[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
451
2017/01/26 - 20:26
heistruett said
faults:
no USB-Hub
no Audio (USB-Audio via USB-OTG only)
no Bluetooth
Model fault or kernel fault?
Well, this is a JB kernel. Can you pls check if this things will work with OmniBuild?
heistruett
Forum Posts: 12
452
2017/01/27 - 19:26
Well, I'll download a couple of ROMs a try them out tomorrow morning.
I'm shure to find a pleasant ROM.
Lollipop wasjust an experiment 'cause I read about successful mods with U30GT2.
I wanted to give a feedback only..
Semnone
Berlin
453
2017/01/28 - 18:28
I have successful flashed this rom on the Xelio 10 extreme but when i turn wifi on the tablet restarts and then it stucks in a bootloop.
Other problems:
The camera rotation(90 degrees to the right i think) is wrong and the auto rotation doesn't work.
I have used the
CrewRKTablets_Odys_Iron_CM12.1_LP_5.1.1_v1.1 Build,
the RK31_kernel_3036_xelio 10 extreme_odys Kernel
and the CrewRKTablets_RK31_CM12.1_LP_5.1.1_v1.0_160dpi fix
In the past there are some other people here in this thread with the same problem and Oma has a solution for it. I hope you can help me too.
heistruett
Forum Posts: 12
454
2017/01/29 - 10:09
The Rockchip tools seem to work very critical, I had loota probs to establish a working connection.
While bootloader modus and driver recon was already ok these tools didn't wanna find a device.And the "Dump" tools didn't work even with a loader found.
At least the problem was the USB cable, only one (original Motorola Defy cable) out of five did the job.
Nevertheless the flash process failes several times.
Obviously a first class shielded cable is needed, but I do not have such with micro USB, only OTG 🙁
Beside the fact that I don't like this ROM:
- audio works
- bluetooth seems to work, it was visible and startable but I didn't established a conn
- USB-OTG works but my Dell hub not.
- NO videos, VLC was always crashing and dumping on the screen!
"Vido_M10_AZ_RileyROM_1.1" from freaktab works.
The only thing I liked was fully automated Update process incl. factory reset, rebooting and so on.
For I dislike this ROM so much I didn't try the stock?? ROM "M10-4.4-20140630-AZ" I found at least on some webspace.
So I jumped back to the start, Odys Iron CM12.1 LP 5.1.1 is the only Cyonogenmod I found for RK3188...
I hope the is a way to get it run.
455
2017/01/29 - 16:49
KK build comes with a selinux kernel and a loader wich is not compatible for downgrade. So, be careful.
Try this on the CM12.1 build: http://crewrktablets.arctablet.com/?wpfb_dl=2983
456
2017/01/29 - 16:50
Other problems:
Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2984
Semnone
Semnone
Berlin
457
2017/01/29 - 17:07
Other problems:
Great work Oma. Wifi works, autorotation works, but the camera is still wrong.
Ich weiß nicht wie ich das erklären soll. Wenn ich das Tablett waagerecht vor mir halte, dann ist das Bild was ich sehe um 90° gedreht nach rechts und sieht aus als ob ich das Tablett hochkant halte. Das Video ist dann auch hochkant und eben um 90° nach rechts gedreht.
Vor dem Fix war es auch so, nur dass das Video im Player richtig dargestellt wird.
Ansonsten läuft jetzt alles Super und beim bisherigen Testen ist mir nix aufgefallen.
heistruett
Forum Posts: 12
459
2017/01/30 - 19:22
Sometimes I got a black screen only and sometimes and Andro lying on the back and a red exclamation mark on his belly ;)No problem so far, from time to time a little stress with the loaders...
On Lollipop "UMS Enabler" app complains about SELinux..
THX!
I'll try it later this evening
heistruett
Forum Posts: 12
460
2017/01/31 - 14:47
1st I installed the zip via CWM, looked fine so far.
But afterwards no more.. :(, even with cache/Dalvik cleared.
- USB OTG is working with storage devices directly attached
- no USB hub, no card reader, no USB audio card 🙁
- Bluetooth can be started and icon lights on 🙂
- no devices visible and tablet not visible for other devices
- playing audio tracks results in error messages
- playing videos gives error with stock video player
  VLC shows a white screen and after one or two minutes  a message "not responding"
dmesg of a clean boot after with wiped cache/Dalvik attached.
alogcat started after dmesg with several audio apps/VLC tries.
forgotten..
On sunday I tried several Kitcat version incl. the chinese stock version.
All are missing the key/button section within the settings.Lollipop is offering buttons, yeah! 🙂
In all tested version I couldn't activate german umlauts in "QWERTZ" layout, no ä,ö,ü,ß.
Semnone
Berlin
461
2017/01/31 - 20:26
After the last fix the camera doesn't work any more.  Meldung: "Kamera wurde beendet"
Another small issue is, when i want to slide an app to the main screen the whole screen rotates for 180°.
But only when auto rotation is active. When i disable auto rotation i am able to slide an app to the main screen.
What can i do, when an app has some issues or doesn't start?
Is this because of some errors in the rom or the app is not really customized with this rom?
But at all, the rom is really great. The Tablet is much faster then before and of course i will donate for you.
462
2017/01/31 - 20:36
Pls flash back system.img and install the first model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2984
To control phantom rotation install this: http://crewrktablets.arctablet.com/?wpfb_dl=1369
Workaround for cam i.e.: https://forum.xda-developers.com/showpost.php?p=46671244&postcount=804
463
2017/01/31 - 20:38
Looks as we do not have any chance with this kernel. Sorry.
JimDoe
464
2017/02/01 - 11:11
I'm newbie on this forum
Thanks all for discussion and esp. Oma7144 for this great work!
I installed (1st time ever) CM on Android device. In detail IRON by CrewRKTablets CM12.1 LP 5.1.1 build v1.1 on ODYS IRON bought end of 2014. Everything works fine so far (USB OTG, BT, Wifi, SDCard, Video, Cam) but no sound on speaker or earphone. Sound via BT on Laptop as speaker works fine. Youtube app closes occasionally.
Any ideas how to fix?
#JimDoe#
465
2017/02/01 - 15:53
Hm, my Iron is from early 2014. Can you pls check with stock kernel? http://crewrktablets.arctablet.com/?wpfb_dl=1620
Change kernel in folder rockdev/Image and flash it (just tick parameter and kernel).
69 Guest(s)
2 Guest(s)
Devices in use: Desktop (61), Phone (8)
rk.13
siwinfi64
dangphat
dpc
ngu
