241
2014/11/13 - 18:13
Ok, in CWM now do a factory reset and reboot.
Ovidiu M.
Romania
242
2014/11/13 - 19:37
I did that every time when, after installation, enter CWM.
Maybe if I test other files, another kernel or another boot ....
I do not know what files. Not find anywhere someone with this tablet which use kitkat.
P.S. I tested the original kernel Odys Iron and unlike the tablet PMP5297c, he show blue logo "Crew rktablets".
OlivioFarias
243
2014/11/13 - 21:07
Hello Friends, I would like to know if you have a firmware update for the tablet below.
http://qilive.com/produit/tablette-785-quad-core
I would love to upgrade to version 4.4, could someone help me? From already thank you very much for your help.
If English is faulty is the fault of google translator hahahaha.
244
2014/11/14 - 10:34
Qilive:
Download pack: http://crewrktablets.arctablet.com/?wpfb_dl=1901
Download kernel and Parameter, unzip the files and replace them in the pack:
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1898
Parameter: http://crewrktablets.arctablet.com/?wpfb_dl=2043
Download update and model fix and copy to external sdcard:
Update: http://crewrktablets.arctablet.com/?wpfb_dl=1916
Model fix: http://crewrktablets.arctablet.com/?wpfb_dl=1896
Flash according to instructions and install update and model fix directly after first boot into CWM.
OlivioFarias, Redin
245
2014/11/14 - 10:40
@ BPNL & Ovidiu M.
Try again and let me know the results:
Download pack: http://crewrktablets.arctablet.com/?wpfb_dl=2035
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1533
Flash according to instructions.
246
2014/11/14 - 10:44
@ pbecks1963
Did you check your USB driver? Any joy with the CM11 build?
You can also test this parameter file: http://crewrktablets.arctablet.com/?wpfb_dl=2043
Unszip and replace in the pack. Do a fresh installation incl. eraseIDB.
pbecks1963
Forum Posts: 35
247
2014/11/14 - 11:05
pbecks1963 said
I just noticed that if i enable usb debugging i loose my connection on the PC (via usb). I disabled usb debugging but didn't get the connection back (also tried a reboot)
Could be a driver and/or a NAND issue. Re-install the USB-driver: http://crewrktablets.arctablet.com/?wpfb_dl=2016
De-install driver first, then install again.
Check with latest CM11 build if you get the same issues: http://crewrktablets.arctablet.com/?p=3591
Just change the kernel.
Just so i understand right: flash the above mentioned build (but with the kernel i got with this build)
ps: usb-driver did not work on win8.1/64 (at home). I will first try the CM11 build.
TABLET: Lifetab e10320 tablet (RK3188) 1.280 x 800 pixels screen.
ROM: OMNI 4.4.4-20140817-rk31board-HOMEMADE
pbecks1963
Forum Posts: 35
248
2014/11/14 - 12:38
I think i completely bricked my tab... :-(
(will try to get life into it at home. maybe it's just a dead battery, i noticed the battery was draining when connected to usb/pc strangely enough)
Mhh.. it's not completely bricked (it can be "found" but won't boot into cwm...)
Ovidiu M.
Romania
249
2014/11/14 - 15:33
@ BPNL & Ovidiu M.
I suppose if go into CWM after formatting ... not have to wait 4 minutes.
Nope ... does not work.
Hm... What wrong? BPNL said that working with him. Strange ... Very strange.
I have rewritten a HTC and Sony. And they worked. I mean, I do not think I make a silly mistake.
OlivioFarias
250
2014/11/14 - 15:54
Qilive:
The pack comes with Kernel Parameter, and model updates fix?
Many thanks for the help!
BPNL
251
2014/11/14 - 16:23
Ovidiu M. said
@ BPNL & Ovidiu M.
Hello Mr. Ovidiu,
I reinstalled again with the CrewRKTablets_RK31_KK_Omni_parameter_dynamic parameter, ( I innitialy installed with the 8G parameter.
What I found out it is very important to do the Oma_DevelopTool_Refresh (read the steps carefully with erase blocks).
http://crewrktablets.arctablet.com/?wpfb_dl=1631
Run the RKDevelopTool:
- load the v1.24 loader
- Erase IDB Block
- Erase All Blocks
- Download
Then run RKAndroidTool:
- untick loader
- EraseIDB
- Run
Furthermore I installed as above
I found some useful info in the instruction file :
first install only
3. boot your Oyds Iron and set storage mode to MTP and debugging to USB
4. run DriverInstall.exe
5. run RKAndroidTool.exe with admin rights
6. press power button and volume up button and hold for 12 sec
7. release the power button
8. release volume up button 2 sec after "Found ..." is shown
9. select EraseIDB
10. select Run
11. Iron will boot into CWM
12. release a factory reset
13. go back, reboot system (do not fix su)
14. wait 4 min
Working on a win7 PC, hope this helps
Ovidiu M.
Romania
252
2014/11/14 - 17:39
@BPBL
Once I run RKDevelopTool (after found my tablet, load bin file, Erase ID Block, Erase ALL Blocks and Download) my tablet no longer connects to the USB: "Windows Does not Recognize USB malfunctioned".
In order to go to next app and connect tablet with RKAndroidTool I must use Hynix Chip reset by connecting pins 7-8.
Only then works EraseIDB (with untick loader), but when hit RUN it asks to activate loader. With loader check the device not reset and Run failed and... "Windows Does not Recognize USB malfunctioned" again.
OlivioFarias
253
2014/11/14 - 20:49
My Qilive got white screen and will not give out. Where do I install the drive correctly on it?
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
254
2014/11/15 - 02:08
Hello again everybody,
I wonder if anyone out there have installed this rom on an M9 pro?
Pipo M8pro
Pipo M9pro
Pipo P4
The_Maximus
France
Forum Posts: 20
255
2014/11/22 - 09:34
I have installed this rom on my Aoson M30Q.
But at the first try i made a mistake i don't change the Kernel.img like Livendead say ... so black screen and tablet unresponsive.
I make a new install with the Aoson M30Q kernel from crewrktablets.arctablet.com and Odys Iron OmniRom 4.4.4 v1.4.1.
(I use the process of livendead in page 4 of this tread)
It works, the tablet and the rom start, but the touch screen not work !
I try again with the v1.3.1 and 1.3 applying model fix and phantom rotation fix, not better.
Finally install Aoson M30Q Love Li Shun - 2014-6-3 stock rom. And touch screen still not work.
My tablet is HS or i can try something ?
(Sorry for my bad English).
- Max -
93 Guest(s)
Devices in use: Desktop (85), Phone (8)
swan12
heftpflaster
