2014/05/30 - 20:49
Gents,
OmniRom has landed on Odys Iron.
Update: release build v1.4.1 ;-)
Stuff to adapt the build for other tabs: http://crewrktablets.arctablet.com/?p=3555
IRON by CrewRKTablets Omni 4.4.4 build v1.4.1 (implement hwcomposer)
IRON by CrewRKTablets Omni 4.4.4 build v1.4  (implement multi-windows)
IRON by CrewRKTablets Omni 4.4.4 build v1.3.1  (first stable roll-out release)
– generation 1 loader
– selinux off
– CWM 6.0.3.1 recovery
– system ext4
– homebrew kernel jk #1
– unified internal storage
– screen 264 dpi
– PhabletUI & Multi-User
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
not working:  ./.
flash instructions are included in the download pack.
if you are on a gen2 loader firmware (KitKat) change the loader first.
how multi-window works.
hints:
- to improve UI feeling: disable all animation scales in developer options,
...use Nova launcher and set animation/scroll to "faster than light" and
...enable Entropy Fixer with value 256
- to improve battery drain set keep wi-fi on during sleep to never
- to get full access to the build enable /system rw in File Manager HD
- to disable su notifications change notification in settings/SuperSu
Special thanks to netlars & JochenKauz
– Oma -
 v1.4_01-1.pngImage Enlargerv1.0_05-1024x768.jpgImage Enlargerv1.0_10-1024x768.pngImage Enlargerv1.4_04-1.jpgImage Enlargerv1.4_06.pngImage Enlargerv1.4_06a.pngImage Enlargerv1.4.1_02.pngImage Enlargerv1.4_03.pngImage Enlarger
BPNL, hurricane165, w3bb4
2014/06/01 - 12:36
Ok, now stable wifi & BT ;-)
Any feedback from beta-testers?
Screenshot_2014-06-01-12-22-26.pngImage Enlarger
Screenshot_2014-06-01-11-40-20.pngImage Enlarger
2014/06/01 - 21:55
Update post #1 with build v1.1.
v1.1_01.pngImage Enlarger
JFK
Forum Posts: 16
2014/06/02 - 18:39
I install Yuandao mini one BZ model.
Becouse , it have MT7601u ifi driver.
But , can't load.
I really wait for BZ kitkat so.
Rock293031
Forum Posts: 39
2014/06/03 - 01:21
Hallo Oma,
erster Test mit dem RK3066 imuz TX12d.
8GB Parameter und 160dpi fix. Sonst alles aus dem Package.
Bekomme einen Fehler bei Format NAND, nicht alle Permissions konnten gesetzt werden.
Tab bootet, WLAN ok, BT lässt sich nicht aktivieren.
Rotation rührt sich nicht. Tab bleibt im Landscape Modus, wird aber von Apps korrekt geändert (z.B. Benchmark)
Fast keine HW overlay Probleme. Display so gut wie perfekt.
HDMI funktioniert. Finde aber keine HDMI settings.
dmesg/logcat folgen morgen. Bin saumüde nach einer 5Stunden Autofahrt.
Danke !!!
Gruss, Neptune
2014/06/03 - 19:54
Sounds good. Ausgeschlafen?
Rock293031
Forum Posts: 39
2014/06/04 - 02:43
Hallo Oma,
ja, hab endlich ausgeschlafen. Diese Montags-Fahrten in die Arbeit gehen ziemlich an die Substanz.
Hab mit dem Tab noch ein wenig herumprobiert.
Overlay Fehler konnte ich bisher keine feststellen. Das Tab läuft soweit sauber und stabill.
Ich habe die logs angehängt, falls Du mal draufschauen willst.
Bei Antutu hinkt es ein wenig den anderen Builds hinterher, nicht ganz 11.000 Punkte. Hab das Tab 2x. Auf dem 2ten ist noch die 4.1.1 Stock. Die kommt auf 15.000. Erstaunlich viel für ein RK3066?!.
Probleme habe ich folgende:
- Sobald ich nach einem Update der Gapps das Tab neu starte, bleibt es im Boot-Loop. Nach dem Update aus dem Playstore gibt es nach einer Weile einen Massen-FC der meisten gapps und das Tab hängt sich nach Neustart auf. Hatte das Problem aber auch mit dem AOC Rk903 Test-Build. Habe mal das logcat_bootloop file angehängt. Hoffe, dass ich den Nand nicht schon totgeflasht hab...
- Display Rotation geht nicht. Kamera ist +90Grad im Uhrzeigersinn.
- BT geht nicht an.
Ich kannte bisher OmniRoms nicht. Ich muss sagen, das gefällt mir sehr gut.
Mein Test ist natürlich kaum aussagekräftig für Dein Build, da Du es ja speziell für das Iron kompiliert hast.
Und ich teste ja mit meinem alten RK3066 Tab. Hoffe ein Iron Besitzer testet es mal und gibt Feedback.
Wünsche Dir einen schönen Mittwoch. Bald ist wieder Wochenende!
Grüsse, Neptune
2014/06/04 - 06:07
Fein.
4.2 ist auf dem RK30 deutliche "langsamer" als 4.1. RK hat sich nie die Mühe gemacht, 4.2 für den RK30 zu entwickeln. Hier müssen wir mit den vorkompilierten Binaries leben, bzw. die Binaries vom RK31 passen ja auch nicht perfekt. Aber sie laufen auf dem 36er Kernel, den es ja auch nur für eine handvoll Tabs gibt.
Kannst du bitte noch die Logs anhängen?
Rock293031
Forum Posts: 39
2014/06/04 - 19:25
Hallo Oma,
sorry, war schon wieder halb am Schlafen und habe die Logs vergessen.
Hier sind sie.
Grüsse!
P.S. Habe jetzt mal auf ein Update der Google Play-Dienste verzichtet. Bisher bootet das Tab normal neu.
grindio
2014/06/05 - 02:00
Would this rom work on a vido, Yundao, Visture or dragon touch?  I haven,  heard of this odys iron before.
2014/06/05 - 06:33
Iron Build is for RTL8723 wifi. Tabs you asked for are MT5931 wifi. Compilation of MT5931 wifi still fails.
anu2013
Thanks Received: 4
2014/06/12 - 11:45
possible to support gen2 loader?
I have ifive mini3 retina. So came with kk 4.4.2 gen 2 loader.
I want install Omni rom in my tablet.
Plz help to support gen2 loader.
PrEzi
Forum Posts: 57
2014/06/16 - 12:33
Hallo Oma!
Dank dir habe ich mir auch ein Odys Iron bestellt ;)
Jetzt nur die Frage - welch von dem drei Firmwares das Beste/Stabilste ist -- Omni, CM oder Stock ?
Ich denke mal -- Stock hat am wenigsten Fehlern oder ?
Und nochmals -- vielen Dank für deine Arbeit !!
2014/06/16 - 15:38
Es gibt 4 Builds im Status stable:
- JB Stock Edition
- JB Multi-Windows Edition
- CM10.1 Edition
- KitKat Edition
Omni-Rom und CM11 haben frühen Beta-Status.
2014/06/16 - 15:50
It seems to be RK's target is to keep community out with the new environment (gen2 loader, selinux kernel, selinux build) of JB and KK firmware. No source code and no kernel sources are available for tabs.
The already seen KK stock firmwares are still not in a stable condition. Surprisingly new tabs comes with JB firmware.
We are still of the opinion that a more open strategy will support their sales and give them the opportunity to get improved code back.
So, in this special case we cannot be of any help. Sorry.
56 Guest(s)
3 Guest(s)
Devices in use: Desktop (53), Phone (3)
