2013/12/21
arabi48 said
Unfortunately that isn't that simple. So, you have the M33 GB. With the M33 GB (JB) kernel you can boot the CM12 build, while the CM12.1 build doesn't boot?- Oma -
YES . ITS FREEZ IN KERNEL LOGO
MY TAB COME WITHE 4.1.1 FIRM
THIS IS MY TAB
2015/03/18
Cytryn said
Regarding new CM12.1 v1.1 build.
ro.sf.hwrotation is now active. So it should work with the stock HAL's.
Really good work . Now with this change i easly fixed my camera.
Any other important changes?
Still BT and 3G not working but i see some improvements regarding 3G.
3G working is rare for rk30/31 CM11/CM12/12.1 builds (i didnt find any) For CM11 rom i using i just using PPP widget 2 app, but sadly its not working for CM12/12.1 builds. Author of ppp widget 2 just not supporting custom roms.
Anyways good work so far, keep it up.
2014/04/30
Can you pls check if rotation/orientation is right with build v1.1 and this fix: http://crewrktablets.arctablet.com/?wpfb_dl=2677
It seems much better for Рipo m6pro, thanks!
+ screen rotation fixed.
+ cameras are OK too.
- bluetooth still doesn't turn on. (+ But it doesn't crashes any more)
- I confirm that:
Cytryn said
REgarding 3G, now i can turn mobile network (cellular data) and set apns and i can search and see my sim operators and register. But cant see signal icon, there is only "no sim card" icon and checked internet connection not working.
- was unexpected self-reboot.
- noticed a funny bug: long tap on icon or widget in desktop and menu causes a 180° screen rotation. So I can't move or delete icons and widgets.
2012/11/19
arabi48 said
YES . ITS FREEZ IN KERNEL LOGOMY TAB COME WITHE 4.1.1 FIRM
please do me a favor.. switch off the capitals..
Cheers
JochenKauz
MNT45Per aspera ad astra, we rock the Tablets !
2015/03/18
Ahh so this is downside of working ro.sf.hwrotation 🙂
Just install this Oma_Chuwi_V88_rotation_fix.zip it installing Rotate app as an system app and it fixing this bug. But need to be set to Force auto.
@Oma Just include this Rotate app in next build.
The following users say thank you to Cytryn for this useful post:
Cusco, peterme86
2015/06/15
Thanks for fw Oma.
I confirm installation CM12.1 v1.0 on Inch Sirius HD 16GB
Here is fix for tab CrewRKTablets_Odys_Iron_CM12.1_LP_5.1.1_v1.0 just dpi, rotation fix, camera rotation
Here is kernel http://crewrktablets.arctablet.com/?wpfb_dl=2318
Still needs to fix BT (BT turn on, but does not find devices).
The following users say thank you to atolzl for this useful post:
2013/06/29
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2676- Oma -
Thank you. But it is not earned.
Downlaod again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2676
romavdvPer aspera ad astra, we rock the Tablets !
atolzl said
Thanks for fw Oma.I confirm installation CM12.1 v1.0 on Inch Sirius HD 16GB
Great. Thank you for feedback!
Boot tab fresh, enable BT and try to search for devices. Then do a dmesg and a logcat log, pls.
Cytryn said
Really good work
Not bad for one day work 😉
Pls upload the model fix for documentation.
PPP widget should work, but I don't know much about your homebrew kernel. Maybe a driver issue.
Pls let me have a dmesg and a logcat log.
Cytryn said
Cusco said
- noticed a funny bug: long tap on icon or widget in desktop and menu causes a 180° screen rotation. So I can't move or delete icons and widgets.Ahh so this is downside of working ro.sf.hwrotation 🙂
Thanks for helping out here!
Depends on the kernel. It is the typical RK way ... fakerotation. We will correct that in the framework with the next build.
Is the kernel in the archive your stock kernel? If not where to find?
What is the NAND size? Did you ever run KK (gen2 loader) on the tab?
vitala1 said
Qlive 97RDear Oma.
I have this tablet: Qlive 97R,
I established CrewRKTablets_Odys_Iron_CM12.1_LP_5.1.1_v1.0,
I replaced in the folder "rockdev" - parameter(8GB) and kernel - RK31 Kernel 3036 97r Qilive(kernel archive).
Lollipop works, but there are problems:
1. Wi-Fi works, but an Wi-Fi Direct - no, (the indicator WiFi Direct is, but data transfers - No, on a network of a WiFi Direct it isn't visible);
2. USB Dongl HUAWEI E1550 sets connection (an icon in a tray - No, the indicator on the modem burns), but transmissions - no, there is no Internet.
3.overdue response of the touchpad.
2015/09/27
vitala1 said
Qlive 97RDear Oma.
3.overdue response of the touchpad.1. no idea for now2. can you pls check if it turns on by using PPP wiget 2 (see Play-Store)?3. what do you mean by overdue response?- Oma -
Hi.
2. Of course, I used this widget (PPP wiget 2). There is no icon of mobile data transfer.
3. time delay after clicking (time of a response of about 0,5 sec.).
69 Guest(s)
Devices in use: Desktop (61), Phone (8)
