[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
MNT45
France
Forum Posts: 30
286
2015/12/31 - 23:08
 "My only dream is freedom, then I dream of freedom."
Thanks Received: 1378
287
2016/01/01 - 12:21
Tab has MT5931 wifi, so use the V88 build and the Vido 90FHDRK model fix: http://crewrktablets.arctablet.com/?p=5668
Kermit21
288
2016/01/01 - 13:34
My Iron is 2 years old now. Did you a dump of the stock firmware?
No, I don't know how (without cwm). But now it's to late anyway. But the "normal" stock rom and your modded stock work fine! So I don't think there is any difference. And my "wake up from standby" issue is gone with the new iron!
I tried out  CM12.1 LP 5.1.1 build v1.0. But also no sound and my usb-drive isn't recognized with this rom (no hostmode or automount), so I couldn't test video playing. But the v1.0 has two advantages: It doesn't show "no sim" messages (like v1.1 do) and there are no soft-button for volume up/down beside the normal one.
nelySLB
Forum Posts: 34
289
2016/01/01 - 19:50
I Oma i have cube u30gt2 i have installed 1.1 and no auto rotation no wifi and no Bluetooth with wifi boot loop when you enable it.
i can't flash the fix because i can boot to cwm but can't flash anything from anywhere not even from side load.
i flashed another cwm and was able to flash the fix by side load wifi is working now but no auto rotation
please help if you could.
MNT45
France
Forum Posts: 30
290
2016/01/01 - 23:52
 ok but my rom is the gen2 or no? because I have installed kitkatcustom...
MNT45
France
Forum Posts: 30
291
2016/01/02 - 07:10
I installed the rom everything works perfectly. THANKS FOR YOUR JOB
the only problem is that it appears to me 1GB of RAM memory except that my tabllete has 2GB.
How to do?
And how to do for install viper4android because it's very effically
292
2016/01/02 - 08:44
Fine.
RAM is beeing initialized by the kernel. Can you pls show me a screenshot?
In post #1 there is a link to my favourite apps. The package also includes Viper4Android. See the included screenshot for instructions.
293
2016/01/02 - 08:45
Pls use a FAT32 formatted sdcard.
MNT45
France
Forum Posts: 30
294
2016/01/02 - 09:25
Fine.
Screenshot_2016-01-02-09-19-23.pngImage Enlarger
But un Antutu I have 2GB
Screenshot_2016-01-02-09-20-08.pngImage Enlarger
PS : I have a gold score ?
Screenshot_2016-01-02-09-20-24.pngImage Enlarger
MNT45
France
Forum Posts: 30
295
2016/01/02 - 09:27
Sorry its OK :-p
dops75
296
2016/01/04 - 11:52
dops75 said
I Installed CM12.1 LP 5.11 on my Qilive 97r, my Device has a new life 😀
But there's a big problem for me. Th BT in sot working properly 🙁
I fixed with PipoM9pro fix
So, AP6476 wifi. Anything else working? To compile BT stuff for other chips than RTL8723 (uses rtk_btusb) the code does not compile. Sorry for now.
OK but please don't forget about me...Cry
RJSC
297
2016/01/11 - 03:18
Pipo M9 Pro here also:
Even with the latest model fix, Bluetooth anda wi-fi direct do not work.
Any suggestions?
The following users say thank you to RJSC for this useful post:
uli-hh
KSM2016
298
2016/01/11 - 12:30
Like on Kermit´s Iron NO sound for me too.
Tested with
5.0.2
5.1.1 v1.0 and
5.1.1 v1.1
I bought the Iron three Month ago if this helps.
Sorry, no backup of the original ROM.
dops75
299
2016/01/13 - 13:53
Hi Oma,
Something new for me? 🙁
Thanks 😉
perillo
Forum Posts: 16
300
2016/01/25 - 16:51
Hi oma,
i have a big problem with the v88 rom in my bq edison 2 QC, when i use an application that use many CPU and RAM or use many applications at the same time the tablet's reboot alone, i try to flash the rom another time but now the tablet reboot many more times, for example when i using spotify or google chrome wiht only a page open, who is happening?
Sorry for my bad english
97 Guest(s)
Devices in use: Desktop (92), Phone (5)
gerry3818
jaga1986
Piotrassss
mgsppt
inigo
janefonda
