2014/04/30
Cusco said
here's the log (from terminal)Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2672
Wifi works! Great, thanks!
Also works: HDMI, USB OTG (with ES file explorer)
Problems:
- BT&3G still doesn't turn on
- accelerometer doesn't work
- Cameras are turned on 90°
- ui crashes sometimes
- no auto rotate screen
- I can't connect tablet via ADB, tried RK and google drivers - no luck
- cwm can't mount internal sdcard (ok with external)
Log from terminal:
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=2674
As for ADB you need to enable it in developer oprtions.
Build has an unified storage, so there is no internal scdard to mount.
2014/04/30
Broken archive
Download again: http://crewrktablets.arctablet.com/?wpfb_dl=2674
romavdvPer aspera ad astra, we rock the Tablets !
Which tab and kernel?
Ok, RK3066 😉
But I am not aware the tab has a 3.0.36+ kernel.
Anyway, pls try: http://crewrktablets.arctablet.com/?wpfb_dl=2676
2014/04/30
As for ADB you need to enable it in developer oprtions.Build has an unified storage, so there is no internal scdard to mount.
Debugging enabled. Seems as unknown device.
CWM can't see internal memory at all.
About last model fix:
- bluetooth crashes when turning on
- screen rotates but orientation is wrong (screenshot from landscape position)
2013/12/21
The question is, what tab is it? In the other thread you mentioned it is a M33Q GB?
YES IT IS
ITS SHOW THE KERNEL LOGO AND FREEZ
NO BOOT
Aoson M33Q GB has a selinux kernel. This is a non selinux build and will consequently not boot on a selinux kernel.
2013/06/29
Ok, RK3066 😉But I am not aware the tab has a 3.0.36+ kernel.
Thank you. I will probyvat.
2013/06/29
did not work
u0_a71@cm12.1 on rk31board:/ $ su
root@cm12.1 on rk31board:/ # dmesg
<6>[ 0.000000] Initializing cgroup subsys cpu
<5>[ 0.000000] Linux version 3.0.36+ (roman@roman-P53SJ) (gcc version 4.4.3 (GCC) ) #84 SMP PREEMPT Fri Sep 25 18:32:46 MSK 2015
<4>[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[ 0.000000] Machine: RK30board
<6>[ 0.000000] memory reserve: Memory(base:0x9b000000 size:80M) reserved for <ion>
<6>[ 0.000000] memory reserve: Memory(base:0x9a400000 size:12M) reserved for <fb0 buf>
<6>[ 0.000000] memory reserve: Memory(base:0x99e00000 size:6M) reserved for <camera_ipp_mem>
<6>[ 0.000000] memory reserve: Total reserved 98M
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writeback
<6>[ 0.000000] bootconsole [earlycon0] enabled
<4>[ 0.000000] CPU SRAM: copied sram code from c0c34000 to fef00010 - fef02898
<4>[ 0.000000] CPU SRAM: copied sram data from c0c36888 to fef02898 - fef033d0
<4>[ 0.000000] sram_log: &= 1: n S T t l D k G V V 4 m e#O ZO
<3>[ 0.000000] can't get a available nume and deno
<3>[ 0.000000] clk_frac_div can't get rate=49500000,uart0_frac_div
<4>[ 0.000000] rk30_dvfs_init
<6>[ 0.000000] L310 cache controller enabled
<6>[ 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
<4>[ 0.000000] DDR DEBUG: version 1.00 20131106
<4>[ 0.000000] DDR DEBUG: DDR3 Device
<4>[ 0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.000000] DDR DEBUG: init success!!! freq=396MHz
<4>[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=1 extra clock, DGPS=180
<4>[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x3, DGSL=1 extra clock, DGPS=270
<4>[ 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
<4>[ 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.000000] rk30_iomux_init
<7>[ 0.000000] On node 0 totalpages: 237056
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0c31980, node_mem_map c16e4000
<7>[ 0.000000] Normal zone: 976 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 123952 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 1072 pages used for memmap
<7>[ 0.000000] HighMem zone: 111056 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 7 pages/cpu @c1eed000 s6976 r8192 d13504 u32768
<7>[ 0.000000] pcpu-alloc: s6976 r8192 d13504 u32768 alloc=8*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 235008
<5>[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00140000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00006000@0x00004000(kernel),0x00006000@0x0000A000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00BBE000@0x00080000(userdata),0x00002000@0x00C3E000(kpanic),0x00200000@0x00C40000(system),-@0x00E40000(user) bootver=2013-06-20#1.34 firmware_ver=5.0.2
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] Memory: 926MB = 926MB total
<5>[ 0.000000] Memory: 918908k/918908k available, 129668k reserved, 448512K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] DMA : 0xff600000 - 0xffe00000 ( 8 MB)
<5>[ 0.000000] vmalloc : 0xdf000000 - 0xfe800000 ( 504 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xde800000 ( 488 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .init : 0xc0408000 - 0xc0434000 ( 176 kB)
<5>[ 0.000000] .text : 0xc0434000 - 0xc0ba0914 (7603 kB)
<5>[ 0.000000] .data : 0xc0ba2000 - 0xc0c337e8 ( 582 kB)
<5>[ 0.000000] .bss : 0xc0c38024 - 0xc16e3fb0 (10928 kB)
<6>[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] NR_IRQS:448
<4>[ 0.000000] rk30_gpio_init: 176 gpio irqs in 6 banks
<6>[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
<6>[ 0.000000] Console: colour dummy device 80x30
<6>[ 0.004842] Calibrating delay loop (skipped) preset value.. 1631.46 BogoMIPS (lpj=8157341)
<6>[ 0.013632] pid_max: default: 32768 minimum: 301
<6>[ 0.018779] Mount-cache hash table entries: 512
<6>[ 0.024193] Initializing cgroup subsys debug
<6>[ 0.028748] Initializing cgroup subsys cpuacct
<6>[ 0.033559] Initializing cgroup subsys freezer
<6>[ 0.038337] CPU: Testing write buffer coherency: ok
<4>[ 0.144137] CPU1: Booted secondary processor
<6>[ 0.144180] Brought up 2 CPUs
<6>[ 0.151948] SMP: Total of 2 processors activated (3262.93 BogoMIPS).
<6>[ 0.159013] devtmpfs: initialized
<6>[ 0.170000] NET: Registered protocol family 16
<6>[ 0.174837] last_log: 0xde100000 map to 0xdf004000 and copy to 0xc0c3c250 (version 2.1)
<4>[ 0.194984] DVFS MSG: AVS Value(index=0): 139 139 138 139 139 139 139 139 138 138
<6>[ 0.314486] rk29sdk_wifi_bt_gpio_control_init: init finished
<6>[ 0.322183] console [ttyFIQ0] enabled, bootconsole disabled
<6>[ 0.331215] Registered FIQ tty driver de098c00
<6>[ 0.331750] Loaded driver for PL330 DMAC-1 rk29-pl330
<6>[ 0.331786] DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
<6>[ 0.331951] Loaded driver for PL330 DMAC-2 rk29-pl330
<6>[ 0.331985] DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
<6>[ 0.363913] bio: create slab <bio-0> at 0
<5>[ 0.368309] SCSI subsystem initialized
<6>[ 0.368505] usbcore: registered new interface driver usbfs
<6>[ 0.368609] usbcore: registered new interface driver hub
<6>[ 0.382880] usbcore: registered new device driver usb
<4>[ 0.382951] ts_register_slave:ft5306,id=1
<6>[ 0.383297] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
<6>[ 0.383487] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
<6>[ 0.383677] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
<6>[ 0.383825] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
<6>[ 0.383964] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
<6>[ 0.418440] rk30-adc rk30-adc: rk30 adc: driver initialized
<4>[ 0.529794] regbase df100000 0x0, otg_phy_confed08184, 0x408
<4>[ 0.585506] charge_status = 2
<4>[ 0.859667] regbase df100000 0x0, otg_phy_confed08184, 0x408
<4>[ 0.865357] charge_status = 0
<4>[ 0.868440] lower power .....
<6>[ 0.871445] rk30_adc_battery: driver initialized
<6>[ 0.876279] Advanced Linux Sound Architecture Driver Version 1.0.24.
<6>[ 0.883072] Bluetooth: Core ver 2.16
<6>[ 0.886744] NET: Registered protocol family 31
<6>[ 0.891218] Bluetooth: HCI device and connection manager initialized
<6>[ 0.897607] Bluetooth: HCI socket layer initialized
<6>[ 0.902512] Bluetooth: L2CAP socket layer initialized
<6>[ 0.907616] Bluetooth: SCO socket layer initialized
<6>[ 0.912706] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.919889] rk fb probe ok!
<4>[ 0.949979] tps65910_pre_init,line=38
<6>[ 0.952580] TPS65910 Set default voltage.
<4>[ 0.954656] tps65910_pre_init,line=248
<4>[ 0.964925] tps65910_post_init,line=256
<4>[ 0.964955] tps65910_post_init:g_pmic_type=2
<4>[ 0.984424] tps65910_post_init set vio vcc_io=3300000mV end
<4>[ 0.985461] tps65910_post_init set vpll vdd11=2500000mV end
<4>[ 0.986484] tps65910_post_init set vdig2 vdd11=1100000mV end
<4>[ 0.987504] tps65910_post_init set vaux33 vcc_tp=3300000mV end
<4>[ 0.989880] tps65910_post_init set vdd1 vdd_cpu=1200000mV end
<4>[ 0.992254] tps65910_post_init set vdd2 vcc_ddr=1200000mV end
<4>[ 0.993275] tps65910_post_init set vdig1 vcc18_cif=1800000mV end
<4>[ 0.994300] tps65910_post_init set vaux1 vcc25_hdmi=2500000mV end
<4>[ 0.995323] tps65910_post_init set vaux2 vcca33=3300000mV end
<4>[ 0.996343] tps65910_post_init set vdac vccio_wl=1800000mV end
<4>[ 0.997363] tps65910_post_init set vmmc vcc28_cif=2800000mV end
<4>[ 0.997501] tps65910_post_init,line=342 END
<4>[ 0.997529] tps65910_i2c_probe:irq=356,irq_base=384,gpio_base=384
<4>[ 0.997603] ts_i2c_init
<4>[ 1.014368] ts_init_platform_hw set vaux33 vcc_tp=3300000mV end
<4>[ 1.333705] ts_init_platform_hw
<4>[ 1.333970] ft5306 touchscreen init
<4>[ 1.334232] [FST] Firmware version = 0x10
<4>[ 1.411503] [TSP] Step 1: Reset CTPM test
<3>[ 1.411711] i2c i2c-2: No ack, Maybe slave(addr: 0x38) not exist or abnormal power-on, retry 2...
<3>[ 1.411938] i2c i2c-2: No ack, Maybe slave(addr: 0x38) not exist or abnormal power-on, retry 1...
<3>[ 1.412164] i2c i2c-2: No ack, Maybe slave(addr: 0x38) not exist or abnormal power-on, retry 0...
<3>[ 1.412217] ft5x0x_i2c_txdata i2c write error: -11
<4>[ 1.519471] [TSP] Step 3: CTPM ID,ID1 = 0x79,ID2 = 0x3
<4>[ 2.968139] [TSP] Step 4: erase.
<4>[ 2.968165] [TSP] Step 5: start upgrade.
<4>[ 3.001939] [TSP] upgrade the 0x0 th byte.
<4>[ 3.271853] [TSP] upgrade the 0x400 th byte.
<4>[ 3.541769] [TSP] upgrade the 0x800 th byte.
<4>[ 3.811681] [TSP] upgrade the 0xc00 th byte.
<4>[ 4.081602] [TSP] upgrade the 0x1000 th byte.
<4>[ 4.351520] [TSP] upgrade the 0x1400 th byte.
<4>[ 4.621432] [TSP] upgrade the 0x1800 th byte.
<4>[ 4.891343] [TSP] upgrade the 0x1c00 th byte.
<4>[ 5.161254] [TSP] upgrade the 0x2000 th byte.
<4>[ 5.431164] [TSP] upgrade the 0x2400 th byte.
<4>[ 5.701075] [TSP] upgrade the 0x2800 th byte.
<4>[ 5.970991] [TSP] upgrade the 0x2c00 th byte.
<4>[ 6.240910] [TSP] upgrade the 0x3000 th byte.
<4>[ 6.510820] [TSP] upgrade the 0x3400 th byte.
<4>[ 6.780733] [TSP] upgrade the 0x3800 th byte.
<4>[ 7.050648] [TSP] upgrade the 0x3c00 th byte.
<4>[ 7.320556] [TSP] upgrade the 0x4000 th byte.
<4>[ 7.590469] [TSP] upgrade the 0x4400 th byte.
<4>[ 7.860377] [TSP] upgrade the 0x4800 th byte.
<4>[ 8.130290] [TSP] upgrade the 0x4c00 th byte.
<4>[ 8.400199] [TSP] upgrade the 0x5000 th byte.
<4>[ 8.670110] [TSP] upgrade the 0x5400 th byte.
<4>[ 8.940023] [TSP] upgrade the 0x5800 th byte.
<4>[ 9.209935] [TSP] upgrade the 0x5c00 th byte.
<4>[ 9.479849] [TSP] upgrade the 0x6000 th byte.
<4>[ 9.749759] [TSP] upgrade the 0x6400 th byte.
<4>[ 10.035244] [TSP] Step 6: ecc read 0x2, new firmware 0x2.
<4>[ 10.035507] start auto clb.
<4>[ 11.703714] end auto clb.
<4>[ 11.703738] ts_chip_init:ft5306 devid:0x0
<6>[ 11.703934] input: ft5306 as /devices/platform/rk30_i2c.2/i2c-2/2-0001/input/input0
<4>[ 11.703998] ts_irq_init:use irq=306
<4>[ 11.704029] ts_device_init:initialized ok,ts name:ft5306,devid=0
<4>[ 11.704039]
<6>[ 11.713728] tps65910-rtc tps65910-rtc: rtc core: registered tps65910 as rtc0
<4>[ 11.716458] tps65910_rtc_probe:ok
<6>[ 11.716533] Switching to clocksource timer1
<4>[ 11.723216] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xdf0ac000
<3>[ 11.723290] request lcd en pin fail!
<4>[ 11.723321] fb0:win1
<4>[ 11.723326] fb1:win0
<4>[ 11.723330] fb2:win2
<4>[ 11.723454] rk30 lcdc0 clk enable...
<6>[ 11.723735] Switched to NOHz mode on CPU #0
<6>[ 11.724179] Switched to NOHz mode on CPU #1
<4>[ 11.753585] rk30 lcdc0 clk disable...
<4>[ 11.775532] fb0:phy:9a400000>>vir:e0000000>>len:0xc00000
<4>[ 11.775782] rk_fb_register>>>>>fb0
<4>[ 11.791478] rk_fb_register>>>>>fb1
<4>[ 11.791664] rk_fb_register>>>>>fb2
<4>[ 11.791694] rk30 lcdc0 clk enable...
<4>[ 11.791735] lcdc0: dclk:62526315>>fps:57 rk30_load_screen for lcdc0 ok!
<6>[ 11.791778] lcdc0 wakeup from standby!
<6>[ 11.791803] lcdc0 win1 open,atv layer:2
<4>[ 11.792136] rk30 lcdc0 probe ok!
<4>[ 11.792251] pwm_regulator_probe:n_voltages=19
<6>[ 11.792442] pwm_regulator.0: driver initialized
<6>[ 11.808765] NET: Registered protocol family 2
<6>[ 11.808916] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
<6>[ 11.809239] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
<6>[ 11.810214] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
<6>[ 11.811301] TCP: Hash tables configured (established 65536 bind 65536)
<6>[ 11.811340] TCP reno registered
<6>[ 11.811366] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 11.811416] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 11.811726] NET: Registered protocol family 1
<4>[ 11.811915] RK29 Backlight Driver Initialized.
<6>[ 11.812110] Unpacking initramfs...
<6>[ 11.873395] Freeing initrd memory: 1280K
<6>[ 11.873583] rk30-tsadc rk30-tsadc: initialized
<6>[ 11.873691] PMU: registered new PMU device of type 0
<4>[ 11.874595] DVFS WARNING: vd_cpu : selector=86,but volt <=0
<4>[ 11.887454] highmem bounce pool size: 64 pages
<6>[ 11.887620] ashmem: initialized
<6>[ 11.892886] fuse init (API version 7.16)
<6>[ 11.894485] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
<6>[ 11.894534] io scheduler noop registered
<6>[ 11.894560] io scheduler deadline registered
<6>[ 11.894637] io scheduler cfq registered (default)
<6>[ 11.900406] rga: Driver loaded succesfully
<6>[ 11.900847] rk30-hdmi rk30-hdmi: rk30 hdmi probe sucess.
<4>[ 11.901098] rk_serial.c v1.6 2013-12-23
<6>[ 11.901205] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
<6>[ 11.901389] rk_serial rk_serial.0: membase 0xdf0c8000
<6>[ 11.901463] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
<6>[ 11.901631] rk_serial rk_serial.3: membase 0xdf0d0000
<6>[ 11.901893] Rockchip ion module(version: 1.0) is successfully loaded
<6>[ 11.904578] loop: module loaded
<6>[ 11.904629] Android kernel panic handler initialized (bind=kpanic)
<4>[ 11.905510] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 11.905576] random_ether_addr***********:5E:92:3C:30:F4:67
<6>[ 11.905913] rk29 vmac rk29 vmac.0: ARC VMAC at 0x10204000 irq 51 5e:92:3c:30:f4:67
<6>[ 11.906038] PPP generic driver version 2.4.2
<6>[ 11.906218] PPP Deflate Compression module registered
<6>[ 11.906253] PPP BSD Compression module registered
<6>[ 11.906988] PPP MPPE Compression module registered
<6>[ 11.907023] NET: Registered protocol family 24
<6>[ 11.907114] usbcore: registered new interface driver asix
<6>[ 11.907184] usbcore: registered new interface driver cdc_ether
<6>[ 11.907263] usbcore: registered new interface driver dm9620
<6>[ 11.907337] usbcore: registered new interface driver SR9700_android
<6>[ 11.907421] usbcore: registered new interface driver CoreChips
<6>[ 11.907490] usbcore: registered new interface driver net1080
<6>[ 11.907557] usbcore: registered new interface driver cdc_subset
<6>[ 11.907626] usbcore: registered new interface driver zaurus
<6>[ 11.907671] cdc_ncm: 04-Aug-2011
<6>[ 11.907726] usbcore: registered new interface driver cdc_ncm
<4>[ 11.907761] Rockchip WiFi SYS interface (V1.00) ...
<6>[ 11.907828] Initializing USB Mass Storage driver...
<6>[ 11.907902] usbcore: registered new interface driver usb-storage
<6>[ 11.907940] USB Mass Storage support registered.
<6>[ 11.908061] usbcore: registered new interface driver usbserial
<6>[ 11.908127] USB Serial support registered for generic
<6>[ 11.908198] usbcore: registered new interface driver usbserial_generic
<6>[ 11.908237] usbserial: USB Serial Driver core
<6>[ 11.908302] USB Serial support registered for GSM modem (1-port)
<6>[ 11.908381] usbcore: registered new interface driver option
<6>[ 11.908414] option: v0.7.2:USB Driver for GSM modems
<6>[ 12.120718] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
<6>[ 12.120751] usb20_otg usb20_otg: DWC OTG Controller
<6>[ 12.120834] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
<6>[ 12.120891] usb20_otg usb20_otg: irq 48, io mem 0x00000000
<6>[ 12.120918] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
<6>[ 12.120983] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 12.121018] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 12.121052] usb usb1: Product: DWC OTG Controller
<6>[ 12.121075] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
<6>[ 12.121103] usb usb1: SerialNumber: usb20_otg
<6>[ 12.121379] hub 1-0:1.0: USB hub found
<6>[ 12.121405] hub 1-0:1.0: 1 port detected
<6>[ 12.123966] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xdf200000
<6>[ 12.334324] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 12.334374] usb20_host usb20_host: DWC OTG Controller
<6>[ 12.334420] usb20_host usb20_host: new USB bus registered, assigned bus number 2
<6>[ 12.334470] usb20_host usb20_host: irq 49, io mem 0x00000000
<6>[ 12.334528] DWC_OTG: Init: Port Power? op_state=1
<6>[ 12.334550] DWC_OTG: Init: Power Port (0)
<6>[ 12.334601] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 12.334635] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 12.334670] usb usb2: Product: DWC OTG Controller
<6>[ 12.334694] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
<6>[ 12.334721] usb usb2: SerialNumber: usb20_host
<6>[ 12.334978] hub 2-0:1.0: USB hub found
<6>[ 12.335004] hub 2-0:1.0: 1 port detected
<6>[ 12.336057] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 12.336092] android_usb gadget: Number of LUNs=2
<6>[ 12.336116] lun0: LUN: removable file: (no medium)
<6>[ 12.336141] lun1: LUN: removable file: (no medium)
<6>[ 12.336314] android_usb gadget: android_usb ready
<6>[ 12.336570] input: rk29-keypad as /devices/platform/rk29-keypad/input/input1
<6>[ 12.336799] usbcore: registered new interface driver xpad
<4>[ 12.336951] sensor_register_slave:mma7660,id=18
<4>[ 12.336975] sensor_register_slave:akm8975,id=24
<6>[ 12.337139] using rtc device, tps65910, for alarms
<6>[ 12.337321] lirc_dev: IR Remote Control driver registered, major 250
<6>[ 12.337354] IR NEC protocol handler initialized
<6>[ 12.337376] IR RC5(x) protocol handler initialized
<6>[ 12.337399] IR RC6 protocol handler initialized
<6>[ 12.337422] IR JVC protocol handler initialized
<6>[ 12.337444] IR Sony protocol handler initialized
<6>[ 12.337466] IR RC5 (streamzap) protocol handler initialized
<6>[ 12.337492] IR LIRC bridge handler initialized
<6>[ 12.337514] Linux video capture interface: v2.00
<4>[ 12.337652] def_ref_volt: 2500mV, curr_ref_volt: 2500mV
<6>[ 12.337928] device-mapper: uevent: version 1.0.3
<6>[ 12.338115] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
<6>[ 12.338293] Bluetooth: HCI UART driver ver 2.2
<6>[ 12.338317] Bluetooth: HCI H4 protocol initialized
<6>[ 12.338340] Bluetooth: HCILL protocol initialized
<6>[ 12.338392] cpuidle: using governor ladder
<6>[ 12.338413] cpuidle: using governor menu
<6>[ 12.383745]
<6>[ 12.383748] drivers/mmc/core/core.c...2019.. ===== mmc_rescan Begin....[mmc0]
<6>[ 12.388864] rk29_sdmmc_change_clk_div..1684.. newDiv=63, newCLK=297Khz [sd_mmc]
<6>[ 12.388920] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. [sd_mmc]
<6>[ 12.389082] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. [sdio]
<4>[ 12.389179] leds-gpio: probe of leds-gpio failed with error -16
<6>[ 12.390224] usbcore: registered new interface driver usbhid
<6>[ 12.390252] usbhid: USB HID core driver
<6>[ 12.390489] logger: created 256K log 'log_main'
<6>[ 12.390570] logger: created 256K log 'log_events'
<6>[ 12.390645] logger: created 256K log 'log_radio'
<6>[ 12.390715] logger: created 256K log 'log_system'
<4>[ 12.391056] RT5631 Audio Codec 0.01 alsa 1.0.25
<6>[ 12.436470]
<6>[ 12.436473] mmc_attach_sd..1230.. ===== Begin to identify card as SD-card. [mmc0]
<3>[ 12.510847] RT5631 0-001a: dapm: unknown pin HP_L
<3>[ 12.510873] RT5631 0-001a: dapm: unknown pin HP_R
<6>[ 12.526803] asoc: RT5631 HiFi <-> rk29_i2s.0 mapping ok
<6>[ 12.527130] ALSA device list:
<6>[ 12.527149] #0: RK29_RT5631
<6>[ 12.527236] GACT probability NOT on
<6>[ 12.527258] Mirror/redirect action on
<6>[ 12.527278] u32 classifier
<6>[ 12.527292] Actions configured
<6>[ 12.527312] Netfilter messages via NETLINK v0.30.
<6>[ 12.527365] nf_conntrack version 0.5.0 (14377 buckets, 57508 max)
<6>[ 12.527632] ctnetlink v0.93: registering with nfnetlink.
<6>[ 12.527680] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 12.527713] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 12.527962] xt_time: kernel timezone is -0000
<6>[ 12.528086] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 12.528211] arp_tables: (C) 2002 David S. Miller
<6>[ 12.528264] TCP cubic registered
<6>[ 12.528281] Initializing XFRM netlink socket
<6>[ 12.528651] NET: Registered protocol family 10
<6>[ 12.529180] Mobile IPv6
<6>[ 12.529212] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 12.529318] IPv6 over IPv4 tunneling driver
<6>[ 12.529861] NET: Registered protocol family 17
<6>[ 12.529902] NET: Registered protocol family 15
<6>[ 12.530056] Bluetooth: RFCOMM TTY layer initialized
<6>[ 12.530087] Bluetooth: RFCOMM socket layer initialized
<6>[ 12.530113] Bluetooth: RFCOMM ver 1.11
<6>[ 12.530132] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 12.530159] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 12.530268] NET: Registered protocol family 35
<6>[ 12.530342] [BT_RFKILL]: Enter rfkill_rk_init
<6>[ 12.530441] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 12.530477] [BT_RFKILL]: ** disable irq
<6>[ 12.556607] [BT_RFKILL]: bt shut off power
<6>[ 12.586593] [BT_RFKILL]: bt_default device registered.
<4>[ 12.586659] pmic set pm_suspend_volt:
<6>[ 12.586784] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
<5>[ 12.586835] Registering SWP/SWPB emulation handler
<3>[ 12.587126] rk_cam_cif(3329):rk30-camera version: v0.3.21 Zoom by ippget cif ldo failed!
<4>[ 12.588603] ret: 0
<6>[ 12.588676] ddrfreq: verion 3.2 20131126
<6>[ 12.588697] ddrfreq: fix cpu pause bug
<6>[ 12.588718] ddrfreq: normal 396MHz video 300MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 396MHz
<6>[ 12.589052] i2c i2c-0: sensor_probe: gs_mma7660,0xde1b0c00
<4>[ 12.589084] sensor_chip_init:gs_mma7660:devid=0x0,ops=0xc0c0ace8
<6>[ 12.590117] input: gsensor as /devices/platform/rk30_i2c.0/i2c-0/0-004c/input/input2
<4>[ 12.590297] sensor_irq_init:use irq=304
<4>[ 12.590387] sensor_misc_device_register:miscdevice: mma8452_daemon
<4>[ 12.590418] sensor_probe:initialized ok,sensor name:mma7660,type:2,id=18
<4>[ 12.590425]
<6>[ 12.590470] i2c i2c-0: sensor_probe: ak8975,0xde1b0e00
<3>[ 12.590723] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 2...
<3>[ 12.590985] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 1...
<3>[ 12.591244] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 0...
<3>[ 12.591503] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 2...
<3>[ 12.591761] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 1...
<3>[ 12.592018] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 0...
<3>[ 12.592276] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 2...
<3>[ 12.592533] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 1...
<3>[ 12.592791] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 0...
<4>[ 12.592833] sensor_chip_init:fail to read ak8975 devid:0xff
<3>[ 12.592861] i2c i2c-0: sensor_probe failed -11
<3>[ 12.592866]
<4>[ 12.592897] sensors: probe of 0-000d failed with error -11
<6>[ 12.592947] sensor_init: Probe name sensors
<4>[ 12.592979] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<6>[ 12.596094] tps65910-rtc tps65910-rtc: setting system clock to 2015-09-27 14:49:06 UTC (1443365346)
<6>[ 12.596432] asoc: rk-hdmi-i2s-hifi <-> rk29_i2s.0 mapping ok
<6>[ 12.596944] usbcore: registered new interface driver snd-usb-audio
<6>[ 12.597075] Freeing init memory: 176K
<4>[ 12.616649] get cif ldo failed!
<4>[ 12.616667] ret: 0
<3>[ 12.623884] init: /init.rk30board.rc: 61: invalid command ''
<3>[ 12.625117] init: /init.cm.rc: 200: ignored duplicate definition of service 'bugreport'
<4>[ 12.689474] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
<3>[ 12.698005] init: /dev/hw_random not found
<6>[ 12.698093] keychord: using input dev rk29-keypad for fevent
<4>[ 12.707833] get cif ldo failed!
<4>[ 12.707852] ret: 0
<6>[ 12.716689] usb 2-1: new high speed USB device number 2 using usb20_host
<4>[ 12.738025] Probe hm2057_back_3 success
<4>[ 12.738323] get cif ldo failed!
<4>[ 12.738371] ret: 0
<4>[ 12.766689] get cif ldo failed!
<4>[ 12.766707] ret: 0
<3>[ 12.778771] init: /dev/hw_random not found
<4>[ 12.791423] gp_rknand_info = : 0xde24ba00
<4>[ 12.791570] request IRQ_NANDC irq , ret=0.........
<4>[ 12.791650] FlashCopyProgBuf1=0xc1582000
<4>[ 12.791688] ATime: 40 ns AHB: 150 timming: 1082
<4>[ 12.791714] No.1 FLASH INFO:ad de 94 da 74
<4>[ 12.792066] ATime: 32 ns AHB: 150 timming: 1061
<4>[ 12.792238] ATime: 32 ns AHB: 150 timming: 1061
<4>[ 12.792262] randomizer = 2 , EccBits = 28 pSpec->pReadRetrial = bf00c28c
<6>[ 12.797754] rk29_sdmmc_change_clk_div..1684.. newDiv=0, newCLK=37500Khz [sd_mmc]
<6>[ 12.797850] mmc0: new high speed SDHC card at address 59b4
<4>[ 12.816779] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
<6>[ 12.817124] mmcblk0: mmc0:59b4 NCard 29.4 GiB
<6>[ 12.818937]
<6>[ 12.818940] msdos_partition..466... ==== Begin to parse sdcard-partition. [mmcblk0]
<6>[ 12.818984] msdos_partition..535... ==== The sdcard has MBR. [mmcblk0]
<6>[ 12.819017] msdos_partition..548... ==== partition-1, size=30206MB. [mmcblk0]
<6>[ 12.819060] msdos_partition..576... ==== main partition-1....[mmcblk0]
<6>[ 12.819093] mmcblk0: p1
<6>[ 12.820258] sdmmc_rescan_try_freq..1913.. ===== Initialize SD-card successfully. [mmc0]
<6>[ 12.820306]
<6>[ 12.820309] drivers/mmc/core/core.c...2019.. ===== mmc_rescan Begin....[mmc1]
<6>[ 12.836652] rk29_sdmmc_change_clk_div..1684.. newDiv=42, newCLK=297Khz [sdio]
<4>[ 12.837263] get cif ldo failed!
<4>[ 12.837281] ret: 0
<4>[ 12.870119] Probe gc0308_front_4 success
<4>[ 12.879360] FTL INFO:Version = 438,Date = 20121130
<4>[ 12.879386] totalLogicBlkRaw = 1896
<4>[ 12.879414] gBootMedia = 1 gSdmmcFwPartOffset =0!
<4>[ 12.879438] rknand_buffer.c version: 4.38 20121130!
<5>[ 12.894801] 10 cmdlinepart partitions found on MTD device rk29xxnand
<5>[ 12.894833] Creating 10 MTD partitions on "rk29xxnand":
<5>[ 12.894862] 0x000000400000-0x000000800000 : "misc"
<5>[ 12.895737] 0x000000800000-0x000001400000 : "kernel"
<5>[ 12.896892] 0x000001400000-0x000002000000 : "boot"
<5>[ 12.897986] 0x000002000000-0x000004000000 : "recovery"
<5>[ 12.899082] 0x000004000000-0x000008000000 : "backup"
<5>[ 12.900208] 0x000008000000-0x000010000000 : "cache"
<5>[ 12.901355] 0x000010000000-0x000187c00000 : "userdata"
<5>[ 12.907156] 0x000187c00000-0x000188000000 : "kpanic"
<6>[ 12.908840] apanic: Bound to mtd partition 'kpanic'
<6>[ 12.908866] apanic: No panic data available
<5>[ 12.908891] 0x000188000000-0x0001c8000000 : "system"
<5>[ 12.910692] 0x0001c8000000-0x0001da000000 : "user"
<4>[ 12.912005] startBlk = 42 sysProtAddr = 41
<3>[ 12.915109] fs_mgr: Warning: unknown flag encryptable
<6>[ 12.929829] usb 2-1: New USB device found, idVendor=0bda, idProduct=8179
<6>[ 12.929865] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ 12.929903] usb 2-1: Product: 802.11n NIC
<6>[ 12.929924] usb 2-1: Manufacturer: Realtek
<6>[ 12.929949] usb 2-1: SerialNumber: 00E04C0001
<6>[ 12.931312] EXT4-fs (mtdblock8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<6>[ 12.931453] fs_mgr: __mount(source=/dev/block/mtd/by-name/system,target=/system,type=ext4)=0
<6>[ 12.946072] EXT4-fs (mtdblock5): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<6>[ 12.946148] fs_mgr: __mount(source=/dev/block/mtd/by-name/cache,target=/cache,type=ext4)=0
<6>[ 12.960906] EXT4-fs (mtdblock6): recovery complete
<6>[ 12.960939] EXT4-fs (mtdblock6): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<6>[ 12.961010] fs_mgr: __mount(source=/dev/block/mtd/by-name/userdata,target=/data,type=ext4)=0
<4>[ 13.015294] UMP: Using OS memory backend, allocation limit: 536870912
<4>[ 13.015330] UMP: UMP device driver -e1a6a37 loaded
<4>[ 13.051533] Mali: Mali400 inside of rk3066
<4>[ 13.051564] Mali: init mali clock success
<4>[ 13.053010] Mali: Mali device driver loaded
<4>[ 13.056104] rk30_mirroring: Unknown symbol video_data_to_mirroring (err 0)
<4>[ 13.056167] rk30_mirroring: Unknown symbol audio_data_to_mirroring (err 0)
<4>[ 13.069706] rk29_ipp: module is from the staging directory, the quality is unknown, you have been warned.
<4>[ 13.070661] ipp irq 47
<4>[ 13.071209] IPP init, version rk30-ipp 1.003
<6>[ 13.355168] binder: 88:88 transaction failed 29189, size 0-0
<4>[ 13.439019] vpu: power on
<6>[ 13.441716] VPU_SERVICE: checking hw id 4831
<4>[ 13.446664] vpu: power off...done
<6>[ 13.450486] VPU_SERVICE: init success
<6>[ 13.551315] rtk_btusb: Realtek Bluetooth USB driver ver 0.9
<6>[ 13.557172] usbcore: registered new interface driver rtk_btusb
<3>[ 13.563681] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
<3>[ 13.572036] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
<3>[ 13.582135] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
<3>[ 13.592228] init: property 'ro.product.usbfactory' doesn't exist while expanding '$ro.product.usbfactory'
<3>[ 13.601867] init: cannot expand '$ro.product.usbfactory' while writing to '/sys/class/android_usb/android0/f_mass_storage/inquiry_string'
<3>[ 13.635379] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
<3>[ 13.645460] init: cannot find '/system/bin/akmd', disabling 'akmd'
<3>[ 13.645537] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper'
<3>[ 13.750798] android_usb: already disabled
<6>[ 13.757121] adb_open
<6>[ 14.002398] EXT4-fs (mtdblock8): re-mounted. Opts: user_xattr,barrier=1,data=ordered,noauto_da_alloc,discard
<38>[ 14.124268] logd.auditd: start
<3>[ 14.176166] fs_mgr: Warning: unknown flag encryptable
<4>[ 14.362520] healthd: BatteryTemperaturePath not found
<4>[ 14.643280] Loading Chuwi V88 HUB access mod
<4>[ 14.643309] Greetings from crewrktablets 😉
<4>[ 14.643343] HUBaccess mod addres check failed [b2 00 09 eb]
<6>[ 14.812009] lcdc0 win1 open,atv layer:2
<4>[ 14.812053] rk fb use 3 buffers
<6>[ 15.120272] tun: Universal TUN/TAP device driver, 1.6
<6>[ 15.125370] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<6>[ 15.207603] TCP veno registered
<6>[ 15.210225] warning: `daemonsu' uses 32-bit capabilities (legacy support in use)
<6>[ 15.468041] usbcore: registered new interface driver dm9601
<6>[ 15.486977] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
<6>[ 15.558055] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 15.641961] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
<6>[ 15.642088] usbcore: registered new interface driver rtl8150
<6>[ 15.655584] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
<6>[ 15.726486] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
<3>[ 15.767586] cifs: module is already loaded
<3>[ 15.844000] init: untracked pid 254 exited with status 0
<3>[ 15.987929] snd_hwdep: exports duplicate symbol snd_hwdep_new (owned by kernel)
<3>[ 16.077534] snd_rawmidi: exports duplicate symbol snd_rawmidi_drain_input (owned by kernel)
<3>[ 16.203023] snd_usbmidi_lib: exports duplicate symbol snd_usbmidi_create (owned by kernel)
<3>[ 16.439022] snd_usb_audio: module is already loaded
<6>[ 16.581646] USB Serial support registered for cp210x
<6>[ 16.586728] usbcore: registered new interface driver cp210x
<6>[ 16.592345] cp210x: v0.09:Silicon Labs CP210x RS232 serial adaptor driver
<6>[ 16.628788] USB Serial support registered for pl2303
<6>[ 16.628881] usbcore: registered new interface driver pl2303
<6>[ 16.628908] pl2303: Prolific PL2303 USB to serial adaptor driver
<6>[ 16.675405] USB Serial support registered for FTDI USB Serial Device
<6>[ 16.675753] usbcore: registered new interface driver ftdi_sio
<6>[ 16.675783] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
<6>[ 16.711646] usbcore: registered new interface driver cdc_acm
<6>[ 16.711682] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<3>[ 16.766497] init: untracked pid 301 exited with status 0
<3>[ 16.781435] init: untracked pid 303 exited with status 1
<6>[ 16.796701] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
<6>[ 16.866750] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
<6>[ 16.917069] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
<6>[ 17.043502] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
<3>[ 17.116863] init: untracked pid 305 exited with status 1
<3>[ 20.277332] init: untracked pid 184 exited with status 0
<6>[ 20.581034] DWC_OTG: ********session end intr,soft disconnect************************
<6>[ 24.826429] request_suspend_state: wakeup (3->0) at 24829835711 (2015-09-27 14:49:18.728123126 UTC)
<6>[ 28.156615] DWC_OTG: ********vbus detect*********************************************
<6>[ 29.017118] DWC_OTG: ********soft connect!!!*****************************************
<6>[ 30.156607] DWC_OTG: ********soft reconnect******************************************
<6>[ 30.609590] DWC_OTG: ********soft connect!!!*****************************************
<6>[ 32.156608] DWC_OTG: ********soft reconnect******************************************
<6>[ 32.505858] DWC_OTG: ********soft connect!!!*****************************************
<4>[ 34.365261] get cif ldo failed!
<4>[ 34.365292] ret: 0
<4>[ 34.387210] get cif ldo failed!
<4>[ 34.387239] ret: 0
<4>[ 34.680841] get cif ldo failed!
<4>[ 34.680917] ret: 0
<4>[ 34.757318] get cif ldo failed!
<4>[ 34.757351] ret: 0
<4>[ 34.787172] get cif ldo failed!
<4>[ 34.787323] ret: 0
<3>[ 34.826670] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.934670] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.934750] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.934805] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.934874] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.934939] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.935001] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.935092] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.935151] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.935206] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.935260] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<3>[ 34.935316] gc0308_front_4(rk_cam_sensor:533): have not other series meet the requirement except init_serie,array_index = 0
<4>[ 35.059115] get cif ldo failed!
<4>[ 35.059204] ret: 0
<6>[ 47.734174] acc_open
<6>[ 47.736417] acc_release
<4>[ 48.198291] enter func vmac_open...
<4>[ 48.202053] power on phy
<4>[ 48.336648] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 48.341334] eth_mac_from_RANDOM***********:5E:92:3C:30:F4:0
<6>[ 48.375275] vmac_mii_bus: probed
<6>[ 48.375474] rk29 vmac rk29 vmac.0: PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1)
<6>[ 48.375725] ADDRCONF(NETDEV_UP): eth0: link is not ready
<4>[ 48.668235] Current WiFi chip is RTL8188EU.
<3>[ 49.390010] wlan: module is already loaded
<6>[ 50.366924] PHY: 0:00 - Link is Down
<4>[ 81.575400] Current WiFi chip is RTL8188EU.
<3>[ 81.636515] wlan: module is already loaded
<7>[ 81.940443] i2s dma info:periodsize(4096),limit(4),buffersize(16384),over(0)
<4>[ 90.590063] standby rt5631
<7>[ 94.015536] i2s dma info:periodsize(4096),limit(4),buffersize(16384),over(0)
<3>[ 101.828530] init: untracked pid 2355 exited with status 128
<3>[ 102.093057] init: untracked pid 2358 exited with status 0
Ok, homebrew kernel 😉
Did this kernel ever make the LCD work?
You might have issues with the gpu. The modules doesn't fit to the kernel exports. Are you working with stick sources?
72 Guest(s)
Devices in use: Desktop (67), Phone (5)
