[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
2015/09/24 - 21:17
Jammed_Death said
ehy oma, i and another user noticed a problem and recurring lag when wifi goes and stays on. With the stock and even all the custom roms we tried on a qilive 97r. There is a way to discover what's the cause? Don't know, a service, kernel or something?
First things first: the build is booting on Qlive 97R?
When there is the same effect with different firmwares this is clearly hardware/kernel related.
Cusco
Russia
Forum Posts: 22
2015/09/24 - 22:00
Hi, Oma!
Tried this rom on Pipo m6pro whith cube parameter file.
CWM shows this:
Tablet stucks on first logo.
2015/09/24 - 22:04
Use the default parameter file.
Cusco
Russia
Forum Posts: 22
2015/09/24 - 22:32
Just tried. Got the same
2015/09/24 - 22:34
Did you execute eraseIDB?
Cusco
Russia
Forum Posts: 22
2015/09/24 - 22:39
I'm sorry. It's starting...
Booted. I'm lucky!
But now I have 13,5 GB instead of 32, and virtual sd2 that can't mount.
2015/09/24 - 23:16
Here is a parameter file for 32 GB: http://crewrktablets.arctablet.com/?wpfb_dl=2666. Change in folder /rockdev and flash again, incl. eraseIDB.
Ignore virtual sd2.
Cusco
Russia
Forum Posts: 22
2015/09/25 - 00:20
Thanks! Internal and external sd looks good.
But now I have troubles whith networks: wifi, bluetooth, mobile network don't turn on.
So I can't test gps because I don't have any maps on tablet.
Added: And there is no flashdrive or mtp usb connection. Only adb interface present if turned on.
2015/09/25 - 06:41
Can I have a dmesg and a logcat log log (tool)? Reboot tab before and try to enable wifi a few times.
According to our last discussion M6pro has AP6476 wifi. The chip has also GPS, which is not supported by the CM12.1 build.
You can enable USB connection under settings/storage.
Cytryn
Forum Posts: 35
Thanks Received: 4
2015/09/25 - 08:25
All storages are emulated, so it should be /mnt/storage/usb0.
I know that it is emulated but its not working for me usb drive not connecting. i checked this folder and other one and nothing showing.
Can anyone confirm that usb drive via usb otg cable working and can see usb drive content?
ohh i see Cusco confirmed that.
Cytryn
Forum Posts: 35
Thanks Received: 4
2015/09/25 - 08:33
You need to turn off debugging and enable mtp connection to make mtp work.
Flashdrive not working for me as well.
Cusco
Russia
Forum Posts: 22
2015/09/25 - 10:43
here's the log (from terminal)
Cytryn
mtp works after turning off debugging, thanks
usb otg doesn't work for me too
perillo
Forum Posts: 16
2015/09/25 - 14:43
I try your cm12.1 rom in my BQ Edison 2 QC and this works, but have some bugs for example the wifi, bluetooth and screen rotation doesn't work correctly and i can´t set the screen dpi in 160, if i flash the fix for 160 dpi screen works in 200 dpi, I´m waiting for the build 2.0, now i´m using your cm12 and works fine, only don´t work the screen rotation
Great work oma, thanks you
2015/09/25 - 16:56
Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2672
2015/09/25 - 17:02
Thank you for feedback! Can I have a dmesg and a logcat log from the running CM12 build?
Btw in CM12.1 one can change the resolution on the fly in settings/display/.
cm12.1_v1.2_10.pngImage Enlarger
70 Guest(s)
Devices in use: Desktop (64), Phone (6)
