ti5002000
Forum Posts: 21
2014/07/02 - 01:12
Hi Oma
First thanks for yout great work.
I will ask you if you could port this to the tablet qilive 97r (http://www.qilive.com/produit/tablette-97-quad-core) which is a tablet that is almost equal as the archos 97b platinum but the touchscreen driver isnt equal as i experienced.
if you want i can provide you the kernel of qilive 97r.
the issue is that Odys Iron OmniRom 4.4.2 custom root firmware boots but wifi dont work and screen rotation.
thanks
2014/07/02 - 06:56
Pls let me have a logcat and a dmesg log of the running stock firmware first.
ti5002000
Forum Posts: 21
2014/07/02 - 14:34
The problem is that i don't have The stock firmware any more. I accidentally deleted The ROM and only managed to get The kernel, boot, and recovery. I get that from a post that you answered, asking for a ROM for The tablet, where you asked for that. So you saved my life.
I tried all your firmware. The only one in which works wifi, rotatation, etc is The one 4. 4 for pipo 8 But It is a bit show.
I also tried your cm11 and The wifi works well But not The screen rotation and Bluetooth. What a pity. The build was so good.
If you could get some fix for this..
Many Many thanks
ti5002000
Forum Posts: 21
2014/07/02 - 14:36
And if you want The kernel number and other things im here for What is needed thanks a lot
2014/07/02 - 20:19
I need to see your hardware. Best is logs from a working build (U8).
ti5002000
Forum Posts: 21
2014/07/02 - 21:16
Can you Please tell me how I Should do The procedure?
Thanks for your time oma
2014/07/02 - 22:37
Open a terminal and type:
su
dmesg >/mnt/sdcard/dmesg.txt
ti5002000
Forum Posts: 21
2014/07/03 - 01:12
There you go
Thanks for your precious time
ti5002000
Forum Posts: 21
2014/07/03 - 02:30
Oh i forgot to tell that the display, when i install the build of the pipo u8 ,it starts inverted and the camera only gives me purple.
2014/07/03 - 17:19
Ok, RK903 wifi.
Try the v1.2 build: http://crewrktablets.arctablet.com/?p=2982
Install this model fix as first guess: http://crewrktablets.arctablet.com/?wpfb_dl=1816
ti5002000
Forum Posts: 21
2014/07/03 - 17:29
ok thanks a lot OMA .
one questtion : why the wifi works in CM build for example and in others no?
2014/07/03 - 17:40
Just not implemented. We are trying to make our own wifi chips work first. Still not stable.
ti5002000
Forum Posts: 21
2014/07/03 - 17:51
oh i see i understand completely.
Many thanks i will try your solution later when i am at home
ti5002000
Forum Posts: 21
2014/07/04 - 01:18
Well after testing your sugestion here the results:
-The wifi and bluetooth works
-the display are upside down but the rotation works and touch works well ,not inverted (in omni rom the touch works inverted)
-the camera gives me some photos with the tendence to be red and the image are upside down too
many thanks Oma
2014/07/04 - 07:15
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=1896
Can you pls upload the kernel for the archive?
75 Guest(s)
Devices in use: Desktop (61), Phone (13), Tablet (1)
Javier1994
jcn50
cleopatra duran
perelliz
johnpierrepierre
stumts
