[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
421
2016/09/04 - 16:23
We still have server issues. Try again tomorrow.
NeoTrantor
422
2016/09/13 - 13:40
Hi Oma,
would it be possible to port CM13 to RK3188 based devices? If so, I would like to give it a try. I've got the sources and programming knowledge but maybe you could provide me some device-specific build files to speed things up?
My tablet is the Cube 30gt2 by the way.
423
2016/09/13 - 17:13
No, not possible. Time for rk30boards is over.
NeoTrantor
424
2016/09/13 - 18:16
Why that?
Mark06
Forum Posts: 222
Thanks Received: 41
425
2016/09/18 - 07:56
On a cube u30gt2, is this os running fast? I mean just as fast as the overclocked kitkat versions?
Thx
Cube u30gt2 tab
kjs
426
2016/11/02 - 23:55
 First of all, thank you ver much for your work!!!
I have a PIPO M9 Pro 32Gb wifi and 3G, and I install it with this steps:
PACKAGE KK BOOT
1- ERASE ID Blocks
2- ERASE ALL Blocks
3- RUN (Loader RK3188Loader(L)_V1.24)
ROM ODYS IRON 1.1
4- Change Kernel.img for (RK31_kernel_3036_hr_m9pro_pipo)
5- Uncheck Loader
6- ERASE IDB
7- RUN
      Release Factory Reset
      Reboot with no fix SU
We have the following pain points:
   1- When I turn on the Wifi the tablet enter in a bootloop (Probably the fix will solve this issue, I'm sure)
   2- The CWM touch responsive is very bad (I don't know if this have a solution)
   3- In general the tablet have a slow response in touch and starting apps (I try to OC kernels but the tablet did't start)
In general, Could you please give me any solution to improve the smooth and a better response?
427
2016/11/03 - 20:04
You willl find model fixes and some hints to improve UI performance here: http://crewrktablets.arctablet.com/?p=5617
Jammed_Death
Forum Posts: 51
428
2016/11/03 - 21:32
oma how can i flash kernel only? Can't install drivers in windows 10 anniversary, even in test mode, can i flash trough recovery?
429
2016/11/03 - 22:02
FlashFire (see Playstore) can do the job.
For Win10 driver pls check this: http://www.arctablet.com/blog/forum/firmware-flashing-on-rockchip-based-devices/rockchip-driver-on-windows-10/?lang=fr
Jammed_Death
Forum Posts: 51
430
2016/11/03 - 22:04
already tried that link and the other ways, but no luck with last version of 10...well maybe flashfire will solve the problem, i'm trying to install the archos 97b platinum kernel from your site with this cm to see if it improve performances
kjs
431
2016/11/06 - 10:13
Thank you very much Oma, but after applying some fixes my PIPO M9 Pro 32Gb wifi/3G enter in a bootloop.
    1. CODECS -> OK
    2. FIX (normal) -> OK, and the wifi prolem solved
    3. KERNEL OC -> Bootloop
    4. FIX3 -> Bootloop
I don't found any other fix or hint for normal running or to improve CWM performance.
Could you please give me some recomendations?
432
2016/11/06 - 17:16
That's all we can do with a given kernel. What do you do with the kernel? Bitwise overwritring the frequence table?
sindicat21
Forum Posts: 35
433
2016/11/11 - 17:21
Someone have resourses for 3.0.101+ LP kernel for RK3188? It needs for stock lollipop.
cubelibre
434
2016/11/12 - 10:35
Look here https://github.com/cubelibre/LP
RK3188 5.1.1 FW https://yadi.sk/d/lW6L-K2FxB3jP
Good luck Wink
jorgito_ml
435
2016/11/30 - 17:04
I'm trying to flash this rom on my BQ Curie 2 QC.
The flashing progress ends without any problem and the tablet restarts in recovery mode as espected.
The problem comes when I try to flash the zip fixes (model_fix, 160dpi and rotation_fix). I can't search the zip file, the recovery (clockworkmod) throws this error: "can't mout /sdcard/"
Any clue to solve this?
Tx!!!
PS: On RKAndroidTool I'm just changing the parameter file with the one for 16GB and the kernel file with the JB kernel for my tablet.
74 Guest(s)
Devices in use: Desktop (66), Phone (8)
rk.13
siwinfi64
dangphat
dpc
ngu
