256
2014/11/22 - 10:39
So, you have now a strange firmware in your touch controller. Obviously the stock kernel will not flash the right firmware back. We cannot do much in that case. Sorry
Jammed_Death
Forum Posts: 51
257
2014/11/22 - 10:44
The_Maximus said
I have installed this rom on my Aoson M30Q.
But at the first try i made a mistake i don't change the Kernel.img like Livendead say ... so black screen and tablet unresponsive.
I make a new install with the Aoson M30Q kernel from crewrktablets.arctablet.com and Odys Iron OmniRom 4.4.4 v1.4.1.
(I use the process of livendead in page 4 of this tread)
It works, the tablet and the rom start, but the touch screen not work !
I try again with the v1.3.1 and 1.3 applying model fix and phantom rotation fix, not better.
Finally install Aoson M30Q Love Li Shun - 2014-6-3 stock rom. And touch screen still not work.
My tablet is HS or i can try something ?
(Sorry for my bad English).
hi, unfortunately for you aoson made more than 1 model of m30q. So you should go to szaoson.com with google translate and find the correct stock rom...there are at least 3 of them everyone change the sensors compatibility. Try with that and you should solve your issue :)
The_Maximus
France
Forum Posts: 20
258
2014/11/22 - 10:52
Two things i forgot :
the tablet is usable with an usb mouse (i'll try an 2in1 usbmouse keyboard too).
And when i boot the tablet there a sound, a tick tick 5-6 times.
I will try other rom from the szaozon.com download center (i found 4 roms) maybe i'll a have a chance a flashing the right firmware back ?
Edit : Ok Jammed_Death, thanks i'll do that.
- Max -
259
2014/11/22 - 10:59
Ok, the names of the firmwares indicates two different touch controller: Goodix GT911 and VTL CT363. Maybe you have luck.
@ Jammed_Death: is there a chance to idenify the hardware revision by serial-number or other criteria?
The_Maximus
France
Forum Posts: 20
260
2014/11/22 - 11:39
I'm downloading the 4 rom on szaozon.com.
I'll try first the two with touch screen controller named.
No serial on my tablet, on serial on the box : LST-M30Q13450112.
I'm going to try Antutu or a device analyser ?
- Max -
261
2014/11/22 - 13:59
Yes, try this two ones.
- Om a-
The_Maximus
France
Forum Posts: 20
262
2014/11/22 - 14:14
Ok, the first i try work's. Thank's all !
For my Aoson m30Q the rom stock working is :
M30Q-爱立顺-GT9110-王坚-0905-update ( M30Q- Ericsson long -GT9110- Wang Jiang-0905-update)
I have M30Q with a Goodix GT911 touch controller ?!
I can test the 3 other rom if you need more feedback.
First i'l try to create a kernel.img backup from this stock rom for using it with your Omni rom.
- Max -
Jammed_Death
Forum Posts: 51
263
2014/11/22 - 16:31
happy to know about it
@oma: the one who helped me on another board tried all the roms and noone worked for him, al. The only way to identify the hw is opening the tablet and look at the board and chips but it's dangerous because there is a flex cable very short between digitizer and mainboard
the firmware M30Q 爱立顺 CT363TP 4.2(二维码M30Q后面加个5字 got a different digitizer chip. The one with "M30Q Love Li Shun latest TP and gravity sensor IC compatible" don't work either. The only one working is the  M30Q爱立顺4.2 but have some issues with the camera.
Apparently the aoson made a mess with firmware and hw revisions. With this mess some of the aoson firmware work with aoson, some with qilive and some with archos 97b platinum. This makes the rom development a mess and this require all the fixes for rotation and more :/
ps: i hope i explained myself, it's a mess talking about this arguments for a non english guy :D
264
2014/11/22 - 17:53
Thanks Jammed_Death! I am also not a native speaker ... all clear for me what you did explain.
I also spent some time on it:
M30Q Love Li Sun original - kernel #51 preempt 4. July 2013
M30Q Love Li Sun latest touch panel - kernel #142 preempt 27. Sep 2013 (was already in the achive)
M30Q Ericsson long GT911 touch panel - kernel #94 preempt 5. Sep 2013
M30Q Ericsson long CT363 touch panel - kernel #97 preempt 6. Sep 2013
Hope this helps.
Jammed_Death
Forum Posts: 51
265
2014/11/22 - 18:44
nice :D
The_Maximus
France
Forum Posts: 20
266
2014/11/22 - 19:31
Really nice !
I spend my day to backup my kernel stock's rom ... you give us the 4 Great.
So i try the 1.4.1 version with CrewRKTablets_KK_Omni_v1.3_model fix_Aoson_M30Q_2 and Oma_Chuwi_V88_rotation_fix.
Screen up is down and down is up !
With the 1.3.1 and the same fix, screen ok ! But i can't activate Wifi function :/
- Max -
267
2014/11/22 - 19:49
Ok, with build 1.4.1 you have working wifi?
The_Maximus
France
Forum Posts: 20
268
2014/11/23 - 00:53
I'll check wifi in 1.4.1 build after sleeping.
- Max -
The_Maximus
France
Forum Posts: 20
269
2014/11/23 - 10:26
With 1.4.1 Build and no fix :
Wifi ok, bluetooth ok, HDMI out ok.
Screen ok, no upsidedown, but no rotation !
Camera ok but inverted with 90° to the left.
A new test with CrewRKTablets_KK_Omni_v1.3_model fix_Aoson_M30Q_2 is on the road.
- Max -
The_Maximus
France
Forum Posts: 20
270
2014/11/23 - 10:45
With 1.4.1 Build and CrewRKTablets_KK_Omni_v1.3_model fix_Aoson_M30Q_2.
All exactly the same + screen up side down again !
I test with Oma_Chuwi_V88_rotation_fix only.
- Max -
77 Guest(s)
Devices in use: Desktop (70), Phone (6), Tablet (1)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
