Thanks Received: 3171
196
2014/10/09 - 23:46
4thjak said
Wifi depends on you wifi chip. Pls provide a dmesg log from the running stock firmware.
- Oma
How?
4thjak,
Oma already gave some details on extracting a dmesg log, please read the first post pages in the current topic.
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
197
2014/10/10 - 04:25
ok, I've been jumping pages, maybe next I'll be tingkering it again. All the while I was waiting a reply here, I also tested sir KK Fudge's Omni rom, it was almost perfect, fluidity ang all, but connection between pc and tab is not ok.
Pipo M8pro
Pipo M9pro
Pipo P4
pbecks1963
Forum Posts: 35
198
2014/10/21 - 10:32
Hello Oma,
I am ready to update to this rom. I've downloaded all the files and am ready to start flashing (did a factory reset om the tablet for good measure). But somehow i can't get into the flash mode.. (that was: keep  volume + and power button pressed for 12 seconds, right?)
Any help?
ps: i changed boot animation a while back and am wondering if that is causing trouble now...
ps2: IT WORKS! (win8.1 64 bit was the problem)
TABLET: Lifetab e10320 tablet (RK3188) 1.280 x 800 pixels screen.
ROM: OMNI 4.4.4-20140817-rk31board-HOMEMADE
pbecks1963
Forum Posts: 35
199
2014/10/21 - 22:03
Hello Oma,
It seems that my sensors don't work anymore. I noticed that my screen wouldn't rotate on its own. Sensor-check-apps from the play-store all fail to test my sensors. (GPS and gyroscope)
I did a reboot and added the dmesg-log to this post..
(also i can't get to the tablet using usb-cable/pc, on win7/64 and win8.1/64 the drivers that come with the package don't work)
(also: camera force closes. Edit: only on ART, switched back to DALVIK). Other sensors still don't work.
pbecks1963
Forum Posts: 35
201
2014/10/22 - 20:27
Is a factory reset necessary? (getting FC's, i already wiped dalvik cache)
"proces com.android.systemui has stopped"
202
2014/10/22 - 20:34
Did you install the 160dpi fix?
Download the model fix again: http://crewrktablets.arctablet.com/?wpfb_dl=2193
Do a factorey reset and install the model fix.
pbecks1963
Forum Posts: 35
203
2014/10/22 - 21:01
Hello Oma,
Did the Factory reset and installed the fix.
First message after the reboot: "Der Prozess "com.android.systemui" wurde beendet. (and a bluetooth-freigabe error message)
204
2014/10/22 - 21:06
Ok, one step back. Do a clean install incl. eraseIDB and install only the 160dpi fix: http://crewrktablets.arctablet.com/?wpfb_dl=2013
pbecks1963
Forum Posts: 35
205
2014/10/22 - 21:18
(Just a quick reply. Rotation works but gives me a mirror image. )
 Back to the problem:
Just that i understand what i need to do now:
1) In the RKAndroidtool: erase IDB
2) In the RKAndroidtool choose options: 1 till 7)
3) flash rom (choose the RK31_kernel_3036_e10320_medion for option 4)
4) First reboot is in cwm: flash fix
Right?
206
2014/10/22 - 21:20
Yes. Waht do you mean by mirrored image?
pbecks1963
Forum Posts: 35
207
2014/10/22 - 21:27
If i turn the tablet 180 degrees the image flips 180 degrees in the wrong direction. Up becomes down.
ps: have to flash tomorrow (win7 pc is upstairs in my kids bedroom)
ps: i just noticed that the virtuall buttons on the bottom of the screen are gone. It's a 1.280 x 800 pixels screen.
pbecks1963
Forum Posts: 35
208
2014/10/23 - 12:25
Flashed. Now the tablet still has the FC's AND closes itself after a while. (and the virtuall buttons are not visable)
209
2014/10/23 - 15:57
Hm, not really clear what it is. Try an older build: http://crewrktablets.arctablet.com/?wpfb_dl=1901
Make sure to install the 160dpi fix.
pbecks1963
Forum Posts: 35
210
2014/10/23 - 16:55
tried the older build: Tablet is still booting. I powered the tablet off after 20 minutes. Tried again with same result. Played in cwm with factory reset/clear (dalvik) cache/fix root, flash with and without the fix. No success.
I did a cwm-restore (Oma RK31 010320 JBv1.0 - 06.05.2014).
Will try again later (when i feel lucky or you have a new fix/idea)
Thanks for all!
85 Guest(s)
Devices in use: Desktop (76), Phone (9)
swan12
heftpflaster
