[ ROM ] Odys Iron CM12.1 LP 5.1.1 custom root firmware (2015/09/20)
Thanks Received: 1378
256
2015/12/04 - 19:07
uli-hh said
Them I flashed again with the RK31 Kernel 3036 Hr M9pro Pipo 2. This time touch screen worked perfectly. But still no wifi and no bluetooth. Also random reboots when doing settings or starting apps. When tab is gone to sleep modus automatically it does not wake up with power button. I've to reboot. Here is a logcat
Did you try the model fix? http://crewrktablets.arctablet.com/?wpfb_dl=2696
eckengucker
257
2015/12/04 - 19:55
well whats about this one: http://crewrktablets.arctablet.com/?wpfb_dl=1291 ? looks like 3.0.36. But my tab is fucked up now. Screen is flickering and it wont boot. Should be a hardware fault..
258
2015/12/04 - 20:02
Well, that's a kernel for Pipo S3 pro. So, could not work.
eckengucker
259
2015/12/04 - 20:07
sry. I ment s3 pro 🙁 anyway. hardware is broken now. has nothing to do with the rom 😉
Mark06
Forum Posts: 222
Thanks Received: 41
260
2015/12/05 - 07:36
Can't you get into cwm recovery holding volume and power button?
Cube u30gt2 tab
uli-hh
Forum Posts: 31
Thanks Received: 8
261
2015/12/05 - 13:49
of course!
262
2015/12/05 - 14:16
Hm, where can I find a working stock firmware for your specific M9pro hardware revision?
uli-hh
Forum Posts: 31
Thanks Received: 8
263
2015/12/05 - 15:42
Here you'll find all links to all M9pro Roms:
Pipo M9 Pro Firmware
I'm normally using the Kasty-Rom from here.
264
2015/12/05 - 16:58
Thanks ... hope I've found the right one 😉
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=2745
uli-hh
Forum Posts: 31
Thanks Received: 8
265
2015/12/05 - 18:40
I've installed the offered model_fix_Pipo_M9pro_2 after flashing the CM12.1 with factory reset.
The tab booted without any problem, but when I switch on Wifi in setting, the tab is going into a bootloop.
266
2015/12/05 - 18:43
So, pls let me have an link to a JB build which works with your touch conroller.
uli-hh
Forum Posts: 31
Thanks Received: 8
267
2015/12/05 - 19:35
Pipo M9 Pro RileyROM 2.7 Jellybean
or an older one
Pipo M9 Pro - Finless 1.5 ROM
I've installed the CM12.1 rom with the kernel from these two working JB roms (+ model fix).
Both times the same result: Wifi on = bootloopCry
bseixas
Forum Posts: 23
268
2015/12/13 - 00:05
Am i the only one with stability problems on Chuwi V88 (TIG version) ?
Two situations i could replicate often was Youtube app closing to home screen and random reboots on web browsing, already made a factory reset and both issues remains.
sindicat21
Forum Posts: 35
269
2015/12/25 - 12:58
Anyone have ideas how to fix problem with WIFI ?
"Always sleep" option not solving this problem
Hw decoding of media contents won't working, tried a few films with VLC and MX-Player
Kermit21
270
2015/12/25 - 17:23
HW decoding also don't work for me (Odys Iron). But I even have no sound at all. And sometimes my tablet reboots spontaneously 🙁
I attach the kernel ring buffer (dmesg). Maybe someone can tell me to use another kernel for my odys iron oder similar patch?
Thanks in advance,
Kermit
84 Guest(s)
Devices in use: Desktop (76), Phone (7), Tablet (1)
gerry3818
jaga1986
Piotrassss
mgsppt
inigo
janefonda
