[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
karmantyu
436
2016/12/02 - 19:43
Great ROM, but I have 75% battery drain on "Cell Standby". My Pipo M6pro doesn't have a SIM card slot so the problem is mainly on the kernel side. Since I can't compile JB kernel for my M6 pro  I'm requesting help to modify the ROM / erase the files responsible for drain on my tablet. Could somebody tell me which file to remove to stop the drain?
Cusco
Russia
Forum Posts: 22
437
2016/12/02 - 23:57
Remove (or rename) libril-rk29-dataonly.so from system\lib\
jorgito_ml
438
2016/12/21 - 00:20
jorgito_ml said
I'm trying to flash this rom on my BQ Curie 2 QC.
The flashing progress ends without any problem and the tablet restarts in recovery mode as espected.
The problem comes when I try to flash the zip fixes (model_fix, 160dpi and rotation_fix). I can't search the zip file, the recovery (clockworkmod) throws this error: "can't mout /sdcard/"
Any clue to solve this?
Tx!!!
PS: On RKAndroidTool I'm just changing the parameter file with the one for 16GB and the kernel file with the JB kernel for my tablet.
solved using an external sdcard.
klp
439
2016/12/28 - 10:15
my tablet "PIPO M6 Max" is it possible to flash this version IRON by CrewRKTablets CM12.1 LP 5.1.1 build v1.1
4.4 is now installed custom Rooted
p.s. sorry for my English, i`am russian
Semnone
Berlin
440
2017/01/06 - 11:31
Hallo zusammen,
kann ich dieses rom für ein Odys Xelio 10 Extreme benutzen oder ist das
Odys Iron OmniRom 4.4.4 rom das letzte, welches als "funktioniert" bekannt ist und ich nutzen sollte?
Can i use this rom for a Odys Xelio 10 Extreme or should i use the Odys Iron OmniRom 4.4.4 rom, because its the last stable one for this tablet?
Cheers Semnone
The following users say thank you to Semnone for this useful post:
presko
presko
441
2017/01/09 - 09:37
Semnone said
Hallo zusammen,
Cheers Semnone
I think that you have to try is your kernel compatible with those 2 roms and report back which was ok and which didn't.
I have bought a broken visture which i plan or to use stationary as hdmi stick or to upgrade it 5.1.1 and intergrate it in a in car entertainment diy system.
i have read that v88 is ok for v97hd I think that i have read that lollipop i also compatible but may experience touch lag so its up to you to test and make your notice which is best for your needs
sindicat21
Forum Posts: 35
442
2017/01/09 - 09:43
V97HD its clone of N90FHDRK but we have unfixable issue with wifi + random reboots + broken video recording.
Semnone
Berlin
443
2017/01/20 - 14:48
All i know is, that the OmniROM 4.4.4 v1.4.1 has a confirmed installation on the Odys Xelio 10 Extreme. --> See here
I can test this on my tablet next weekend, but i think it must work. I hope so. 😉
But i don't want to test the Odys Iron CM12.1 LP 5.1.1 on my tablet until i know it works or i know that there are problems. I dont want to brick it.
How can i check a kernel without a chance to brick my tablet? Is there save way?
An answer from Oma7144 would be great. 😉
heistruett
Forum Posts: 12
444
2017/01/25 - 14:08
I just installed Android 5.1 on an RK3188 tablet of unknown vendor, OMA helped me identifying as an Vido M10 AZ clone.
Used stuff:
- CrewRKTablets_Odys_Iron_CM12.1_LP_5.1.1_v1.1- RK31_kernel_3036_hr_m10_vido_2
- CrewRKTablets_RK31_LP_5.0_v1.0_parameter_dynamic
faults:
no USB-Hub
no Audio (USB-Audio via USB-OTG only)
no Bluetooth
Model fault or kernel fault?
MP4 videos with AC3/DTS audio strems cannot be played, no probs for corresponding MKVs.
Add more codecs (3gp, avi, wmv, flv) - install via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2775
No codecs, containers only 😉
445
2017/01/25 - 17:44
Let me have a dmesg and a logcat log from a fresh boot.
446
2017/01/25 - 17:45
When OmniRom is confirmed working then the LP build will also boot on the given kernel.
Semnone
heistruett
Forum Posts: 12
447
2017/01/25 - 19:41
dmesg already done, I'll make a new one and attach here.
logcat.. I do not know.
heistruett
Forum Posts: 12
448
2017/01/26 - 09:50
I found aLogCatRoot, I did some saves with it, maybe it helps you.
When I try to make a fast reboot the system tries to start but instead of morphing android's head into a ball it crashes to a bllach screen.
Pressing the power button results in a very very small pic in the middle of the screen.
Same behavior when trying to reboot to "bootloader".
"Charging" pic added.
I also made a fresh dmesg after such a crash.PICT0106.JPGImage Enlarger
Semnone
Berlin
449
2017/01/26 - 10:26
You mean the kernel from the LP Build or the kernel from the OmniRom? Because for the OmniRom i have to change the Kernel first. Can i use the kernel from the LP Build or must i change the Kernel in the
ockdev\Image folder with this one: RK31_kernel_3036_xelio 10 extreme_odys?
After flashing this Build i have to install the 160 dpi fix, right?
Can i use opengapps or are there any known problems with the different variants?
450
2017/01/26 - 20:19
Yes, this is the Xelio 10 Extreme stock kernel. We do only have that binary. The 160dpi fix is also needed. The build does include gapps.
65 Guest(s)
Devices in use: Desktop (60), Phone (5)
rk.13
siwinfi64
dangphat
dpc
ngu
