Thanks Received: 1381
136
2014/08/18 - 09:11
Put the sd card in before you start. Do a clean install incl. eraseIDB. In CWM do a factory reset and install the model fix.
nelySLB
Forum Posts: 34
137
2014/08/18 - 09:18
done, no joy, same can't mount
when factory reset on cwm
Wipping data
Formatting /data...
Formatting /cache...
Formatting /sd-ext...
No app2sd partition found. Skipping format of /sd-ext.
Formatting /sdcard/.android_secure...
Error mounting /sdcard/.android_secure!
Skipping format...
Data wipe complete.
138
2014/08/18 - 09:47
Looks ok. What is the result of install model fix from external sdcard?
nelySLB
Forum Posts: 34
139
2014/08/18 - 10:12
None, it can't mount it on cwm
And i can't sideload the file either
140
2014/08/18 - 10:15
Install zip from sdcard > choose zip from external sdcard.
nelySLB
Forum Posts: 34
141
2014/08/18 - 10:31
can't mount external sd
hnito82
Forum Posts: 11
142
2014/08/18 - 10:46
Hello Guys has anyone installed this rom on tablet Mediacom 8 S4?
Oma please could you help me with the installation of this rom I'm afraid to do something wrong and crash the device
143
2014/08/18 - 11:36
Mediacom MP84S4 has RTL8723 wifi. So build should work.
Kernel is here: http://crewrktablets.arctablet.com/?wpfb_dl=1790
Just change the kernel in folder rockdev/Images before flash. In CWM do a factory reset and install the 160 dpi fix.
hnito82
144
2014/08/18 - 11:37
Can you pls check the external sdcard on your PC? One patition, FAT 32 formatted and without errors?
nelySLB
Forum Posts: 34
145
2014/08/18 - 12:01
e: error in /external_sd/crewrktablets_kk_omni_v1.3_model fix_cube_u30gt2.zip
(status 6)
installation aborted
146
2014/08/18 - 12:27
It seems your sd card is somehow corrupt. Format the sd card. Download the model fix again and copy it to the sd card. Insert the sdcard and boot into recovery.
nelySLB
Forum Posts: 34
147
2014/08/18 - 12:54
tryed 4 diferent cards always new download always same result (status 6) installation aborted
only 16gb usable. the fix fix this?
PrEzi
Forum Posts: 57
148
2014/08/18 - 13:13
Status 6 during installation of an CWM package indicates an syntax error in the updater script.
Most common problems :
-- there is a "hidden" newline character from Windows (should be in *nix format) in the updater script
-- CWM Version older than 6.0.4.9 (I think) when flashing KK-Roms/updates -- since KK updates are using (or  can use) some additional commands that are not recognized in older CWM Recoveries.
Unfortunately from work I cannot access my tools nor am I allowed to download external files...
That is why I cannot help further... but I would strongly suggest to check those two tips.
149
2014/08/18 - 14:27
Ok, updated Cube U30GT2 model fix for build v1.4: http://crewrktablets.arctablet.com/?wpfb_dl=2021
Try again.
nelySLB
Forum Posts: 34
150
2014/08/18 - 15:02
Try again.
Previous to the fix tablet booted on landscape
After fix booted on portrait
Still no auto rotation
Camera not inverted anymore now is fine
Tablet have 32gb internal storage only shows 16gb
116 Guest(s)
2 Guest(s)
Devices in use: Desktop (104), Phone (12)
quodiddle
dakarpesca
Andrews666
Jonny2020
passsaris
sepa1999
