[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
JimDoe
466
2017/02/02 - 13:08
Flashed RK31_kernel_3036_hr_iron_feng81_odys http://crewrktablets.arctablet.com/?wpfb_dl=1620 (no changes on Parameter, Kernel new, others ticked off, Button RUN), for result pls check screenshot.
No changes on any funtion. Everything works except sound on speaker and headset. Sound via BT works.
 screenshot2017-02-02_01.jpgImage Enlarger
Is there a dump function somewhere in the system that I may have forgot to activate?
JimDoe
467
2017/02/02 - 17:36
No. We do have 4 Iron here working flawlessly. The question is what is different with yours? Have you done a dump of the running stock firmware?
JimDoe
468
2017/02/03 - 12:16
No dump of stock firmware - newbies are too dump to believe in fails 😉
I'm not familiar with tools to do a dump. Tried to use aiolog for log files, but can't find device ID. List of devices is empty.
Semnone
Berlin
469
2017/02/03 - 18:19
Pls flash back system.img and install the first model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2984
To control phantom rotation install this: http://crewrktablets.arctablet.com/?wpfb_dl=1369
Workaround for cam i.e.: https://forum.xda-developers.com/showpost.php?p=46671244&postcount=804
The installation of the Ucam Ultra Camera is not possible "App wurde nicht installiert".
The normal cam works with the known issue, but the pictures are ok in the gallery. I only need to rotate them, thats all.
The phantom rotation is fixed now.
What can you say about this Oma?:
Semnone said
What can i do, when an app has some issues or doesn't start?
Is this because of some errors in the rom or the app is not really customized with this rom?
470
2017/02/05 - 17:05
There are a lot of 3rd party apps can do the job, i.e. Camera360.
Most likely driven by the app crashing on the Rockchip stuff.
vitalez06
471
2017/03/06 - 03:25
Hello. I've managed to run this build on my RK3188 tablet, but every time I put it to sleep mode then turn it back on, it wouldn't turn back on. Only way to turn it on again is by doing a hard-reset. Also, there is no sound. The sound chip is RK616. Is there any way to fix them? The tablet is called Lifeware FABTab Quadro 7 and this is its stock firmware: http://www.mediafire.com/file/b8km95dmjcfl6de/Fabtab_7_Quadro_%28FT4007%29.rar
Thanks in advance!
vitalez06
473
2017/03/06 - 18:32
Forgot to mention that I've been using the stock kernel from my tab. Anyway, I've found out the cause of device not waking up from sleep. Turns out, it's automatically outputting in HDMI, that's why the screen won't turn on.
Turning off the HDMI fixes it, though I only saw the HDMI option in other custom build of yours (OmniROM, to name), so I have no idea how will I disable it in this build.
Flashing the V88 build gave me working sound, but runs noticeably slower than the Odys build, so I'm trying to see if I could have sound on this build. Or I'm guessing it's slower because the sound works? I hope not.
vitalez06
475
2017/03/07 - 05:39
Still no sound, and still won't wake from sleep. I tried the other builds and tried disabling HDMI, but the OmniROM's HDMI setting is the only one that worked, since it asks for SuperSU permission after disabling it.
476
2017/03/07 - 19:02
Not really an idea of what your kernel is doing. The CM12.1 builds for Iron and V88 are almost the same except the wifi-chip implementation. If the Omni build works for you stay with it.
segro
477
2017/03/23 - 15:26
I'd like to put this firmware on my Aoson M33, but I'm not sure I understood instructions...
are there somewhere instructions in pictures, or video?
Main reason to change original ROM is very small (only 1GB) partition for installing programs, currently
flashed ROM is original 4.4.2
sindicat21
Forum Posts: 35
478
2017/03/25 - 10:24
Someone tried VPN on CM12?
Robur
479
2017/10/14 - 16:34
I have a Qilive 97R which works 100% running:
  • ROM: CrewRKTablets_Odys_Iron_Omni_.4.4_v1.4.1
  • 8 GB Parameter Fix
  • KERNEL: RK31_kernel_3036_97r_qilive
  • MODEL FIX: CrewRKTablets_KK_Omni_v1.4.1_model fix_Qilive 97R_2
I have tried installing CrewRKTablets_Odys_Iron_CM12.1_LP_5.1.1_v1.1 using the same Kernel. The system installs and boots, but the sensors and Wi-Fi do not work (no screen rotation and trying to start Wi-Fi reboots the tablet into a permanent loop).
Applying the above model fix does not help. The tablet hangs showing the start animation forever.
Also tried RK31_kernel_3036_97r-2_qilive.7z and the symptoms are the same.
I reckon a new model fix specifically built for Android 5.1.1 is needed?
Thanks.
Oxford
480
2019/04/01 - 04:07
62 Guest(s)
2 Guest(s)
Devices in use: Desktop (53), Phone (9)
rk.13
siwinfi64
dangphat
dpc
ngu
