Cusco said
- screen rotates but orientation is wrong (screenshot from landscape position
Can you pls check if rotation/orientation is right with build v1.1 and this fix: http://crewrktablets.arctablet.com/?wpfb_dl=2677
CuscoPer aspera ad astra, we rock the Tablets !
2013/06/29
Linux version 3.0.36+ (roman@roman-P53SJ) (gcc version 4.4.3 (GCC) ) #84 SMP PREEMPT Fri Sep 25 18:32:46 MSK 2015
Ok, homebrew kernel 😉
[ 11.723216] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xdf0ac000
[ 11.723290] request lcd en pin fail!
[ 11.723321] fb0:win1
[ 11.723326] fb1:win0
[ 11.723330] fb2:win2
[ 11.723454] rk30 lcdc0 clk enable..Did this kernel ever make the LCD work?
4>[ 13.015294] UMP: Using OS memory backend, allocation limit: 536870912
[ 13.015330] UMP: UMP device driver -e1a6a37 loaded
[ 13.051533] Mali: Mali400 inside of rk3066
[ 13.051564] Mali: init mali clock success
[ 13.053010] Mali: Mali device driver loaded
[ 13.056104] rk30_mirroring: Unknown symbol video_data_to_mirroring (err 0)
[ 13.056167] rk30_mirroring: Unknown symbol audio_data_to_mirroring (err 0)You might have issues with the gpu. The modules doesn't fit to the kernel exports. Are you working with stick sources?
The screen works . Cant run wifi
Ok, let me have a screenshot of settings/about the tab.
<4>[ 81.575400] Current WiFi chip is RTL8188EU.
<3>[ 81.636515] wlan: module is already loaded
RTL8188 is a simple chip. Just to load the module, nothing else. Or is the driver in the kernel?
2015/03/18
Just a test build: http://crewrktablets.arctablet.com/?wpfb_dl=2675- Oma -
What did u change/fix in this build?
2013/06/29
Oma7144 сказал
Хорошо, дайте мне скриншот настроек / о вкладке.[81.575400] Текущее чип Wi-Fi является RTL8188EU.
[81,636515] WLAN: модуль уже загруженRTL8188 простой чип. Просто, чтобы загрузить модуль, ничего. Или водитель в ядре? - Ома -
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2676
2013/12/21
Aoson M33Q GB has a selinux kernel. This is a non selinux build and will consequently not boot on a selinux kernel.- Oma -
NO SEAR OMA I HAVE A NON SELINUX KERNEL ITS FOR 4.2.1 FIRMWARE YOU TAKE A LOOK
AND THE 5.0.2 FIRM BOOT NORMELLY BUT VERY LAGY IF IT IS SELINUX CANT BOOT EVER
Well, this is a kernel for the M33 GB, which is not the same as M33Q GB.
2015/03/18
Regarding new CM12.1 v1.1 build.
Usb drive is working, but need some patients reconecting usb drive, not sure maybe settings to mtp connection helped. Probably in previous build it working as well.
Interesting thing my stock sensor module and camera module not working right (same in previous build), sensor is turned (in my stock used ro.sf.hwrotation=270) but i know that in CM12/CM12.1 this command not working like before it turning screen view but not turning touch screen so better stay at value ro.sf.hwrotation=0. Camera with not changed module is turned and with my stock camera.rk30board.so just crashing on start. But i found right sensor module, just using second one from this CrewRKtablets rom. Others schould try one sensor fix from there.
Also like i said in previous post i found camera.rk30board.so, from other rom (for sure not from my stock rom) and this module fixing my turned camera screen but crashing when making photo. So maybe there is a chance to find right one camera module like with sensor modules.
REgarding 3G, now i can turn mobile network (cellular data) and set apns and i can search and see my sim operators and register. But cant see signal icon, there is only "no sim card" icon and checked internet connection not working.
Can provide logs if needed.
2015/09/27
I have this tablet: Qlive 97R,
I established CrewRKTablets_Odys_Iron_CM12.1_LP_5.1.1_v1.0,
I replaced in the folder "rockdev" - parameter(8GB) and kernel - RK31 Kernel 3036 97r Qilive(kernel archive).
Lollipop works, but there are problems:
1. Wi-Fi works, but an Wi-Fi Direct - no, (the indicator WiFi Direct is, but data transfers - No, on a network of a WiFi Direct it isn't visible);
2. USB Dongl HUAWEI E1550 sets connection (an icon in a tray - No, the indicator on the modem burns), but transmissions - no, there is no Internet.
3.overdue response of the touchpad.
Help me, the friend!
2013/12/21
Well, this is a kernel for the M33 GB, which is not the same as M33Q GB.- Oma -
ITS THE SAME PRODUCT WITH BLUETOOTH ALL OTHER ROM FOR THE M33Q RUN GREAT FOR MY TAB LIKE
2013/12/21
http://www.slatedroid.com/topic/69770-aoson-m33/page-8#entry1050673
THERE IS TWO MODEL M33Q AND M33QS
AND TWO SUB MODEL LX AND GB
Q= WIFI AND SOME TAB WITH BLUETOOTH
QS= 3G MODEL
THERE IS NOT JUST M33 OR ITS M33Q
Unfortunately that isn't that simple. So, you have the M33 GB. With the M33 GB (JB) kernel you can boot the CM12 build, while the CM12.1 build doesn't boot?
ro.sf.hwrotation is now active. So it should work with the stock HAL's.
CytrynPer aspera ad astra, we rock the Tablets !
65 Guest(s)
Devices in use: Desktop (58), Phone (7)
