/11/29 - 00:03
Final try: http://crewrktablets.arctablet.com/?wpfb_dl=2262
Hi, OMA, you finaly are corret with "The Maximus" device.
Do you know if is the same to may KiLive 97r ? My camera are 90 degrees true view.
297
2014/11/29 - 11:11
As fas as I know there are three different hardware revisons (Qilive 97R, 97R-2, 97QR).
Which kernel is on the tab? Can you provide a screenshot of settings/About the tab?
Redin
Redin
Forum Posts: 19
298
2014/11/29 - 11:37
Thanks to replay.
Yes, see attachement - thats my original QiLive ROM
QiLive-97R001.jpgImage Enlarger
299
2014/11/29 - 16:47
ro.product.model=QiLive 97R
ro.build.fingerprint=QiLive/RKQILIVE97R/QiLive97R:4.2.2/JDQ39/20130829.165007:user/release-keys
ro.ota.product_name=aqilive97qr
kernel ok #377 preempt 29 Aug 2013
A dump from that firmware is here: http://neurodesigns.com/Qilive/StockRomQilive97R_aqilive97qr.rar
Kernel ok #377 is already in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1898
Latest Omni build v1.4.1:  http://crewrktablets.arctablet.com/?wpfb_dl=2035
Change parameter in /rockdev and kernel in /rockdev/Images. Flash incl. eraseIDB. After first boot into CWM do a factory reset and reboot.
Redin
Redin
Forum Posts: 19
300
2014/11/29 - 19:19
Thanks.
Camera is now ok, but NOW it do not make rotation. Any fix?
74 Guest(s)
Devices in use: Desktop (63), Phone (11)
swan12
heftpflaster
