pbecks1963
Forum Posts: 35
211
2014/10/25 - 14:26
Back on the android 4.4.4.-rom again. Tried fix1 (did nothing, no rotation). Tried fix2 (auto rotate works but all "up" becomes "down"
TABLET: Lifetab e10320 tablet (RK3188) 1.280 x 800 pixels screen.
ROM: OMNI 4.4.4-20140817-rk31board-HOMEMADE
212
2014/10/25 - 14:29
What do you mean by fix2?
pbecks1963
Forum Posts: 35
213
2014/10/25 - 14:36
fix2: CrewRKTablets_KK_Omni_v1.4.1_model fix_Medion_E10320 (i assumed this zip is different than fix1: CrewRKTablets_RKxx_160dpi)
214
2014/10/25 - 14:40
Download again and check: http://crewrktablets.arctablet.com/?wpfb_dl=2193
pbecks1963
Forum Posts: 35
215
2014/10/25 - 14:47
YES YES YES!!! Rotation works as it should. thanks to the fix in post #214
Thank you...
BPNL
216
2014/10/26 - 21:10
I try to put KitKat on my Prestigio Multipad 4 Quantum 9.7 PMP5297C_Quad rooted. With a RK3188.
The Tablet is connected to my Computer and visible, I install runs okay but after download it gives a fault.
Somewhere I missed something.
Anybody suggestions?
Foutmelding.JPGImage Enlarger
217
2014/10/26 - 22:10
Try again, incl. eraseIDB.
BPNL
218
2014/10/27 - 09:03
Unfortunately tried but did not work, same fault.
When I get the tablet in recovery I get the following faults :
: invallid command argument
can't mount  /cache/recovery/log
can't open  /cache/recovery/log
can't mount  /cache/recovery/last_log
When I try to mound /sdcard
Error mounting /sdcard!
goes for all the mound commands.
219
2014/10/27 - 17:05
Same fault? Last time you reported Run failed ...
Errors in CWM are not relevant (last_log can't be there). Do a factory reset and reboot system.
BPNL
220
2014/10/27 - 17:21
Thank you for your quick response
Sorry, if it was not well-defined, last time it gave the same fault it is writing the flash, then when is checking download file, it says download failed foutmelding-2.JPGImage Enlarger
After that i tried with CWM, an saw that I can't mount sd and ext-sd.
If I try to flash the kernel from RK31_kernel_3036_hr_pmp5297c_prestigio it gives load firmware failed.
I did manage to install RK3188Loader(L)_V1.24
221
2014/10/27 - 17:48
Pls try to refresh the NAND. Tool is here: http://crewrktablets.arctablet.com/?wpfb_dl=1631
BPNL
222
2014/10/28 - 15:14
Not working yet,
Steps made till now.
USB bugging on, set to MTP.
Copy parameter_8GB as zip an unzipped to the ext sd
Run NAND tool load RK3188Loader(L)_V1.24 erase ID, blocks Erase all Blocks.
Run RKAndroidtool EraseIDB (here I can not uncheck loader).
Than I run, with same result ever time as shown in above pictures download file failed.
I attach the log maybe you can seen something about it.
My knowledge is not as high.
Good thing is I still manage to get the original img back on my Prestigio :-).
Thank for looking in to my questions.
223
2014/10/28 - 16:34
Unpack the parameter file and replace the one in folder rockdev. Flash again incl. eraseIDB.
BPNL
224
2014/10/28 - 17:31
Thank you working on my Prestigio!, now looking around one my tablet :-)
Jammed_Death
Forum Posts: 51
225
2014/11/02 - 21:28
ehy oma there will be more updates? Lollipop maybe?
ps: about this
http://www.xda-developers.com/android/entropy-seed-generator-not-all-its-hacked-up-to-be/
apparentrly entropy is useless on performance, should we remove the fixer?
93 Guest(s)
Devices in use: Desktop (84), Phone (9)
swan12
heftpflaster
